Post new topic Reply to topic  [ 8 posts ]
PostPosted: Wed Mar 28, 2012 1:58 pm
Hey Folks-
I'm looking to kit my Cervelo S5 with new Red when I can get it. Will I be stuck with the stock BBRight crank, or is the new Red crank compatible? Thanks!
MD
PostPosted: Wed Mar 28, 2012 2:29 pm
http://bbright.net/supportingbrands.aspx
:beerchug:
PostPosted: Wed Mar 28, 2012 4:31 pm
The new RED cranks are only available as GXP and BB30. You can get the GXP version and then an adapter to convert your BBRight to GXP.
If you wait there will be a New Red chainring S975 BBRight crank available but it may be very hard to source as it is usually an OEM only crank.
PostPosted: Wed Mar 28, 2012 10:42 pm
If you end up going through Rotor, you would be able to order up a BBright BB compatible with either GXP or BB30. You're safe either way.
PostPosted: Wed Mar 28, 2012 11:14 pm
BBRight is BB30 with 11mm extra width on the non-drive side (79mm BB shell width offset 11mm to non-drive side). The standard BB30 Red crank does not fit as it is specific to the 68mm BB30 shell standard. You have two options for a Red crank on BBRight.
Use the GXP version with an adaptor - available from Wheels Manufacturing or Enduro Bearings.
Use the BB30 Red branded Quarq powermeter. This is the same as the current S975 crank but with new Red graphics. Note that it doesn't use the hollow carbon manufacturing process that the new Red crank uses, it relies on an aluminium spine like old Red. So it's heavier, but it looks the part and has powermeter capabilities.
I don't know which option works out lighter - GXP version has heavier arms and needs an adaptor - S975 BB30 version has old style heavier arms.
Grover's Grumblings
Grover's Garage
PostPosted: Thu Mar 29, 2012 12:54 pm
I've installed sram bb30 cranks in a bbright frame. I had to remove the bearing preload adjustment ring from the non drive side crank, and then use some bb30 spacers and a wavy washer. It took a couple of tries to get the right number of spacers, but it worked just fine in the end. Fwiw, this was on a quarq s975 bb30 crank, installing into a 2011 r3.
My Rides:
2011 S3 Sram Red/808's/Zipp SLC2/Romin Pro
2009 SWorks Epic/Handbuilt wheels (by me)/Marta SL magnesiums/ XTR drivetrain
2008 Ellsworth Moment/ Handbuilt wheels (by me)/ Marta SL/ X0 (9spd) drivetrain
K.P.A.
PostPosted: Thu Mar 29, 2012 1:10 pm
All the bb30 s975 cranks can do this as this is what they do to create the BBRight cranks.
PostPosted: Fri Mar 30, 2012 8:57 am
just be aware that red bb30 cranks don't use the same preload system as s975 bb30 cranks. red bb30 will not fit bbright.
Grover's Grumblings
Grover's Garage
Users browsing this forum: 573, angrylegs, Bing [Bot], Butcher, ElNotorio, Google [Bot], Google Adsense [Bot], KLabs, maxxevv, rijndael, xFree, yourdaguy and 42 guests
There are no new unread posts for this topic. Specialized carbon crank on BBright?
dalex
Wed Dec 05, 2012 9:22 pm
spud View the latest post
There are no new unread posts for this topic. Rotor 3D+ vs Sram Red for bbright
1415chris
22
2161
Wed Nov 21, 2012 3:28 am
There are no new unread posts for this topic. SRAM 2013 Rings on non SRAM crank?
itsacarr
Tue Jul 03, 2012 3:48 am
boots2000 View the latest post
There are no new unread posts for this topic. Attachment(s) Experience with Sram S900 crank
Bregne
16
1300
Sun Nov 18, 2012 12:42 am
claus View the latest post
This topic is locked, you cannot edit posts or make further replies. Sram Force crank vs Rotor 3D
rich00
Wed Mar 20, 2013 2:36 am
rich00 View the latest post
It is currently Wed May 22, 2013 2:17 pm
SRAM Red crankset
