Post new topic Reply to topic  [ 20 posts ]
Go to page 1, 2  Next
PostPosted: Sun Mar 18, 2012 4:34 am
Hello
Just purchased a set of 2011 404's, does anyone here know if they should have come with pads? Were pads included with the wheels in 2011 or just in 2012?
Thanks!
PostPosted: Sun Mar 18, 2012 5:25 am
gitsome wrote:
Hello
Thanks!
Clinchers come with pads, no pads for tubulars
PostPosted: Sun Mar 18, 2012 1:51 pm
I use normal pads on mine all the time, bumf says it is fine.
Follow me on twitter:- MrAliBongo
PostPosted: Sun Mar 18, 2012 3:56 pm
got a set of tangente platinum pads with each of my 2012 303 fc clinchers
PostPosted: Sun Mar 18, 2012 4:43 pm
Mine did not, but I bought a 404 front and 808 rear, not a set so maybe that's why.
PostPosted: Sun Mar 18, 2012 5:55 pm
my wheels came in separate boxes, each with a plastic bag secured to each wheel, with rimstrip, valve extender, brake pads, and manual.
edit - but the front was missing stickers on one side, and i called zipp and they admitted it was a QC mistake, and are sending me some, so you should contact them first to see if they screwed the pooch on your pads too.
PostPosted: Sun Mar 18, 2012 6:11 pm
rambotan wrote:
gitsome wrote:
Hello
Thanks!
This is correct
PostPosted: Sun Mar 18, 2012 8:46 pm
jdp211 wrote:
rambotan wrote:
gitsome wrote:
Hello
Thanks!
This is correct
X2
@racecarbrian
PostPosted: Sun Mar 18, 2012 10:52 pm
Use only the recommended pads....dont use pads that you used for aluminum rims on your Zipp wheels. The regular pads are too strong for the carbon fiber wheels and will eat up the carbon fiber wheels. Also microscopic pieces of aluminum are left on the pads and this will definitely damage your zipp wheels.
PostPosted: Mon Mar 19, 2012 2:04 pm
ok Thanks everyone, I guess they left the pads out of my wheel accessories bag too, dealer said he'd give me some.
Also today (2 days of riding on them so far) I noticed the rear-wheel was shifting back-and-forth along the hub/axle between the cassette and the dropout on the opposite side. I can tighten up the hub-end I guess and screw it back close and then tighten a hex screw on it, but is this weird? Should I contact Zipp? QC issue or just bad mounting by mechanice at shop?
BTW fwiw, I love the wheels so far, really fast, stable and feel so nicely planted on the ground, very confidence-inspiring and fun to ride. Better performance than I'd expected, as good as I'd hoped. Hope the quality is there to match.
Let's all hope they stay that way
PostPosted: Mon Mar 19, 2012 3:21 pm
my hubs were a bit loose right out of the box too. they didn't need much tightening, but it made a definite difference in the sideplay. i expect them to need another small adjustment after the first few rides (like my last set of the old gen clinchers).
PostPosted: Mon Mar 19, 2012 4:13 pm
As a few others mentioned, definitely adjust/check the pre-load on the bearings. Zipp has a video on youtube of the process, very easy and you can tune it how you want.
My rear bearing adjustment was loose and the hex wasn't right at all. Wondered why my rear wheel was slopping around..haha.
PostPosted: Mon Mar 19, 2012 6:15 pm
Yeah thanks, saw that bit, a bit annoying to have to keep an eye on that tiny hex screw plus my hex seems to slip a bit so I'm worried about eventually stripping the head on that tiny bolt, Zipp toild me to tighten then back away a bit and lock it in by tightening the hex, but it seems they hub end is not in its "aero" position if I do this,seems minor but still sort of not into having to worry about this process repeating if it loosens up over time repatedly I guess time will tell. I'm used to Alchjemy which has been trouble free
PostPosted: Mon Mar 19, 2012 7:47 pm
When I bought mine, they came with a pair of cork pads...
Pascal
My Colnago C59 MTBK Camapgnolo Hyperon Ultra 2 and Campi SR11
http://rodebaron51.imgur.com/all/
PostPosted: Mon Mar 19, 2012 8:20 pm
rambotan wrote:
gitsome wrote:
Hello
Thanks!
That seems bizarre. While I'm not doubting the accuracy of your statement, why would clinchers come with pads and tubulars without pads?
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
Users browsing this forum: 1415chris, Google [Bot], Yahoo [Bot] and 45 guests
There are no new unread posts for this topic. Possibly replace rear Zipp - 303 or 404 question.
edesigner
Sat Nov 24, 2012 8:26 pm
edesigner View the latest post
There are no new unread posts for this topic. zipp 303 FCC Front / zipp 404 FCC Rear
jameskack
Mon Sep 10, 2012 8:10 pm
dmoneysworks View the latest post
There are no new unread posts for this topic. brand new Zipp 101 or used Zipp 303
zgundam
10
1395
Mon May 28, 2012 6:21 am
ticou View the latest post
There are no new unread posts for this topic. What would you pay for a 2011 Cervelo R3?
JKS
14
961
Mon Feb 11, 2013 7:20 pm
mattydubs View the latest post
There are no new unread posts for this topic. BMC 2011 SLR - which Hollowgram Crank & BB do I need?
dereksmalls
Mon Aug 06, 2012 7:19 am
dereksmalls View the latest post
It is currently Tue May 21, 2013 9:24 am
