Post new topic Reply to topic  [ 10 posts ]
PostPosted: Mon Mar 26, 2012 3:11 pm
I've got a squeak which I'm fairly sure is coming from my Record 11s Ultra Torque (steel bearings) crank. It's done 8,000 miles and Campagnolo says regrease every (approx) 4,000 miles.
Question: The manual says use "Campagnolo Professional Lubricating Grease (cod. LB-100)", but can I assume any good automotive grease is OK? Castrol LM for example?
Under the Sun - a thriller for weightweenies with bike loving main character on Kindle here
PostPosted: Mon Mar 26, 2012 6:00 pm
I've never heard of UT's squeaking. But I can't count the number of times I've convinced myself of a BB problem, only to discover that it's a pedal squeak. I'd be looking elsewhere first.
Unless you've been hosing the bike down with high pressure, there's no reason for the bearings to need attention at this stage.
dangerous curves ahead
PostPosted: Tue Mar 27, 2012 5:48 am
I had a little creak on Record UT Ti and used
copper prep paste which cured it.
PostPosted: Tue Mar 27, 2012 7:33 am
My UT setup has never squeaked but I did find beads of moisture in and around the bearings and cups when I first opened them up and only a thin film of factory grease remaining. The bike had never been hosed down, just ridden in rain showers a few times.
I use Sta-Lube Marine grease in all of the serviceable bearings on my bike including UT bearings. The product is cheap and stays in place without adding much drag. I got onto it after checking out opinions on the web. Incidentally, Gary Fisher apparently insisted on it being used for assembly of his bikes years ago and used to ship drums of it over to Asia.
The squeak may originate elsewhere but repacking the bottom bracket is a good idea anyway and really easy to do.
PostPosted: Wed Mar 28, 2012 10:01 pm
Thanks for all the advice and suggestions. After the doubts expressed (and another ride) I'm now wondering about the source of the sound. It's an intermittent dry, squealing sort of squeak - not a creaking sound. It stops when I stop pedalling and it's bl**dy hard to locate.
All I need is a Tour de France-style mechanic, leaning out of the team car at speed, and using a stethoscope.
PostPosted: Wed Mar 28, 2012 10:40 pm
Try changing and/or lubing your QR skewers. Your pedaling might cause a vibration which propagates to the QR skewer (particularly the rear, but maybe front), and the propensity for the noise might depend on which gear (cog combination) you're in.
Regarding saddle/seatpost/clamp, does it make the noise when out of the saddle?
PostPosted: Wed Mar 28, 2012 11:14 pm
Yes, it does.
PostPosted: Thu Mar 29, 2012 12:16 am
Then check those QR skewers.
PostPosted: Thu Mar 29, 2012 12:21 am
and try different pedals & shoes
PostPosted: Thu Mar 29, 2012 1:51 am
I had the same issue and always thought it came from the BB, but it ended up to be the front QR skewer. Some grease did the trick to my Tune14 skewer.
Pfeiffer's Rennrad Camp and Cycling Coach
Independent HED Wheels/Powertap Dealer
Users browsing this forum: Bing [Bot], coloclimber, dha, Google [Bot], Google Adsense [Bot], Majestic-12 [Bot], mdeth1313, nickf, timj, Tom-s and 55 guests
There are no new unread posts for this topic. Campy UT Crank Cult Bearings - Replace or just re-grease.
JWolf
10
659
Sat Aug 04, 2012 9:03 am
Mattias Hellöre View the latest post
There are no new unread posts for this topic. BB86 ultra torque compatible?
rhyslewisdavies
Mon Jun 04, 2012 9:00 am
rhyslewisdavies View the latest post
There are no new unread posts for this topic. 68mm campag ultra torque in 72 mm shell?
SupaSubi
Fri Aug 10, 2012 8:45 pm
SupaSubi View the latest post
There are no new unread posts for this topic. Scott Foil BB and campagnolo ultra torque
kampiakseli
Mon Aug 27, 2012 2:51 pm
kampiakseli View the latest post
There are no new unread posts for this topic. Campa Ultra Torque observations and questions.
fdegrove
24
1324
Thu Mar 21, 2013 12:59 am
Calnago View the latest post
It is currently Tue May 21, 2013 2:52 pm
