Post new topic Reply to topic  [ 20 posts ]
Go to page 1, 2  Next
PostPosted: Thu Mar 15, 2012 9:18 pm
I have seen different sizes for latex tube both for road bike wheel (700C)
One size is 700X18-20C and other is 700X22-23C
So what's the better one or right one?
PostPosted: Thu Mar 15, 2012 9:27 pm
What size tires are you using? It'll be printed on the sidewall.
If you're using 19 or 20mm tires, then you'll want the 18-20C. If you're using 22 or 23, you'll want the 22-23C. Similarly for 25C and 28C tires.
PostPosted: Thu Mar 15, 2012 9:37 pm
Yes git it very true
By the way what the 3 figures stand for?
PostPosted: Thu Mar 15, 2012 9:47 pm
I use the 20 and 23 size tubes in my veloflex 22s no problems. I like the 20s ,easier to install. The 23 is baggy, you have to really watch it when fitting.
PostPosted: Thu Mar 15, 2012 9:50 pm
exactly because the latex is so soft when I installed it I pinched the tube. It looked to me as if the tube was too big for the tyre but I have 23c tyre (i think) so I don't know, I'll check it when I'm home!
PostPosted: Fri Mar 16, 2012 12:22 am
Yep very difficult to install imo, certainly need new coats of talcum powder every install because the tubes just stick to the tyre and scrunch up(without powder)
Focus Izalco Pro
PostPosted: Fri Mar 16, 2012 1:35 am
I didn't know that so you cover the tubes with talcum powder before installation?
PostPosted: Fri Mar 16, 2012 1:44 am
it isnt 100% needed but it does reduce the chance of pinch flatting and flatting due to stretching/stressing.
This is probably why most latex tubes all come with some amount of powder on them from the factory?
Focus Izalco Pro
PostPosted: Fri Mar 16, 2012 3:05 pm
If you're looking at Michelin latex tubes and running a 23c tire, you should get the 18-20c tube. Michelin tubes tend to run large and will leave a bunch of excess tube that you'll have to fold and stuff.
PostPosted: Fri Mar 16, 2012 4:19 pm
Very poor advice...you want to avoid over-stretching a latex tube (e.g, 18c tube in a 23-25c tire) in order to maximize the ride quality and insure maximum durability of the tube. Remember, you are not using latex tubes to save weight but rather for the ride quality and the increased durability (flat protection). The trick is to learn proper tire/tube mounting techniques with the slightly larger and more pliable latex tubes, and avoid using the smaller and incorrect size tube simply because its easier to mount.
EM3
________________
My 2011 Cervelo R5
PostPosted: Sat Mar 17, 2012 5:36 am
Yep, I lost $20 in 20 minutes by not taking my time installing my Mich latex tubes. Not to mention an elevated heart rate for a split second when I got the big bang.
PostPosted: Sat Mar 17, 2012 8:44 am
The good thing about latex is that you are able to patch them up. This depends on the severity of the pinch though (patchable when the flat looks like a puncture, not when it has exploded!)
Focus Izalco Pro
PostPosted: Sat Mar 17, 2012 1:32 pm
em3 wrote:
Very poor advice
I'm not the only person on this board that does this and as far as I know, nobody has suffered any ill effects from it.
PostPosted: Sat Mar 17, 2012 9:06 pm
EM3
so whats your trick?
PostPosted: Sat Mar 17, 2012 9:08 pm
Anyone can advice if it's a better technique to put the latex tube inside the tyre when you mount when it is a bit inflated? Maybe like 20-30psi?
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
Users browsing this forum: Google [Bot], HammerTime2 and 70 guests
There are no new unread posts for this topic. Need your help with the correct chainset for a pressfit BB
WasFab
Thu Jun 28, 2012 2:38 pm
WasFab View the latest post
There are no new unread posts for this topic. Latex failure
Szczuldo
25
1737
Tue Oct 02, 2012 5:14 am
markyboy View the latest post
There are no new unread posts for this topic. Latex tubes with Dura Ace 9000 c24 wheels
Horacio
7
893
Tue Jan 01, 2013 3:38 am
Horacio View the latest post
There are no new unread posts for this topic. TT fit - top tube
Kermithimself
14
708
Mon Aug 27, 2012 12:14 am
WMW View the latest post
There are no new unread posts for this topic. Shimano E-Tube with a Mac
Tamu8104
Sun Dec 16, 2012 4:20 am
Tamu8104 View the latest post
It is currently Thu May 23, 2013 7:26 pm
