It is currently Wed Jan 17, 2018 2:24 am
Post new topic  Reply to topic  [ 107 posts ]  Go to page Previous 1 2 3 4 58 Next
PostPosted: Thu Apr 19, 2012 6:24 am
H Plus Son Archetype rim is 450g per their website.
according to their website the lightest rim the sell is 450g
Archetype
Weight: 450 grams
Material: G609 Alloy
Height: 25 mm
Width: 23 mm
Joint: Welded
The perfect all around road rim. At 450 grams, this rim has proven to be light yet not sacrificing strength, stiffness, and stability. The well accepted 23mm wide profile mimics a tubular tire, where the advantage can be felt immediately while taking corners as the tire is no longer shaped as a light bulb, flopping over with high load. Our impeccable H Plus Son workmanship and our invisible welded rim joint comes standard with each rim.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
PostPosted: Thu Apr 19, 2012 6:25 am
WTF? :smartass:
Bike Pure
PostPosted: Fri Apr 20, 2012 8:29 pm
How does the rim being 22 grams lighter have anything to do with the price? :noidea:
...and the weights are 472 and 450
Current:
T2
Retired:
PostPosted: Sat Apr 21, 2012 5:12 pm
One thing we have al learned over the years is if a rim manufacturer claims a weight @ 450 grams they usually are verified at 20 grams more. Seems to be a rule they try to follow for some reason. So the H Plus Son rim probably comes in close to the BHS rim. They in fact may be the prime manufacturer if not Kinlin
PostPosted: Sun Apr 22, 2012 8:56 am
Yeah, definitely true about rim manufacturers fibbing a little bit on weight. Problem is that some manufacturers are notably worse than others. Tire manufacturers do this too.
PostPosted: Sun Apr 22, 2012 10:31 pm
Online
You reckon these would do well for CX racing?
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Mon Apr 23, 2012 3:57 am
Don't all al' rim weights creep up over time due to die wear, or am I just guessing?
The Kinlin 200s advertised on BHS as 375g that I bought recently were 390g. Velocity Aeroheads are reputedly considerably heavier than their advertised weight. These have been around for a few years. However brand new Stan's 340s seem to come in at or under advertised weight.
r o y g b i v
PostPosted: Tue Apr 24, 2012 1:58 pm
The last time I put Kinlin XR200s on the scale they were averaging around 375g. After reading your post, I weighed 6 more from another production run. They were averaging around 383g. I've updated the website to reflect this. I've never weighed an XR200 at 390g, but it's not impossible. I don't weigh every one that goes out, that's for sure!
http://www.bikehubstore.com
PostPosted: Wed Apr 25, 2012 6:46 pm
I ordered a pair, 20/24, to build with BHS hubs ... I will post weights when I get them.
PostPosted: Thu Apr 26, 2012 7:45 am
This is probably a silly question, but I am going to ask it anyway.
My Ghisallo wooden rims took quite a beating at the Liege-Bastogne-Liege grand fondo last Saturday, so I in need of some new rims.
I am planning to go for 23mm rims. On my current wheels I am running 25mm tires (GP4000s). Will the aero advantage of the 23mm rim work with both 23 and 25 tires or just with 23?
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Thu Apr 26, 2012 8:14 am
There are no aerodynamic benefits with a 'standard' 23 mm rim (e.g. Hed Belgium C2, Velocity A23, H Plus Son Archetype). The curvature of the rim near the spoke nipples isn't sufficiently gentle to delay boundary layer separation. The benefits with these rims are ride/handing improvements due to improved tire deformation.
If you want aerodynamic improvements you have to consider rims such as the Zipp 101, Hed Jet 4 etc. These are slightly deeper (30 mm or greater) and have a rim shape that ensures that the boundary layer doesn't separate at the tire sidewall.
PostPosted: Thu Apr 26, 2012 12:27 pm
Will the ride/handling improvement be the same with 25mm tires, because I understand 23mm wide rims are built for use with 23mm tires?
PostPosted: Thu Apr 26, 2012 12:30 pm
23mm rims will be better with 25mm tyres than 19mm rims are with 25mm tyres.
The ride/handling won't be the same, the ride will be better, the handling will be similar
Bike Pure
PostPosted: Thu Apr 26, 2012 12:51 pm
CX bikes and touring bikes have been using wider rims with their wider tires for a long time. They are stiffer and support the tire better for better handling etc.
Aero is bound to be better as the tire/rim is less light bulb shaped, but you'd be hard pushed to call it aero.
Again the aero will be better with 23mm tires and 23mm rims as the flow off te tyre onto the rim will be better. Doesn't mean it could be improved more wit the right shape around the spoke bead or a deeper profile. If you want more aero that has typically meant more weight added to the rim, so take your choice - deeper more aero and more weight, shallow lighter and less aero.
PostPosted: Thu Apr 26, 2012 12:54 pm
Daft question, but if you ran 19,20,21,22 mm tyres in a stock wheel will this mimic the effect of a wider rim ? :?:
There are no new unread posts for this topic. 3T Strada aero road bike is made for wide tires and 1×12 drivetrains
[ Go to page: 113 14 15 16 17 ]
KarlC
246
24949
Sat Dec 23, 2017 11:47 pm
romalor View the latest post
There are no new unread posts for this topic. Attachment(s) 23mm on 17mm internal diameter rims?
wwnick
27
3592
Thu May 25, 2017 4:17 am
Hexsense View the latest post
There are no new unread posts for this topic. Tire measurement on 23mm and 24mm rims.
Lrdchaos
Wed May 10, 2017 11:44 pm
BRM View the latest post
There are no new unread posts for this topic. Tire Choice for Giant SLR 0 Carbon Wheels - 23mm width
amtbr
27
3865
Mon Jun 12, 2017 3:35 pm
Jju3jin View the latest post
There are no new unread posts for this topic. Aero bars on non aero race bike
gurk700
19
4468
Wed Jan 03, 2018 7:29 pm
Chans1ee View the latest post
Users browsing this forum: No registered users and 3 guests
cron
