Post new topic Reply to topic  [ 20 posts ]
Go to page Previous  1, 2
PostPosted: Sat Mar 17, 2012 11:49 pm
If you inflate it out of the tire you risk stretching only portions of the tube -- it can look a little bit like a balloon animal, if you know what I mean.
Here's my method: 1) put talc powder in a bag; 2) insert tube and shake to get entire tube covered with talc: 3) insert valve stem into rim; 4) put a few inches of the tube in on either side of the valve; 5) go to the side opposite the valve and put a few inches of tube in there; 6) alternate between valve side and other side -- this will distribute the tube rather evenly; 7) once fully within the tire and tire installed, inflate enough to see the tire start to take shape; 8) check under both tire beads to make sure there is no tube trapped under the bead; 9) inflate more, check to make sure nothing is pinched; 10) inflate to desired pressure and enjoy.
“Tuco” in The Good, The Bad and The Ugly, “If you save your breath I feel a man like you can manage it. And if you don't manage it, you'll die. Only slowly, very slowly old friend.”
PostPosted: Sun Mar 18, 2012 12:07 am
thanks just did it all went smooth. Beside the latex came new so they already powderd!
PostPosted: Sun Mar 18, 2012 3:12 am
Tubbie Guru
Hi,
Another aspect of using latex inner tubes that you have to keep in mind is that you also have to make sure not to stretch the tyre bead when mounting it.
Doing so may lead to inexplicable sudden explosions of the inner tube because it has found a pathway to leave its container...
And yes, 18-20 inner tubes only belong in a tyre of the corresponding size, i.e. from 18 to 20mm wide.
Not sure if this has been mentioned but when you do patch a latex inner tube, just degrease the punctured area with rubbing alcohol and use round latex patches you cut out from an old inner tube. No butyl and no squared edges please.
Ciao, ;)
PostPosted: Sun Mar 18, 2012 5:35 am
+1
This is the trick...same technique you should use for mounting ANY type of tube.
EM3
________________
My 2011 Cervelo R5
PostPosted: Mon Mar 19, 2012 10:16 am
Not to threadjack, related matter here: I have a GP Force/Attack combo and the Force is 24mm. Can I use 22-23 Michelin latex in them? Even butyl are not made specifically for 24mm, it's an odd size indeed.
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
Users browsing this forum: Exabot [Bot], Google Adsense [Bot], Kermithimself, Rob1519, RussellS, thatdkid, TrekUk, ttakata73 and 59 guests
There are no new unread posts for this topic. Need your help with the correct chainset for a pressfit BB
WasFab
Thu Jun 28, 2012 2:38 pm
WasFab View the latest post
There are no new unread posts for this topic. Latex failure
Szczuldo
25
1747
Tue Oct 02, 2012 5:14 am
markyboy View the latest post
There are no new unread posts for this topic. Latex tubes with Dura Ace 9000 c24 wheels
Horacio
7
901
Tue Jan 01, 2013 3:38 am
Horacio View the latest post
There are no new unread posts for this topic. TT fit - top tube
Kermithimself
14
711
Mon Aug 27, 2012 12:14 am
WMW View the latest post
There are no new unread posts for this topic. Shimano E-Tube with a Mac
Tamu8104
Sun Dec 16, 2012 4:20 am
Tamu8104 View the latest post
It is currently Sat May 25, 2013 8:57 pm
