Post new topic Reply to topic  [ 100 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: New Hollowgram
PostPosted: Tue Jun 19, 2012 10:35 pm
Pricing point?
Pegoretti Responsorium
Parlee Z5i
Donhou Commuter
PostPosted: Tue Jun 19, 2012 10:37 pm
Formerly known as CAADHEAD
Lol don't spoil it!
Ti or dye!
PostPosted: Tue Jun 19, 2012 10:44 pm
I'm so glad I finally bought myself some SLs this spring. :doh:
PostPosted: Tue Jun 19, 2012 10:57 pm
Hopefully they do something more with the alternate spider-but the integrated one looks fantastic. To my untrained eye the arms look pretty similar, maybe a bit different around the axle end.
How much does a SISL1 set weigh?
I hope you can use the new arms and axle with the standard spider.
Either way - I want!
signature deleted by the Admin.
 Post subject: New Hollowgram
PostPosted: Tue Jun 19, 2012 11:01 pm
If only my CAAD9 was BB30... maybe I can bore it out...? :beerchug: I hope they do a MTB version but it'd be a pain in the arse to clean.
--Max.
PostPosted: Tue Jun 19, 2012 11:28 pm
As someone who loves his SiSL, I don't see a lot that would make me upgrade. But that's mostly because I run a 52/36. I reserve the right to change my mind as more info comes out, but if you can't run a normal 130 or 110 spider on the SiSL2, that's a deal breaker for me.
Granted this is only one short write-up from one source, but I'm surprised that no one has mentioned the glaring potential lack of compatibility with quarq and SRM. Does anyone --*AHEM* paging starnut-- have any more info?
-efwd
PostPosted: Tue Jun 19, 2012 11:38 pm
Dumb. I'd rather have the ability to change my chainrings and it won't really matter for anyone that uses a SRM, rotor rings, tt rings, etc.
I look forwarding to buying second hand SISLs though once this hits and people haaaave to get them.
PostPosted: Tue Jun 19, 2012 11:41 pm
http://weightweenies.starbike.com/forum/viewtopic.php?f=14&t=67162&hilit=hollowgram
The Hollowgram SISL weighs ~570g all in for a compact crank. That is with crank arms, spider, MK V chainrings, spindle, bearings, crank arm bolts, bearing shields, spacer...etc.
The 484g in the quoted article is for spidering, SiSL2 cranks arms, bolts and spindle. So not a 100% accurate comparison.
For SISL:
SISL crank arm bolts= 15g
SISL spindle= ~60g
Equals: SISL @ 498g compared to SISL2 @ 484g.
Throw in the BB30 bearings, bearing shields and spacers and you get the SISL to 571g of the initial picture posted above.
Now if the new SISL2 includes the BB30 bearings at the weight of 484g, then it is quite impressive. However at the moment it looks like it might be around a 15-20g difference.
"Let's plunge ourselves into the roar of time, the whirl of accident; may pain and pleasure, success and failure, shift as they will -- it's only action that can make a man."
PostPosted: Wed Jun 20, 2012 12:08 am
Looks like a BMX crank to me!
The 609g forged version seems somewhat exciting depending on pricing. I'd expect it to be a lot cheaeper, but we'll see.
PostPosted: Wed Jun 20, 2012 12:28 am
"The 609g forged version seems somewhat exciting depending on pricing. I'd expect it to be a lot cheaeper, but we'll see."
As this is WW, that is heavier than the SISL version. Might be slightly "stiffer" per the article. But the SISL itself is quite stiff. Never heard anyone complain that they wished it was stiffer. Plus the current Hollowgram gives you the option to easily convert from compact to standard and from road to MTB.
PostPosted: Wed Jun 20, 2012 1:05 am
Since it sounds like the spidering is one piece, separate from the arms, I suspect you will still be able to use Si/SL spiders and power meters with the new arms and spindle. The spidering isn't the only improvement. The arms and spindle are lighter and stiffer as well.
Quote:
Their new SiSL2 cranksets are 100% CNC machined in a clamshell design that’s bonded together. The spindle has been machined down more, too, which also made it stiffer. This model has additional machining to save weight, and the remaining material was move around inside the arms to improve the strength. So, these are both lighter and stiffer.
PostPosted: Wed Jun 20, 2012 2:08 am
thats it! i was trying to think where i had seen it before, BMX
that spider is very ugly
PostPosted: Wed Jun 20, 2012 5:56 am
So forgive my ignorance on this, what happens if you bust off a tooth somehow on either of the chainrings or when one get sowrn down more than the other and needs replacing? What do you do? Replace the entire sing,spider and crank? Or just the rings and spider or what? It's 4:55pm at work, my brain is fried and not thinking clear so someone explain the advantage other than stiffness and weightloss?
PostPosted: Wed Jun 20, 2012 6:34 am
^ The spidering is one piece from my understanding. So once the chainrings are worn you have to replace the spidering since they are machined from one piece of aluminum. No need to change crank arms.
So really the "benefit" is slightly less weight (will need to wait until pics of it on a scale) and the increased stiffness.
PostPosted: Wed Jun 20, 2012 7:26 am
Don't know if I like it that much........
Powermeter option is sort of gone with this one......
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
Post new topic Reply to topic  [ 100 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Users browsing this forum: CarpetFibre, dalex and 50 guests
There are no new unread posts for this topic. hollowgram srm hours
paulclay
20
1117
Thu Feb 14, 2013 9:54 am
Dammit View the latest post
There are no new unread posts for this topic. Hollowgram sl on super 6 evo
logy
Wed Dec 12, 2012 7:27 am
There are no new unread posts for this topic. New Hollowgram Spidering
quaman26
Sat Oct 13, 2012 7:26 pm
VNTech View the latest post
There are no new unread posts for this topic. Advice on Hollowgram set up
quaman26
13
670
Wed Jun 13, 2012 4:29 am
There are no new unread posts for this topic. Hollowgram vs. Exogram
timzcat
Sat Sep 01, 2012 8:54 am
logy View the latest post
It is currently Wed May 22, 2013 12:14 pm
