Look Keo Q Factor Washer?
billspreston
by billspreston
Anybody know of a source in the US where I can purchase these +2mm Look Q Factor washers? I've only been able to find them in shops across the pond. Thanks much.
rdy357
by rdy357
Tagged to see if anyone can find them in the US.
I will go check with my local shop this week if there are no replies.
Geoff
by Geoff
You don't need a special washer, any 2mm washer that fits will work.
Dcgriz
by Dcgriz
I've used regular washers on mine. Three on each side.
billspreston
by billspreston
Would prefer to use the Look ones if possible, but using standard pedal washers is certainly an option. Better than nothing I suppose. Find it odd that Look USA doesn't seem to stock these, I've emailed them with no response yet.
