Post new topic Reply to topic  [ 4 posts ]
PostPosted: Fri Mar 23, 2012 4:27 am
So I'm building up a pair of 50mm carbon clinchers with a 3.5mm thick bed using 14mm Sapim aluminum nipples.
From what I've read, the Sapim nipples function just like a 12mm nipple so I don't need to adjust the spoke length for that.
-50mm carbon clincher 544 ERD
-14mm sapim aluminum nipple
-CX-Ray
-Front 20 spoke Radial and Rear 24 spoke 2x both sides.
-BikeHubStore SuperLight front (wide) and rear hub.
But here are the lengths that I am ending up with with the spoke calculator:
-Front: 258.1mm both sides
-Rear: 264.3mm NDS and 259.7mm DS.
What I'm worried about is spoke stretch.
Would I be okay with 258mm for the front (radial), 264mm NDS, and 260mm DS?
Many thanks!
Anthony
PostPosted: Fri Mar 23, 2012 2:01 pm
Your rounding will be fine as long as the measurements you supplied are accurate.
Enjoy the process.
PostPosted: Fri Mar 23, 2012 3:23 pm
Sapim spokes tend to be slightly shorter than their measured counterparts. So a 258 is closer to 257.5. You'll be fine with your rounding.
Fair Wheel Bikes
Fair Wheel Blog
Friend me on Facebook for behind the scenes updates
PostPosted: Fri Mar 23, 2012 9:14 pm
Like this wheels ?? https://picasaweb.google.com/1104808309 ... 3931369170" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
, I made :
hubs - BHS, rims ( light 360 g ) Hong Fu 50 mm, spokes Mac 424, nipples MAC alu 14 mm
front - 260
rear 258 / 262
Spoke tension max 100 kgf front and DS.
I think You can get also 258 front and 260/264 rear
profi wheelbuilder .......
http://picasaweb.google.com/110480830918110522375
Users browsing this forum: Bing [Bot], caballero, Ghost234, gospastic, Wookieopolis and 55 guests
There are no new unread posts for this topic. spoke length
thijsken
Sat Aug 18, 2012 9:10 pm
thijsken View the latest post
There are no new unread posts for this topic. Bontrager Aeolus 5 16/16 spoke vs newer model 18/24 spoke
reason
Wed Oct 10, 2012 8:17 am
reason View the latest post
There are no new unread posts for this topic. Chain length and new cassette
Frankie13
Fri Jun 22, 2012 12:46 am
Camilo View the latest post
There are no new unread posts for this topic. A crankarm length question...
veloflyte
21
868
Mon Jan 14, 2013 5:46 pm
Pantani View the latest post
There are no new unread posts for this topic. Sram chain length
neverwasbeen
10
412
Mon Feb 25, 2013 5:34 am
deek View the latest post
It is currently Wed Jun 19, 2013 5:10 am
