Post new topic Reply to topic  [ 12 posts ]
 Post subject: Broken rear derailleur
PostPosted: Sat Mar 24, 2012 9:30 am
Hi there
My campag rear derailleur is playing up. When I move the chain into the inner chain ring, the rear derailleur does not seem to be taking up the slack. As a result the chain is slapping the chainstay. At first I thought my chain length was too long, I trimmed the chain by 2 links which has made no difference. Hence I think it is the rear derailleur. Has anyone come across this before?
Thanks
owl
Owl
PostPosted: Sat Mar 24, 2012 10:56 am
try moving the jockey wheel cage. Does it have spring tension remaining?
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Sat Mar 24, 2012 3:12 pm
Thanks - yes there is plenty of spring in it comes back with real force - could it be chain length still. In 53/25 it looks plenty tight
Thanks
owl
Owl
PostPosted: Sun Mar 25, 2012 3:25 am
Whats' 53/25? :noidea: Hopefully not your front chain rings.
PostPosted: Sun Mar 25, 2012 4:01 am
53/25 I am sure is big big.
PostPosted: Sun Mar 25, 2012 4:58 am
53T Front and 25T Rear
PostPosted: Sun Mar 25, 2012 6:45 am
Adjust the b-screw.
PostPosted: Sun Mar 25, 2012 8:23 am
thanks for that I will loosen the b screw, to pull the cage further away
Owl
PostPosted: Sun Mar 25, 2012 1:14 pm
If your freehub is binding for some reason (freewheel bearing seizing or broken pawl in the gubbins or cogs touching spokes or ....) then the chain slack will occur at the top of the chain as you describe whenever you stop pedaling.
r o y g b i v
PostPosted: Sun Mar 25, 2012 1:21 pm
chain slap is obviously more likely when in the small ring since the chain is much closer.
here's a pic of a big-big combo with the RD extended as far as you'd want to go
and in the small-small
dangerous curves ahead
PostPosted: Sun Mar 25, 2012 2:53 pm
Thanks for all the advice. The answer - bobsantini you were the correct. Over the winter I put a miche primato cassette on for my turbo, put about 600 miles on it on the turbo and took off a recon cassette which I put on for 2 short rides at the end of last season. The miche primato cassette is slightly too wide causing it to seize the freehub when freewheeling when the cranks are at 11/4 o'clock if that makes sense (what a crock of shi@!).
I swapped cassettes and chain - problem solved. Wont sell my recon cassette now :wink:
Owl
PostPosted: Mon Mar 26, 2012 1:24 pm
That B-screw needs to be adjusted...
Users browsing this forum: Bing [Bot], Dalai, Google [Bot], jpanspac, jwess1234, roadieboy and 44 guests
There are no new unread posts for this topic. Sram Red Rear Derailleur tuning
NiFTY
Sat Jul 28, 2012 1:18 pm
NiFTY View the latest post
There are no new unread posts for this topic. Attachment(s) What happened to my new sram red rear derailleur?
glowder
7
1199
Tue Dec 04, 2012 11:03 pm
SUCycling88 View the latest post
There are no new unread posts for this topic. Campagnolo rear derailleur circlip
SalsaLover
Mon Apr 08, 2013 7:04 am
SalsaLover View the latest post
There are no new unread posts for this topic. DA 9000 rear derailleur compatibility
lannes
Wed Mar 06, 2013 4:58 am
Doolop View the latest post
There are no new unread posts for this topic. Chain drop with Sram Red Rear Derailleur
bluhorizan
12
614
Sun Dec 09, 2012 10:30 am
bura View the latest post
It is currently Thu May 23, 2013 12:16 am
