Post new topic Reply to topic  [ 31 posts ]
Go to page 1, 2, 3  Next
PostPosted: Fri Mar 16, 2012 11:58 am
Hello
Im trying to mount some Vittoria Open Corsas on a new Soul S2 wheelset and am going through hell! That last few inches is impossibly tight that its impossible for me to roll it by hand (Something Ive never had a problem with on cheaper tires). I got one tire fully seated doing some questionable things with a plastic tire lever, but I paid for that by pinching a tube.
Any help would be greatly appreciated and ultimately me back on my bike! :-)
PostPosted: Fri Mar 16, 2012 12:18 pm
Pinch the already seated parts of the tyre with your hand, so it sits in the center of the rim bed. Often that gives the ever so slightly play needed for the final snap.
Bikes: Raceur, Beateur
PostPosted: Fri Mar 16, 2012 12:19 pm
Make sure the first bead is running in the centre of the rim. Use a thin rim tape. I've found that using some talcum powder or chalk on the rim and inside the tyre helps to lubricate things. Plus there's a few youtube videos where they show how to mount really tight tyres.
PostPosted: Fri Mar 16, 2012 12:37 pm
Above are great tips. Another is: rub a small amount of soapy water over the last section of the rim you're having trouble mounting. Saliva a reasonable field alternative for flats on the road. Helps slide the last bit of bead over. Also, try rolling the last bit of bead with your palm instead of thumbs. Much stronger.
PostPosted: Fri Mar 16, 2012 12:43 pm
My only tip is never use continental tires. I find vittoria are the easiest to mount while most continental tires are the most difficult.
Also I have heard but nit tried yet. Put the tire in an old pillow case and put in the dryer for a few minutes to warm before the initial installation.
Many times after the tire is on the rim for a while it stretches a bit and becomes easier the next time.
TIME RXR
PostPosted: Fri Mar 16, 2012 12:48 pm
Finally got the bugger on. Thanks for the tips. I am however now doubting this wheel / tire combo for training...if I get a flat I dont want to be on the side of the road straining and swearing for 20 minutes! I guess thats something I didnt consider when I was looking at wheels to replace my stock Fulcrum 7's. :roll:
PostPosted: Fri Mar 16, 2012 12:59 pm
the bead should stretch. My hutchison tubeless were a nightmare the first time i mounted them, but now they go on like any tire.
PostPosted: Fri Mar 16, 2012 1:03 pm
this and start at the valve and work your way around the outside of the tirefrom both ends so the part your jacking with is 180 degrees from the valve. It also helps to put just enough air in the tube to give it shape (like 3 pumps with a floor pump)
For the life of me I don't know how people pinch tubes, but I hear about it all the stinking time...
PostPosted: Fri Mar 16, 2012 2:32 pm
That is backwards. Start away from valve so the last part you are jacking is at the valve. If you start at the valve the tire can't sit down in the groove at the valve and it will have to stretch further. If you start away from the valve, the entire tire can set in the center grove while you pry the last 2 inches on at the valve.
For certain parts stiffer is more important than lighter.
PostPosted: Fri Mar 16, 2012 2:58 pm
I just lever them on. But I make sure the inner tube is pushed up on to the rim first, inside the tire, so that the lever doesn't pinch the tube. Then, don't get too "greedy" with the levering. Just a smal section at a time until it is on, so you don't have to insert much length of lever (risking biting the tube).
I like Contis specifically because they are hard to put on. I have rolled "easy" clinchers off the rim (they were michelins).
They do get a lot easier after the first time.
PostPosted: Fri Mar 16, 2012 3:23 pm
I lever mine on too. I also pinch the beads in so they're sitting in the center of the rim. For the valve, push the valve into the tire (not all the way of course) so you can get the beads all the way to the center.
To avoid pinching the tube, use the tire iron to stuff it up into the tire before you use the iron to lever the bead over, and go 1-2cm at a time.
Getting the tire warm by leaving it in the sun can also help.
PostPosted: Fri Mar 16, 2012 6:31 pm
I think mjduct had it correct. Start at the valve and finish opposite from the valve. Exception: on tubeless rims and tires, you want to finish at the valve.
PostPosted: Fri Mar 16, 2012 7:22 pm
I have this problem with new Gonti GP4000S on my Easton rims. They're an absolute nightmare to get on and off. I use some soapy water for the last bit.
PostPosted: Fri Mar 16, 2012 8:04 pm
10-15 seconds in microwave...works wonder; except when you're out on the road
PostPosted: Fri Mar 16, 2012 8:51 pm
Or you have wire beads...
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Alexa [Bot], bigkraig, Bing [Bot], bricky21, coppercook62, DaleRider, HammerTime2, Majestic-12 [Bot], MSN [Bot] and 59 guests
There are no new unread posts for this topic. Tips for mounting new Vittoria Open Evo CX clinchers.
jordo99
16
706
Thu Jun 14, 2012 4:59 pm
sawyer View the latest post
There are no new unread posts for this topic. EPS Under Saddle Mounting Option
Butcher
20
2325
Wed Sep 19, 2012 1:18 pm
phips View the latest post
There are no new unread posts for this topic. Mounting Garmin on TT bike
Kermithimself
13
662
Wed Apr 10, 2013 3:59 am
allenpg View the latest post
There are no new unread posts for this topic. Attachment(s) Mounting a Garmin 800 on Aero Bars?
joshf
12
1212
Mon Jan 21, 2013 11:39 pm
RaceWareDirect View the latest post
There are no new unread posts for this topic. Attachment(s) Di2 Remote Climbing Shifter mounting options
pawnii
20
1523
Fri Jun 01, 2012 12:08 am
WeightySteve View the latest post
It is currently Mon May 20, 2013 3:09 am
