What's the recomanded difference between saddle height and h
toosahn
by toosahn
shinyboy wrote:Not really sure how this will help you but -
my saddle height is 81.5cm - handlebars are 16cm lower.
Whoa. That's a crazy drop!
yubbers
by yubbers
As other have said, go see a fitter. There's so many variables that come into play.
DO NOT look at pros for your set ups. Unless you're a carbon copy of their measurements and in the best shape of your life, you won't set up like a pro :)
wath
by wath
It really depends on your riding style. The lower you have the more aerodynamic you will be while the higher you have it the more comfortable you will be (generally). There is no "right" or wrong height, its basically a trade off between speed or comfort.
Or you can just jump on the bandwagon and slam it :mrgreen:
WasFab
by WasFab
SL58 wrote:It is really very simple: take a -17deg. stem and slam it. :lol:
what the 17 degrees stem related with the handlebar drop, can you explain?
saroadie
by saroadie
CharlesM wrote:there is no right answer for this.
Go see a fitter
+1.
This is an excellent response to the original post. Listen to the man.
Don't mess around with everyone's arbitrary answers to your question on this. They are surely only trying to help you, but comparing this measurement is totally dependant on the individual and nothing else. GO SEE A FITTER.
"Bite off more than you can chew, then chew like hell." Peter Brock.
CharlesM
by CharlesM
Seriously...
The ONLY other answer would be to find someone with your exact same body measures, flexibility, pedal stroke and personal injury past and age and fitness. And then it would be no better than a coin toss that you will want the same feel and have the same riding style.
Everything else but seeing a qualified fitter is bullsh!t.
dj97223
by dj97223
True, but in the meantime, we can all talk about whose "drop" is bigger.
shinyboy
by shinyboy
CharlesM wrote:Seriously...
Do you really believe sitting on a bike is so complicated that you need to hand over a wad of cash for some bloke to tell you how to do it :lol:
Look at how the people who push road bikes to their limits at the highest level set up their bikes and fit on their bikes. It's pretty consistent.
There is a fairly narrow range of hip angle that allows the glutes to work....road bike position is what it is because it works and any intelligent adult should be able to assimilate this to a position that works for them.
topflightpro
by topflightpro
Pez is correct.
And YES, there is a CORRECT answer for this.
The proper saddle height and position is determined by your leg length.
Your handlebar height then is determined by your hip flexion. Basically, you need to measure how much flexibility you have in your hips and then set the bar to a height that does not force you to exceed that level. Going past your flexibility can lead to pain in your hips and loss of power.
A fitter can give this to you.
Trying to gain the most aero position may result in less power and discomfort, and negating any aero benefit.
fa63
by fa63
shinyboy wrote:Do you really believe sitting on a bike is so complicated that you need to hand over a wad of cash for some bloke to tell you how to do it :lol:
I have been compiling published information on the fit of pro riders and their bikes for a while now. I just put up the results here:
http://ft-atalay.blogspot.com/2012/03/pro-bike-fit.html
As you can see, there seems to be a decent correlation between rider height vs. saddle height and "reach", but a poor correlation between rider height vs. "stack".
Besides this general observation, I will let everyone draw their own conclusions from this chart.
btompkins0112
by btompkins0112
:thumbup:
WasFab
by WasFab
what stack exactly stands for?
fa63
by fa63
If you look below the picture in the blog post (and also read the comments), there is an explanation of what stack means in those figures. But in short, it is an indication of how high the handlebar is.
CharlesM
by CharlesM
Now if only there was a correlation between the .01% of people with the proper physio to ride professionally and the rest of us...
And then there's all the things you don't see on a chart like cleat placement, saddle tilt etc.
And... the vast majority of pro's use both PT's and exceptionally well qualified fitters.
fa63
by fa63
Which is precisely why I said in my original post "I will let everyone draw their own conclusions from this chart". :D
In my case (1.83m), I get the following:
- 76.5cm saddle height (vs. 77.5cm indicated)
- 58cm reach (vs. 60.5cm indicated)
So the saddle height doesn't seem too far off, but the reach is. I could try to reason that pros like to ride lower and longer positions than average folks like myself, but I won't. I can also tell you I won't be tweaking my fit any time soon based on what it shown on those charts. So again, use at your own risk :D
