Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Thu Mar 15, 2012 5:43 pm
As the title asks really; they're lightish in weight, good hubs and internals, some have asymmetric rims and decent spokes, plus a slightly wider (and in vogue?) rim, so are they anygood? Durable? Rider weight limit? Etc.
:noidea:
PostPosted: Thu Mar 15, 2012 11:45 pm
What? Nobody? :noidea:
PostPosted: Fri Mar 16, 2012 2:01 am
I have ridden the PSLR1 and I liked them better than my Hed Ardennes. They are basically DT Swiss wheels so great quality. The set I tried came in slightly above advertised at 1426g, compared to 1390 claimed.
PostPosted: Fri Mar 16, 2012 8:23 am
I haven't ridden them but the carbon clinchers with magnesium brake surface weight in at 1.8kg, about 200g more than claimed. Build looks solid though.
PostPosted: Fri Mar 16, 2012 10:14 am
Are they better ride than the Cosmic SL?
PostPosted: Fri Mar 16, 2012 1:07 pm
You mean like this???
PostPosted: Fri Mar 16, 2012 1:25 pm
PostPosted: Fri Mar 16, 2012 1:55 pm
Which wheelset are you referring to, since they don't have one with a Magnesium braking surface. The PSLR1 Aero which is the their carbon clincher is right in the neighborhood of claimed weights, since my LBS has a set in the shop.
PostPosted: Fri Mar 16, 2012 2:45 pm
Do the HED wheels have a wider rim than Giant wheels (23mm v 21mm)? If that's the case, how do Giants claims about running lower pressures, ride quality etc. compare to HED? Also what weight are you?
PostPosted: Sat Mar 17, 2012 2:02 am
The Hed is wider at 23mm, versus the Giant 21mm. I ride my Hed at a lower pressure as well, usually around 100psi and did the same with the Giants. I would like to get more time on them, but they just felt smoother on the road, and even though they are the same weight as the Heds, they felt more substantial in the hand. I weigh in at 175lbs.
PostPosted: Sat Mar 17, 2012 6:11 am
My mistake, it's a Scandium rim. It's the P-SLR1, my LBS weight it at around 1.8kg, hopefully their scale was wrong.
In any case, I just read that it lead an aero-wheel test in Cycling Weekly. I can't comment on the article, because I haven't read it.
http://www.giant-bicycles.com/en-gb/new ... est/15986/
PostPosted: Sat Mar 17, 2012 3:10 pm
fabiancanchelara wrote:
Giant road wheels. :wink:
PostPosted: Sat Mar 17, 2012 9:04 pm
aero?
PostPosted: Sat Mar 17, 2012 11:26 pm
My guess is no.
Sent from my ADR6400L using Tapatalk
PostPosted: Sun Mar 18, 2012 2:59 pm
I have a set of the P-SLR1. Came in at 1.450 grams, which was a bit disappointing compared to the claimed 1.390 grams. But aside from that I think they perform very well. Used to ride HED Ardennnes and I think the Giant wheels are as good or maybe a little better. Very even tension on the spokes, perfectly round, but you can however see that they are only 16 spokes in the front wheel. The hubs spin very smooth, but that was also expected due to the DT Swiss internals. I rode them for 1.400 km on a training camp in Spain and had no problem with them. Nice that you don't need rim tape.
Bring the mountains to Denmark!!
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], Google Adsense [Bot], renoracing, sanrensho and 52 guests
This topic is locked, you cannot edit posts or make further replies. Giant- The Truth About Road Frame Testing.
durianrider
Sun Nov 11, 2012 10:06 am
metal View the latest post
There are no new unread posts for this topic. Deep road wheels for every day use (70+mm)
Colnago68
28
2469
Mon Feb 11, 2013 10:11 am
Dozer View the latest post
There are no new unread posts for this topic. Bontrager Aeolus 5.0 D3 Clincher Road Wheels
kingkongsfinger
Thu Dec 13, 2012 4:28 pm
CharlesM View the latest post
There are no new unread posts for this topic. Road Bikes Disk Brakes/Carbon Wheels Dominant Future?
bluhorizan
10
1499
Tue Aug 21, 2012 1:04 am
kulivontot View the latest post
This topic is locked, you cannot edit posts or make further replies. carbon wheels VS alloy wheels
joe77bike
Fri Jul 06, 2012 5:55 am
Frankie - B View the latest post
It is currently Thu May 23, 2013 11:03 pm
