Post new topic Reply to topic  [ 5 posts ]
PostPosted: Tue Mar 13, 2012 2:30 pm
Newbie here looking for a little help. I'm building up my first bike from scratch and it looks like I should have done a little homework first. I've got a new 2011 S-works roubaix sl3 frame. The frame has a carbon shell where the BB goes that's 46mm dia. And about 62mm wide. I did not get any BB parts with the frame.
I ordered a "complete" BB for this frame from my Lbs. After waiting a couple weeks for it to come in I went to pick it up and they handed me 2 bearings. :? I asked where the rest of the BB was. At first they insisted that was it. I told them I thought it came with some bearing cups that locate the bearing at regular BB30 width. They did not have the cups (I ordered them). They told me that the cups do not space out the bearings past the 62mm width. Is this true? Is there any way to mount my already purchased cannondale crankset on this frame without a bunch of really thick spacers? My lbs suggested I buy the s-works crankset but I'd like to run the cannondale because it's lighter and I already own it.
PostPosted: Tue Mar 13, 2012 3:39 pm
so a 46mm shell means press-fit 30, no? so you should've gotten more than just the 2 BB30 bearings. I don't know Specialized too well and what's up with their skinnier width 62mm shell but the 46mm diameter is PF30
PostPosted: Tue Mar 13, 2012 4:08 pm
Your frame should have come with the required nylon cups. OSBB is similar to pressfit where the BB30 bearings press into cups which press into the frame.
The cups do have a "lip" to them to space the BB to the required BB30 width.
If you bought the frame from the shop you are dealing with they owe you a set of cups for the OSBB. Once you have those cups everything installs as normal for a BB30 crankset.
As you can see from my post made about installing my Zipp crankset thew nylon cups have a lip to space the bb to the correct width.
crohnsy wrote:
Still waiting on a few more parts but I have the cranks installed!
The Zipp distributor in Canada didn't bring in the BB30 adapters so I made my own as seen here.
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Wed Mar 14, 2012 1:01 am
as mentioned, Specialized carbon OSBB is NOT pf30. it is 46mm in diameter, but it is narrower overall. the specialized cups (that should have come with your frame) take the frame to 68mm and the i.d. to 42mm, essetially making it bb30. after that, all is straightforward.
the cups are cheap, but require a call from a specialized dealer to their inside rep, as their online ordering system does not list that part separately.
PostPosted: Wed Mar 14, 2012 2:35 am
Thanks guys. I guess I'll just wait for the cups. Love the project yellow!
Users browsing this forum: ewwhite, Ritterview, wshiong and 42 guests
There are no new unread posts for this topic. s works crankset
cymans
9
1146
Thu Apr 04, 2013 3:25 am
Gearhead65 View the latest post
There are no new unread posts for this topic. BB30 crankset on S-Works OSBB
sawyer
Wed Mar 20, 2013 10:19 am
londoncommuter View the latest post
There are no new unread posts for this topic. Best Crankset for Cannondale EVO build?
bluhorizan
15
1760
Sat Jul 21, 2012 3:47 pm
eliflap-scalpel View the latest post
There are no new unread posts for this topic. Cannondale Hollowgram SL crankset on other bikes
poppiholla
9
918
Tue Feb 19, 2013 5:02 am
Buffalo View the latest post
This topic is locked, you cannot edit posts or make further replies. Attachment(s) S-WORKS Venge or S-WORKS Tarmac SL4
elliott123
Wed Feb 13, 2013 4:38 pm
elliott123 View the latest post
It is currently Wed Jun 19, 2013 6:51 am
