Post new topic Reply to topic  [ 32 posts ]
Go to page Previous  1, 2, 3
PostPosted: Mon Apr 02, 2012 6:50 pm
Zachariah wrote:
Replace only if the tube walls gets too thin. Find out by removing the tube and inflating it to 40psi. If it looks like a snake just ate a football...then replace it. What happens is that the bubble can actually separate the tire bead from the rim, resulting in a catastrophic and suddenly random blowout. Ask me how I know....
The only purpose of the tube is to contain air. It is the tires responsibility to keep the tube contained. There is no way that a bubble in the tube could cause a tire to blow off the rim. A bubble might make it easier for the tube to work its way under the rim when mounting the tire or when pressure is low, but this is a maintenance problem, not an issue with the tube per se. A bubble might also weaken the tube, causing it to blow up, but in that case you would roll your tire, not have it blow off - there is a difference, though the result is the same - Body, I'd like you to meet pavement...
When I rode latex tubes, we would pull them yearly and coat them in powder to allow them to move freely and ensure they didn't stick to the inside of the tire. Might be worthwhile to do this when you pull your tires to true your wheels at the end/beginning of the season.
Cheers
1984 Ciocc Aquila 84 - SLX frame and full Campy Super Record
2006 Orbea Lobular - Aluminum and Carbon frame with Ultegra
PostPosted: Mon Apr 02, 2012 11:35 pm
Cheers
Thanks.....good info!
Due to the urging of all the ladies...I do NOT shave my legs!
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: Bing [Bot], CarpetFibre, euan, Google [Bot], stax, TiG and 51 guests
There are no new unread posts for this topic. Latex failure
Szczuldo
25
1736
Tue Oct 02, 2012 5:14 am
markyboy View the latest post
There are no new unread posts for this topic. Replace 130 mm axle for a 135 possible ?
LouisN
10
420
Mon Feb 25, 2013 10:26 pm
LouisN View the latest post
There are no new unread posts for this topic. DIY Di2 looking for my own connectors to replace Shimano. An
bartturner
Sat Feb 09, 2013 9:50 pm
bonafide View the latest post
There are no new unread posts for this topic. When to replace chain rings?
Rideuphill
14
987
Tue Mar 26, 2013 2:13 pm
sawyer View the latest post
There are no new unread posts for this topic. When do you replace your bike tires?
stevec1975
Wed Aug 22, 2012 3:55 pm
prendrefeu View the latest post
It is currently Thu May 23, 2013 7:58 am
