Post new topic Reply to topic  [ 8 posts ]
 Post subject: campag rear gear
PostPosted: Fri Mar 16, 2012 11:29 pm
Having problems with my Campagnolo Chorus 11s rear gear
shifting up perfect from the small to the large, but
going back down not going into gear with every click
on some of the clicks takes an extra few secords before
chain moves down any ideas?
 Post subject: Re: campag rear gear
PostPosted: Fri Mar 16, 2012 11:36 pm
Cable friction issues.
Tight bends/binding, or maybe the ends of your liners aren't fully open and causing extra drag.
PostPosted: Sat Mar 17, 2012 1:49 am
As above....it's cable-drag.
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Sat Mar 17, 2012 4:08 am
Same as above.
Are you using original Campy cable set?
My C59 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=80193
PostPosted: Sat Mar 17, 2012 6:24 am
...in addition to possible cable issue you will also want to check the alignment of your rear der hanger. EM3
________________
My 2011 Cervelo R5
PostPosted: Sat Mar 17, 2012 6:49 am
Also check you have the cable going through exactly the right part of the fixing bolt / washer on the derailleur - a few years back the diagram in the manual was a bit confusing and if it is threaded wrongly the slightly altered angle of the cable as it exits the housing can create friction.
PostPosted: Sat Mar 17, 2012 7:47 pm
Cable friction.
Would more likely discount a bent derailleur hanger - happened to me last week and the chain tends to jump a lot on the cogs - has more trouble settling into a gear, if it does at all.
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Sun Mar 18, 2012 10:54 pm
Solved :D washer holding cable on wrong way around. Very poor diagram on the manuel
funny how a small thing like this can give so much hassle. Had taken a picture of this
before I moved to new frame but deleted it by mistake. Have had the cable on and
off a hundred times tried everything, now solved in 2 minutes
Thanks all
Users browsing this forum: Google Adsense [Bot], skowa and 49 guests
There are no new unread posts for this topic. Campag gear lever rattle
marathon50
Sun Aug 05, 2012 11:22 pm
ipenguinking View the latest post
There are no new unread posts for this topic. Campag SR11 Rear Derailleur problems.
Simonhi
9
680
Mon Jun 18, 2012 4:12 pm
Simonhi View the latest post
This topic is locked, you cannot edit posts or make further replies. Campag Record 10sp rear mech on 11sp set up
stuarts
Mon Feb 18, 2013 10:48 pm
stuarts View the latest post
There are no new unread posts for this topic. SL211 SuperLight rear hub / DA 7900 rear hub
headwind816
7
501
Fri Apr 19, 2013 9:59 pm
eric View the latest post
There are no new unread posts for this topic. What is the best gear ratio for my needs
Strekoza
Sun Feb 10, 2013 3:52 am
It is currently Sat May 25, 2013 12:09 pm
