Post new topic Reply to topic  [ 6 posts ]
PostPosted: Tue Mar 27, 2012 1:12 pm
Hello people wonder if you can give me some advice for my CAAD10 build.
I am not sure which bearings to go with to install my SISL crank and what the pros and cons are
-Cannondale standard steel bearings.
-Cannondale ceramic bearings.
-Sram Pressfit BB30 with ceramic bearings.
Your views are welcome thanks.
Caad9 BBQ Durace7800 build
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=82445#p721875
PostPosted: Tue Mar 27, 2012 1:35 pm
I would go with an Enduro Zero Ceramic BB30 Kit. CAAD 10s aren't Press Fit.
Cannondale CAAD 10 63cm || Cannondale Flash Carbon 29er || Cannondale Evo 63cm
PostPosted: Tue Mar 27, 2012 1:52 pm
Standard steel bearings ABEC-3 or better (you will never notice a difference when riding of ABEC-5+). The seals and spacers create more drag than the balls will in these bearings and it is of no benefit to performance. The only (arguably) real world benefit of ceramics is corrosion resistance, however the reports on the forums seem to indicate the ceramics are not standing up to actual use and wear out prematurely relative to steel bearings.
I have had a set of SRAM standard steel bearings with Hollowgram SISL crankset in my CAAD9 9 for more than 3 years and I ride 4-6 days per week year round. I have never done anything to these bearings post install and they still spin fine and the BB has no noises or play in it.
You can get bearings suitable for around 4$ each on Ebay should you need reaplcements, ordering them from a bicycle specialist will only cost you more $ for the same thing.
PostPosted: Tue Mar 27, 2012 4:00 pm
AVOID the cdale ceramics at all costs (even if free).
PostPosted: Tue Mar 27, 2012 4:40 pm
Get some Phil Wood bearings, they make BB30 bearings. You'll need circlips and bearing shields as I believe they just sell the individual bearings.
PostPosted: Tue Mar 27, 2012 9:20 pm
HSC make a full BB30 kit with shields and clips. I don't have the full kit (just the 6806 bearings) but fairwheel might
Cannondale ceramics were awful at one point, but it was costing them so much in warranty they did resource eventually. That said you might get handed an old set.
Enduro......some love them some hate them. The haters always seem to be louder
signature deleted by the Admin.
Users browsing this forum: Google Adsense [Bot], micky, Vuong05 and 46 guests
There are no new unread posts for this topic. Cannondale SISL crank on Scott Foil
Kingston
15
1313
Thu Dec 27, 2012 6:43 pm
Elrey View the latest post
This topic is locked, you cannot edit posts or make further replies. Help & advice needed - Lightweight Wheels - ceramic bearings
duzza
Thu Sep 06, 2012 12:40 am
reggiebaseball View the latest post
There are no new unread posts for this topic. Campy UT Crank Cult Bearings - Replace or just re-grease.
JWolf
10
661
Sat Aug 04, 2012 9:03 am
Mattias Hellöre View the latest post
There are no new unread posts for this topic. Crank selection for Power2Max - advice appreciated!
thencameyou
Sun Aug 12, 2012 12:54 am
Voye View the latest post
There are no new unread posts for this topic. how many spacers going from SiSl to SiSL2 axle
styrrell
Sun May 19, 2013 4:16 pm
styrrell View the latest post
It is currently Sat May 25, 2013 8:51 am
