Post new topic Reply to topic  [ 6 posts ]
PostPosted: Tue Mar 13, 2012 12:24 pm
I'll very likely be wanting to build up a bike with the following:
Kuota Kharma frame
Chris King BB - one of these: http://chrisking.com/bottombrackets/bottom_bracket
Campagnolo Centaur Ultra-Torque 10-speed drivetrain
As I need both a compact chainset and one that works with CK, I'm going to have to toss my current standard UT chainset/BB cups in favour of a CK compatible one (24mm crank spindles) - question is, what compact chainset options do I have that will be compatible with both the CK BB and a Campag 10-speed chain?
TIA
Mike
PostPosted: Tue Mar 13, 2012 12:41 pm
Rotor?
I am here: http://tapatalk.com/map.php?exbner
"Stay cool and try to survive" A. Klier to the other members of the Garmin classics squad the night before P-R.
PostPosted: Tue Mar 13, 2012 12:53 pm
If you use Stronglight 10/11s speed rings, you can use any 130bcd crank out there. Of the decent 24mm ones, there's Rotor, FSA, Shimano and others.
Don't be alarmed.
PostPosted: Tue Mar 13, 2012 11:38 pm
Thanks, so basically something like an FSA Gossamer Pro MegaExo Compact Chainset would be compatible with the CK BB, but not with the Campag chain? I'd need to fit something like the Stronglight Dural 5083 110mm Shim 9/10 Chainring to the FSA chainset in order for the Campag chain to work?
...or is it the Stronglight Zicral 7075 110mm Camp 9/10 Chainrings?
PostPosted: Mon May 14, 2012 10:00 am
From what I can see, you can use a FSA Gossamer SRM with a CK BB? Would that be correct?
What about the k-force light?
PostPosted: Mon May 14, 2012 11:10 am
I can't guarantee it, but you may be able to get the CK to work on the UT cranks.
I run a CK ceramic on my track bike, on the NDS there is a sleeve that converts the 25mm bearing to the 24mm on the Omnium cranks I use. I don't see why running this both DS and NDS wouldn't work ok. It runs perfectly fine on my track bike and spins nice, no complaints from me. YMMV.
Users browsing this forum: Bing [Bot], deermatt, HammerTime2 and 48 guests
There are no new unread posts for this topic. Chris King New Bottom Brackets - Where to buy
vladt
Sun Mar 24, 2013 4:31 am
jimh View the latest post
There are no new unread posts for this topic. Enve Compression Plug + Chris King Top Cap?
iamalex
Sun Mar 17, 2013 8:18 am
iamalex View the latest post
There are no new unread posts for this topic. King or Tune?
milroy
19
1409
Fri Aug 03, 2012 2:00 pm
nspace View the latest post
There are no new unread posts for this topic. De Rosa King RS
TheCannibal
Wed Jul 11, 2012 10:24 am
TheCannibal View the latest post
There are no new unread posts for this topic. Oh boy... De Rosa King 3 RS
ronaldo
Sat Oct 13, 2012 9:43 pm
ronaldo View the latest post
It is currently Sat May 25, 2013 2:52 pm
Chris King hubs & headsets - buy cheap Chris King bottom brackets
