It is currently Sat Apr 29, 2017 3:19 am
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Fri Mar 30, 2012 5:04 pm
What are your thoughts on these two bikes? Allez Evo is alum with better components listed here:
http://www.specialized.com/us/en/bc/SBC ... 1551,62280
Tarmac is obviously carbon, albeit their entry level carbon frame with components that are not quite as good (but I've read that apex is not bad at all when compared to rival). Prices are about the same. Thoughts?
PostPosted: Fri Mar 30, 2012 7:05 pm
Tarmac for sure, you can always upgrade the components later on.
PostPosted: Fri Mar 30, 2012 9:28 pm
I'd say you'd have to ride them.
I'd guess that the allez comes out lighter overall. You are going to give up weight in the wheels and componenents for the tarmac.
My guess would be that the 8r tarmac isn't going to be any stiffer than the allez, but will probably be a little more comfortable with the road buzz from the rear. The carbon fork in the front is likely the same. Stock, I think the allez is likely a better overall bike. The frames are likely within 100g weight.
FWIW, My commuter is a '12 allez evo / rival with red shifters, and my nice bike is a '11 s-works tarmac sl3 with red. I definitely notice a difference between the weight and agility of the frames, but its not nearly as drastic as you might expect. I'm not sure how much of a difference in stiffness and weight the 11r vs 8r construction makes, but I'd guess the 8r frame is going to be at least ~200ish grams heavier than the 11r S-works, which would put the 8r tarmac in the range of the allez.
I guess my point is that the allez might be a better frame than the 8r tarmac, depending on what you want, so don't just write it off as a negative.
There are no new unread posts for this topic. Upgrading A Specialized Allez
JamesGRC
35
3804
Wed Aug 10, 2016 9:43 pm
Frankie - B View the latest post
There are no new unread posts for this topic. 2013 Specialized Allez Headset
JamesGRC
7
501
Tue Dec 06, 2016 12:38 pm
goodboyr View the latest post
There are no new unread posts for this topic. 2010 Specialized Allez Re-build & Upgrade
DamenH85
10
1233
Thu Aug 04, 2016 5:46 pm
DamenH85 View the latest post
There are no new unread posts for this topic. 2015-17 Specialized Tarmac frames?
AW84
Thu Oct 27, 2016 7:59 am
mpulsiv View the latest post
There are no new unread posts for this topic. Specialized Tarmac vs Cannondale Caad 12
marcello
12
3413
Tue Aug 23, 2016 8:56 am
treetrees View the latest post
Users browsing this forum: Baidu [Spider], EvilEuro, Exabot [Bot], glam2deaf, Yahoo [Bot] and 37 guests
