Post new topic Reply to topic  [ 10 posts ]
 Post subject: Steel ISP tube...
PostPosted: Thu Mar 29, 2012 11:24 pm
Hi forum,
Which manufacturer makes steel seat tubes long enough for my 73 cm ISP plan? Columbus and Dedacciai both don't make them longer than 62 cm. Any ideas?
Thanks in advance,
Timo
And if I ever meet an aardvark, I'm going to step on its damn protruding nasal implement until it couldn't suck up an insect if its life depended on it.
 Post subject: Re: Steel ISP tube...
PostPosted: Thu Mar 29, 2012 11:30 pm
Even if you could get it that long, you would need a custom quad butted tube or add an external gusset. Try asking Vanilla/Speedvagen/DeSalvo.
PostPosted: Thu Mar 29, 2012 11:37 pm
the true temper HOXPLAT 13 is 737 mm long and has a diameter of 737 mm
CARPE DIEM
Colnago C59 Italia GLBK
Up coming custom steel cyclocross :D
PostPosted: Fri Mar 30, 2012 12:10 am
guessing that's a mis type? :mrgreen:
PostPosted: Fri Mar 30, 2012 2:19 am
oops :oops: a length*
CARPE DIEM
PostPosted: Fri Mar 30, 2012 3:56 am
A work-around would be to use a plain gauge piece of tubing. What OD are we talking?
PostPosted: Fri Mar 30, 2012 4:28 am
Aircraftspruce.com should be able to set you straight. All sorts of straight gauge 4130 in appropriate wall thicknesses. Custom lengths available. Quick shipping. Not much to complain about.
This board and the world in general would be a much nicer place if everyone could just take themselves a little less seriously.
PostPosted: Fri Mar 30, 2012 6:22 pm
Why would you want to use straight gauge?! A steel ISP is already going to be heavier than a Al or Carbon seat post...using straight gauge would be waaay heavier.
PostPosted: Fri Mar 30, 2012 8:05 pm
I recommended straight gauge because the OP asked for a long steel tube. I'd assume that if he was having a custom frame made to his specs, the builder would have a lathe and would be able to turn the tube to whatever wall thickness they desired, even if the butting had to be external. That's the route I went with the frame I did with an ISP, and worked out swimmingly. You are probably correct that it is heavier, but that wasn't a big concern for me.
PostPosted: Sat Mar 31, 2012 1:08 am
That's right, it's an Italian builder who will do a custom frame for me. He uses tubes from the Columbus and Dedacciai range but these companies don't do anything above 620mm. Weight isn't the big issue or I would not have chosen steel in the first place. That said, I must say that I considered an aluminium frame build from Deda Fire tubing since that tube set includes a 750mm seat tube. But I want a frame with slim tubes so steel is the way to go I guess.
Users browsing this forum: 1415chris, Gearjunkie, Google [Bot], Google Adsense [Bot], jo.k, Juanmoretime, SWijland, theremery, Tom-s and 50 guests
There are no new unread posts for this topic. TT fit - top tube
Kermithimself
14
707
Mon Aug 27, 2012 12:14 am
WMW View the latest post
There are no new unread posts for this topic. Titanium/steel frame help
canbakay
22
1372
Thu Mar 14, 2013 12:23 am
maxxevv View the latest post
There are no new unread posts for this topic. New Steel Build - need help to keep the weight down
OB2000
Wed Jan 23, 2013 9:31 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Kbedford steel... Newold
CharlesM
29
1992
Thu Jan 31, 2013 12:35 am
madcow View the latest post
There are no new unread posts for this topic. Shimano E-Tube with a Mac
Tamu8104
Sun Dec 16, 2012 4:20 am
Tamu8104 View the latest post
It is currently Thu May 23, 2013 9:44 am
