Post new topic Reply to topic  [ 22 posts ]
Go to page Previous  1, 2
PostPosted: Mon Apr 02, 2012 9:28 pm
tanhalt wrote:
I got one hoping it would have a decent Crr due to the radial (almost) casing layout...but, alas, when I roller tested it, the results weren't good :(
Probably the rubber hairs aero drag slowing it down :lol:
If you do get to ride it outside I would like to hear what you think too. I just think they are definitely better than the rubino pro's.. and I didn't pay too much more for them.
PostPosted: Mon Apr 02, 2012 10:26 pm
That's sad... just how bad is it compared to others you've tested?
PostPosted: Mon Apr 02, 2012 10:37 pm
What pressure did you run them at for the test? Vittorias need a bit more air pressure so you might have been over flexing the side walls reducing the Crr.
signature deleted by the Admin.
PostPosted: Tue Apr 03, 2012 12:44 am
I don't recall the exact number (I can look it up later), but it was bad enough for me to relegate it to "commuter bike" usage :(
PostPosted: Tue Apr 03, 2012 12:45 am
I test at 120psi on the rollers (Kreitler 4.5" diameter).
PostPosted: Sun Nov 25, 2012 11:17 pm
Anybody used these on 23mm wide rims yet?
PostPosted: Mon Nov 26, 2012 8:56 am
Both on A23 and Hed Belgium wheelsets. Did not get the 22mm but the 24mm on 23mm rims measure out to be 27.87mm avg. with the calipers. I have also found out that riding with 70psi front and 75psi rear has been the best balance for my riding. I weigh 139lbs / 63~ish KG.
2012 Izalco Pro 2.0*Re-Grouped*
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Users browsing this forum: Google [Bot], Google Adsense [Bot], lionking, shimmeD and 37 guests
There are no new unread posts for this topic. Vittoria 2013 tyres
lactatehate
Wed Jan 30, 2013 4:19 am
HammerTime2 View the latest post
There are no new unread posts for this topic. Vittoria Corsa Evo SC opinions
wassertreter
Fri Jul 06, 2012 11:18 am
fdegrove View the latest post
There are no new unread posts for this topic. Vittoria Rubino Pro splitting
bcmf
14
728
Tue Aug 07, 2012 7:14 pm
bcmf View the latest post
There are no new unread posts for this topic. Vittoria Open Pavè 27mm
wassertreter
Tue Mar 26, 2013 2:29 pm
wassertreter View the latest post
wassertreter
15
1121
Sat May 18, 2013 8:23 pm
It is currently Wed May 22, 2013 7:18 am
