Post new topic Reply to topic  [ 39 posts ]
Go to page Previous  1, 2, 3
PostPosted: Tue Mar 20, 2012 3:24 am
CharlesM wrote:
Now if only there was a correlation between the .01% of people with the proper physio to ride professionally and the rest of us...
I don't know about that... I have average proportions and I'm right on the lines for saddle height and reach and 1cm lower for bar height. I think it's good info, regardless.
In this chart, reach is "the distance from the tip of the saddle to the center of the handlebar", and stack is "the distance from the center of the front wheel to top of handlebar".
My understanding is that "reach" is measured directly from the saddle tip to the handlebar (i.e., along the hypotenuse of the imaginary triangle), and "stack" is measured directly from the center of fork dropout to the top of the handlebar (again, along the hypotenuse).
F. Atalay
http://ft-atalay.blogspot.com/2012/03/pro-bike-fit.html
PostPosted: Tue Mar 20, 2012 1:45 pm
That's a pretty neat chart.
I'm well above average for saddle height - I have very long legs for someone might height - and am well below average reach. That makes sense, I think. If my torso is short for my height, my reach should be below average.
My flexibility also isn't so great.
PostPosted: Tue Mar 20, 2012 4:34 pm
I'm on spot with saddle height and reach but since I'm riding a frame one size bigger than what I could have so the headset is bit longer and the stack I ride is above average in 3cm. But I can still see according to the chart, marking of stack (green one) spread for riders like my height which ride above average same height like mine.
PostPosted: Wed Mar 21, 2012 8:54 am
You also have a longer TT which typically needs a shorter stem which tends to favor the weight distribution more rearwards than typically expected.
One more thing, on the chart previously posted, reach is measured from the tip of the saddle. IMO, this is a cause on its own for a deviation in results in reach as saddles come in different lengths for the same width, some pronounced as much as 1.5 cm., the SMP for example measures 27.8 cm long vs. the 26.5 cm of the Fizik, etc. I prefer measuring reach from the back of the saddle.
I find what this guy said spot on, specially the sentence about reducing power less:
eric wrote:
Set the saddle position for best power, then set the handle bar height and reach for aerodynamics and comfort.
For saddle position, the Lemond formula for seat height is a good starting point. Knee over pedal spindle is the traditional seat fore-aft position starting point but for road racers, 1-2cm behind KOPS is probably better. Slightly too low reduces power less than slightly too high, so err on the low side.
Reach and bar height are more a personal preference. It depends on your core strength, flexibility and how long you will spend in the saddle.
PostPosted: Wed Mar 21, 2012 9:59 am
can be more explained how to find the best power saddle position and what is KOPS.
PostPosted: Wed Mar 21, 2012 10:36 am
Answering OP's question is not that hard really (and I'm quoting Steve Hogg here).
Assuming your saddle height is correct --
Quote:
The drop should be so that in a 4h ride, you can comfortably ride the last 30min in the drops.
It really is as simple (and as open) as that. There is no way to calculate it, because it depends on more than just bike and rider measurements. If you can't rock the drops, readjust.
Bikes: Raceur, Beateur
PostPosted: Wed Mar 21, 2012 11:53 am
I have a formula that is spot on.
Shoe size in sidi= s
Number of digits on left hand= L
The day that your favorite classics race fell on in the year 2000= c
Number of recommended daily servings of fruit per day = f
Handlebar Drop= s/(L+f) - cL
Please note that if you are taller than 2m, then you must always substitute c for the R which equals the number of km of your longest ride / the average perceived effort of that ride on a scale of 1-10...where 1 is easy and 10 is hard. UNLESS you where riding a campagnolo equipped bike where the scale should be 1 - 11. :beerchug:
TIME RXR
PostPosted: Wed Mar 21, 2012 4:44 pm
Where do you measure the seat height from? for this chart.
PostPosted: Wed Mar 21, 2012 5:34 pm
I am pretty sure it is from center of BB to top of saddle, along the seat tube.
My Bikes
My Photoblog
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: Google [Bot], Google Adsense [Bot], HammerTime2, ichobi, Leroy424 and 60 guests
There are no new unread posts for this topic. Attachment(s) ISP saddle height adjustment
rgamble
15
1289
Wed Nov 21, 2012 3:03 pm
There are no new unread posts for this topic. Attachment(s) Tune Speedneedle owners out there!! Saddle Height? :) :)
Estuche
Mon Oct 08, 2012 5:37 pm
Estuche View the latest post
There are no new unread posts for this topic. Saddle height when changing crank length
guyken
Fri Sep 28, 2012 11:57 pm
theremery View the latest post
There are no new unread posts for this topic. LOOK 695 max seat height
DartanianX
Tue Dec 11, 2012 9:19 pm
OrPe View the latest post
There are no new unread posts for this topic. stack height on pedals
chippan
Thu Jul 19, 2012 5:51 am
Brandonnie View the latest post
It is currently Fri May 24, 2013 4:58 pm
