Post new topic Reply to topic  [ 8 posts ]
PostPosted: Sat Mar 24, 2012 1:58 pm
Hi all,
Just got hold of an SRAM S975 Quarq and I'm struggling a bit with the current BB in my bike. I was led to believe that the Quarq will work with Shimano GXP bottom brackets but mine doesn't seem to fit properly.
My problem is basically, when the crankset is fully tightened, the axle moves around in the BB. I've tried various spacers which solve the problem to some extent, although only because the non-drive side is then pressing tighter against the BB bearings. As soon as I apply any kind of torque to the crankset, the problem reoccurs.
At the moment I'm using a Shimano 105 5700 BB.
Would replacing the BB with this do any good?
http://www.ribblecycles.co.uk/sp/road-t ... RAMBTBR220" onclick="window.open(this.href);return false;
Any suggestions?
K2
Do you suffer more when you train, or cannot train?
viewtopic.php?f=10&t=83160&p=727610#p727610" onclick="window.open(this.href);return false;
PostPosted: Sat Mar 24, 2012 2:09 pm
The crank will only work with SRAM GXP bb's
The crank relies on the non drive bearing to have a smaller inside diameter to hold the system in place. Shimano and has the same diameter so it will not work.
SRAM bb's are pretty cheap so it is an easy fix
PostPosted: Sat Mar 24, 2012 2:12 pm
Good times, so I'm right in assuming this BB will do the trick?
K2
PostPosted: Sat Mar 24, 2012 2:28 pm
Yes
PostPosted: Sun Mar 25, 2012 2:51 am
I use the Chris King GXP BB on two different bikes. No issues. Let me know if you get it and need help with the spacers.
J
Race your bike in realtime using your browser
http://www.rollerracing.ca
PostPosted: Sun Mar 25, 2012 9:41 am
Picked up an SRAM BB yesterday. Everything seems to fit properly, I'll take it out for a test today.
On a side note, does it say explicitly anywhere that one needs a special type of BB, because I think they could've made that a bit more clear
K2
PostPosted: Sun Mar 25, 2012 12:13 pm
I've used the SRAM GXP.. It does the trick but I've blown out two of them. But they are cheap.
Quarq I don't think specifically says you have to get a GXP BB but they do say it's a GXP type crankset.. Just like they say some of their cranksets are BB30.. But if you don't follow this stuff closely, I can see how that would mean nothing to you..
J
PostPosted: Mon Mar 26, 2012 4:54 pm
They don't really need to say explicitly that it needs a special BB, simply because it's a SRAM crank. All SRAM (and Truvativ, Bontrager, etc.) outboard-bearing cranks require a GXP-standard BB. Conversely, all Shimano (and FSA, Raceface, etc.) require a Shimano-standard BB. Neither company's cranks will work on the other's BBs, and vice versa.
Who led you to believe that a SRAM crank would work with a Shimano BB?
Users browsing this forum: Bing [Bot], ethan44, Exabot [Bot], Google [Bot], mpower, revpower, sanrensho and 61 guests
There are no new unread posts for this topic. Bottom bracket question
BreakfastClub
11
591
Mon Feb 18, 2013 11:13 am
There are no new unread posts for this topic. Enduro XD-15 Bottom Bracket?
BdaGhisallo
Mon Apr 15, 2013 7:14 pm
rmerka View the latest post
There are no new unread posts for this topic. Attachment(s) Help, SRM FSA K-force - which bottom bracket?
srasmussen
Wed Aug 29, 2012 8:20 am
There are no new unread posts for this topic. Dura Ace Bottom Bracket Drag
kulivontot
19
1846
Wed Oct 10, 2012 7:51 am
ticou View the latest post
There are no new unread posts for this topic. Campag SR Bottom Bracket (bearings)
Simonhi
24
1274
Thu Oct 18, 2012 10:38 pm
5 8 5 View the latest post
It is currently Mon May 20, 2013 5:58 am
