Post new topic Reply to topic  [ 3 posts ]
 Post subject: DA-7900 RD limit screw
PostPosted: Mon Mar 12, 2012 7:20 pm
Just thought this was a little strange.
I opened a new in box RD-7900, bolted it on, no cable yet.
the High limit screw came about half way backed out from the factory. and it is sitting below the 4th cog. I had to back out a few more turns to get it to sit on the smallest cog. The hanger is not bent.
Is this quite normal? On SRAM I could only get to 2nd cog with the screw turned in. My guess is Shimano thinks if my shifter or cable broke, I can select probably any gear to ride home.
PostPosted: Mon Mar 12, 2012 7:40 pm
More range means the rear derailleur can accomodate a variety of dropout thicknesses, but presumably SRAM has enough and Shimano's is overkill.
Maybe it is for juniors and cadets so they can block out the big gears easily?
PostPosted: Mon Mar 12, 2012 8:09 pm
typically, shimano derailleurs arrive out of the box with the limit screws set about two gears in- 3rd hardest and 3rd easiest. so yours is within reason.
Users browsing this forum: Bing [Bot], HammerTime2, jpap, racermech, tommasini, Yahoo [Bot] and 42 guests
There are no new unread posts for this topic. Screw length for Sidi SP sole?
ipaul
Mon Feb 25, 2013 2:38 am
ipaul View the latest post
There are no new unread posts for this topic. My Time stem screw broke. Help!
phourgenres
Thu Apr 18, 2013 1:47 pm
Tenlegs View the latest post
There are no new unread posts for this topic. Easton EC90 fork headset cap screw/spring/washers necessary?
timj
Thu Aug 16, 2012 9:16 am
timj View the latest post
There are no new unread posts for this topic. Attachment(s) What is the caad10's limit?
Brandonnie
15
2149
Fri Jul 20, 2012 4:39 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Sram Limit Screws
Garret C
Thu Jun 21, 2012 6:24 pm
Camilo View the latest post
It is currently Sat May 25, 2013 2:04 pm
