Post new topic Reply to topic  [ 13 posts ]
 Post subject: mavic CD rims
PostPosted: Sat Mar 24, 2012 6:19 am
For those who have used the CD rims, how long did the coating last on the braking surface? Furthermore, does anyone know the difference between the exalith and CD?
 Post subject: Re: mavic CD rims
PostPosted: Sat Mar 24, 2012 7:59 am
CD was definitely not worth a hassle. It had started wearing off in a matter of days.
PostPosted: Sat Mar 24, 2012 8:56 am
edit: Sorry :oops: You would think that purchasing such expensive rims one would have learned the difference between CD and Ceramic coating :)
"Stay cool and try to survive" A. Klier to the other members of the Garmin classics squad the night before P-R.
PostPosted: Sat Mar 24, 2012 9:32 am
Just to clarify, I was referring to the CD, hardened anodising, not the ceramic coating versions.
PostPosted: Sat Mar 24, 2012 11:41 am
I rode on mavic open pro cd rims back in the day and they were ultra reliable and long lasting- i'd still use 'em today if I wanted handbuilt wheels.
PostPosted: Sat Mar 24, 2012 2:00 pm
Open Pro in all its guises is still a great rim.
The look of the CD rim doesn't last very long. The finish seems to remain intact until you get a few wet rides in. Then the rim develops an oscillating discoloration at the brake surface. At this point many people think the rim has a flaw and that the rim has gone bad and needs to be tossed away. But this is not the case. However over repeated use the braking surface does become a uniform silver color much as the braking surface on any other alloy rim.
If you use new brake pads and ride a new set of these rims only in the dry, the look should remain intact for quite a while. But these riding conditions are a tall order to ask. I would still pick these rims because of their unique grey looks, any day.
The proliferation of aftermarket, entry level wheels has somewhat altered the market situation with regards to handbuilts in recent times. Handbuilts done correctly are still great to ride. But you will find a number of aftermarket products in the 1650-1800g weight bracket which is also comparable in weight to a relatively conservative, yet high spec, 32hole hand build.
PostPosted: Sat Mar 24, 2012 2:07 pm
привет,
Don't expect the look and finish on this rim to last long in snow/grit/wet laden Москва. Especially in winter.
Can't see how the finish the rim caused you hassle, by any stretch of the imagination.
PostPosted: Sat Mar 24, 2012 2:55 pm
Hi H,
Did you used to ride these? if so how long exactly did they last you before the coating on the braking surface started showing signs of wear?
PostPosted: Sat Mar 24, 2012 3:15 pm
Of-course. But I can't give an answer as to how long exactly the grey look on the braking surface would last because each user and conditions are different. Some are heavy on equipment, others dependent on environmental conditions and others on brake usage. But if you read my post I've said all I can.
PostPosted: Sat Mar 24, 2012 3:21 pm
I built a set of OP CD rims on DA hubs.
After a couple of years the finish on the rear is still pretty much like new, but the front is starting to show signs of wear.
I have to add they were probably not used very much in wet conditions, and never raced for about 3000 miles.
(can't say for sure, haven't touched a clincher in two years or more)
PostPosted: Sat Mar 24, 2012 3:38 pm
I had cd rims for my mtb about 17 years ago and as I recall it took a couple of weeks before you could notice the wear
PostPosted: Sat Mar 24, 2012 8:15 pm
horse wrote:
привет,
I guess I messed somewhat with wording. I meant it was not worth the hassle for Mavic to produce those rims and for me to build myself a set of wheels with them.
On the flip side, Open Pros with Ceramic coating were great.
PostPosted: Sun Mar 25, 2012 12:06 am
My CD coating lasted 4 months with minimal wear.
One 60 minute circuit race in the rain took the coating off entirely. It was in the spring and the roads were still very sandy.
Users browsing this forum: adhumston, bratz, DC41, deek, dha, Google Adsense [Bot] and 75 guests
There are no new unread posts for this topic. Shimano 35mm carbon tubular rims as rims only ?
LouisN
Fri Jun 29, 2012 2:24 pm
LouisN View the latest post
There are no new unread posts for this topic. Mavic CXR 80
53x12
Fri Jun 15, 2012 11:49 am
wassertreter View the latest post
There are no new unread posts for this topic. HED c2 v.s. Mavic open pro
Kevin3182
20
1038
Mon Apr 08, 2013 1:51 am
garysol1 View the latest post
There are no new unread posts for this topic. Mavic CC SLR rim tape
fogflip
Mon Oct 29, 2012 6:39 pm
madmole View the latest post
There are no new unread posts for this topic. Mavic ccu decals
trilocus
7
729
Wed Oct 03, 2012 1:37 pm
ecguevara View the latest post
It is currently Thu May 23, 2013 4:24 pm
Mavic road bike & mountainbike rim - buy cheap Mavic carbon wheel
