Post new topic Reply to topic  [ 107 posts ]
Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
PostPosted: Sun Apr 01, 2012 8:00 am
Whelps, looks like I am going to have yet another wheelset! Going to be doing a relay across the US this summer and have been thinking about trying out wide rims... and now BHS has them!
Front Hub Rotaz 1 67 67
Spokes Laser 28 4.5 126
Nipples Brass 28 1 28
Rim BHS C472 1 472 472
Rear Hub Rotaz 1 228 228
Spokes Laser 32 4.5 144
Nipples Brass 32 1 32
1569g Total
Not bad at all weight wise... Probably will do 1x front 2x rear. And yes, I am one of those weird people that like building wheels with lasers.
PostPosted: Sun Apr 01, 2012 11:32 am
Hi Dummey, why are you going for the Rotaz hubs rather the ones that offer the enduro sealed bearings ... thanks
PostPosted: Sun Apr 01, 2012 7:58 pm
I assume you are talking about the DATI hubs. They only come drilled up to 24/28 and I would like this set of wheels to be 28/32. Aside from that, I currently have 2 sets of wheels built up with the Rotaz hubs and love them quite a bit.
If I ever got a set of lower spoke count rims such as the carbon clinchers on BHS, I would probably get the DATI hubs to try them, but I doubt there is gonig to be much of an improvement over the Rotaz.
PostPosted: Tue Apr 17, 2012 1:15 pm
Hi
Are there any wheelbuilders in London who can build these for a reasonable price ?
PostPosted: Tue Apr 17, 2012 1:35 pm
awesome! it seems like the component costs and building it yourself really undercuts boyd.
α
PostPosted: Wed Apr 18, 2012 1:22 pm
WWotY 2007
cep111 wrote:
http://www.bikehubstore.com/category-s/162.htm" onclick="window.open(this.href);return false;
It doesn't saw Niobium but the weight seems like it might be, 28mm deep and 23 wide with aero profile 470 grams. Sure that it's the one Boyds uses and many more will over the next few months.
I was just planning on building a set of Heds c2's but this saves lots of cash and more hole drillings available.
This rim is made by Kinlin, this is the new XC279, designed for cyclo-cross.
RAR wheels
Roues Artisanales
PostPosted: Wed Apr 18, 2012 4:39 pm
Anyone see a problem with this build.
NEW: BHS C472w Clincher Rim - 23mm wide - 28mm deep - 472g = 944g
UltraLight Front Road Hub - 66 grams 24 radial laced.
SuperLight Rear Hub - 211 grams 28
Sapim CX-Ray - Black 4.5g = 234
Sapim 14mm Aluminum Alloy Poly-Ax Nipples -14G - Black = 18.2
Total weight = 1474g total weight.
Match this up with some Latex tubes and some 23mm wide Conti 4000S tires should be a great rolling and low rolling resistance set up.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Wed Apr 18, 2012 4:50 pm
Depending on weight and the hub flange spacing, the rear might not be all that stiff unless you use a triplet or half radial pattern in my experience. 2x with CX-Rays has never been that great of a rear wheel setup for me.
PostPosted: Wed Apr 18, 2012 5:39 pm
I am pretty sure that I am running that on my EDGE 45 set up but will have to check when I get home.
That wheelset has been great so far.
BIG DADDY B FLOW
PostPosted: Wed Apr 18, 2012 6:53 pm
[quote="BmanX"]Anyone see a problem with this build.
Match this up with some Latex tubes and some 23mm wide Conti 4000S tires should be a great rolling and low rolling resistance set up.[/quote]
Use Sapim Race (or DT Aero Comps if ya gotta have bladed) for the rear drive side and the wheel will be a fair bit stiffer. Probably adds 1.5g/spoke * 14 spokes = ~20-25g.
PostPosted: Wed Apr 18, 2012 10:12 pm
Oh yeah? Well, check this out. This relatively small company, H Plus Son, makes an affordable wide road rim called the Archetype. And the weight is decent for you weight weenies.
H Plus Son
Rim: Archetype
width: 23mm :)
weight: 450g :)
http://hplusson.com/products/archetype
PostPosted: Wed Apr 18, 2012 10:35 pm
I'm a bit new to road biking. Can someone briefly explain the virtues of a wide rim? These seem really wide to me. Is it just added stiffness that you're after?
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Wed Apr 18, 2012 10:43 pm
no they allow a wider contact patch with normal 23mm tyres, which reduces rolling resistance. They also allow a larger airvolume so you can reduce pressure in the tyres and increase comfort. They are also meant to be more aero because the transition from rim to tyre is smoother.
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Wed Apr 18, 2012 11:14 pm
H Plus Son
Rim: Archetype
width: 23mm :)
weight: 450g :)
That's also more expensive
PostPosted: Thu Apr 19, 2012 6:14 am
Imaking20 wrote:
H Plus Son
Rim: Archetype
width: 23mm :)
weight: 450g :)
No it isn't. The generic BHS rim that the original poster linked to is 372g. And the H Plus Son Archetype rim is lighter, 350g.
Post new topic Reply to topic  [ 107 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
Users browsing this forum: No registered users and 3 guests
There are no new unread posts for this topic. Farsports 38mm Cyclecross Clinchers (23mm wide)
in Everything wheels
SteveFromNY
11
570
Tue May 07, 2013 4:26 am
kylefoo View the latest post
There are no new unread posts for this topic. 22 or 23mm front tire?
GASer
Fri Nov 30, 2012 11:12 pm
fdegrove View the latest post
There are no new unread posts for this topic. 2x NEW Mavic Yksion Grip Link 23mm tubulars - 50eur shipped!
Berk
Thu Apr 18, 2013 5:46 pm
Berk View the latest post
There are no new unread posts for this topic. accelerated tread wear veloflex carbon 23mm versus 22mm
Thirstyman
Wed May 23, 2012 12:29 pm
notsoswift View the latest post
There are no new unread posts for this topic. The wide rim craze.
Juanmoretime
Sun May 12, 2013 3:18 am
pushstart View the latest post
It is currently Mon May 20, 2013 9:51 pm
