Post new topic Reply to topic  [ 7 posts ]
 Post subject: Sram Red shifter issue
PostPosted: Thu Mar 22, 2012 5:39 pm
Hi guys
Just pulled my bike out for the first spring ride but was let down by my trusty Red group.
The rear shifter will not keep its index which means it will pull cable put does not click and hold the cable. Any one tried this and what part do I need to replace?
Regards
Lars
Cannondaler
PostPosted: Fri Mar 23, 2012 11:33 am
They do not sell parts other than lever blades
Warranty or a new shifter
PostPosted: Fri Mar 23, 2012 12:47 pm
There are no more warranty.
Can it really be that Sram does not back up their top of the line group with spare parts? From campagnolo you can get any little spare part you want.
No more Sram for me then.
Cannondaler
PostPosted: Fri Mar 23, 2012 1:35 pm
My guess is that you just need to clean and lube the internal mechanism. It is not hard to do. If you pull up the hood on the shifter and look at the sides that face toward the wheel you will see a plastic cover plate held on by three small philips head screws. Use a jeweler's screwdriver to remove the screws and take off the plate. Once the plate is off you will be able to see the internal mechanism. You can use a q-tip and WD-40 to clean out any gunk on the mechanism. Then relube with light grease or oil. That should fix your problem if it is caused by dirty, hardened grease. You can also inspect the ratchet mechanism for wear at the same time.
Dave
PostPosted: Fri Mar 23, 2012 1:42 pm
I'm with djwalker on this: if it's not indexing, then the pawl's probably not reengaging the ratchet wheel inside the shifter, which is likely due to it being gummed up. It's a clever system once you're in there, so be sure to clean and grease all the surfaces that the pawl makes contact with.
Just a quick note: when putting the cover plate back on, be very careful to not overtorque the screws. They're threading into plastic, so they're easy to strip if you're not reasonably careful.
PostPosted: Fri Mar 23, 2012 3:47 pm
Thanks for the tips guys!
I'll be in the workshop tonight :-)
I'll let you know if it was successful :-)
Cannondaler
PostPosted: Fri Mar 23, 2012 11:26 pm
Worked like a charm :-)
Ready to rumble again!
Cannondaler
Users browsing this forum: corredor_x, Exabot [Bot], Google [Bot], thprice and 36 guests
There are no new unread posts for this topic. New SRAM Red shifter tuning
skywalker268
Wed Mar 06, 2013 7:21 am
prendrefeu View the latest post
There are no new unread posts for this topic. SRAM Red 2012 Shifter broken?
raiderr
Sat Aug 04, 2012 1:22 pm
ajh View the latest post
There are no new unread posts for this topic. Sram Red Front Der. shifting issue?
G6612
Fri Apr 12, 2013 5:28 pm
Hoodsanddrops View the latest post
There are no new unread posts for this topic. Source for shifter part?
seandonovan
Tue Jul 10, 2012 2:38 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Shimano Di2 R671 TT Shifter
alannmcl
7
566
Fri Feb 15, 2013 7:03 am
footwerx View the latest post
It is currently Fri May 24, 2013 10:48 am
SRAM Red crankset
