Post new topic Reply to topic  [ 28 posts ]
Go to page Previous  1, 2
PostPosted: Sat Mar 10, 2012 6:46 am
If brakes are no concern, Id use some kind of MTB trigger shifter and some narrow track drop bars. I like strange project bikes like this, looking forward to seeing what you come up with!
PostPosted: Sat Mar 10, 2012 9:04 am
User cmh has a pretty cool hill climb bike:
viewtopic.php?f=10&t=97416&start=0
8)
PostPosted: Sun Mar 11, 2012 12:15 am
There are lots of cool things that you could do if you have some time. The older FSA carbon cranks have a removable spider which would allow you to run a spiderless chainring in what ever size you want. You could have a pretty cool crank set. You could also do what others have said and set up your rear derailleur to run a few cogs on the back. You could use carbon spacers to space it out to the right chain line. I have done all of these things in the past and Fibre-Lyte were great to work with in sorting out the details. They even made me some 16t cogs for some single speed projects.
Looking at the link to the Scott build, you could lighten that up a fair bit. Also running a Berk saddle/post combo could keep the weight down. Do you have to run drop bars on the bike. The only reason I ask is that you could run a bullhorn set up with the shifter in the end of the right side for shifting and if you need 1 brake could have a vison lever in the other side at 35g.
So there is potential to do up a stupid light build. For hill climb bikes that do not have to follow any set rules, I honestly do not know why people run drop bars with heavy shifter/brake levers.
I have a lot of ideas for a killer hill climb bike but no funds to make one.
I do a lot of climbing where I live on the west coast and one a single speed builds I have used in the past a 32t upfront and a 16 on the back has allowed me to climb some big hills. If I was to gear it I would run individual cogs something like this. 15,17,19,21,23,25 and just have them spaced out on the wheels for a good chainline.
Maybe run Sram and tune the RD to around 110g easy, shifter are only 69g, KCNC brake is 68g front and i could go on.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Sun Mar 11, 2012 2:02 am
dparker wrote:
I participate in the Mt. Washington Auto Road Hill Climb each year - 7.6 miles at an average gradient of 12% (22% for the last 100 feet, which is mean). At 12%, a 1% drop in total weight (bike plus rider plus stuff) translates to a 1% increase in speed - in other words, gravity provides 100% of the resistance.
So, given that I'm already so skinny my wife would kill me if I lost any weight, and that this race is really my only one each year - I train for it exclusively through the spring and summer, and finally that I'm turning 50 with in a year, and want to treat myself to something really silly - I thought of putting together a crazy light bike just for this race. And I don't want to buy anything new for it - just very light used stuff, so it shouldn't cost too much.
So here's what I'm thinking: I buy a used super light frame (maybe a Scott CR1 Limited?) and then turn it into a minimalist single speed, with no derailleurs, no brakes, tubular tires on super light rims, and shortened handlebars.
What do you think? Could I get down to 8 or 9 pounds total? Is it hard to use a standard carbon frame as a single speed - should I replace the dropouts so they're more horizontal?
Thanks
David
Hi dparker, sounds like fun. I am a little older than you, but much heavier, and there is a ride I like doing from Samford to Mt Glorious in Brisbane. It's about 6kms of climbing of which the last 2kms average 15% (the motorbikes like coming down this road). I have set my bike up just for this ride still using a standard crankset but with an 11-36T cassette and XTR RD. This gives me 39/36 if required and it always is towards the top.
So, what am I suggesting ... that you use a double or triple crankset (probably what you have already), with a single ??T sprocket (to give the equivalent of 34/34 gearing or lower 22(F)/24(R)) and a nexus or alfine chain tensioner (or simply use your current RD set to the single sprocket but I think it will be heavier). This will allow you to use the front chainrings as your gear change mechanism.
What do you think ...
PostPosted: Sun Mar 11, 2012 2:08 am
HEAVY SUGGESTION!
BIG DADDY B FLOW
PostPosted: Mon Mar 12, 2012 7:44 pm
Carbon EVERTHING! You can use vertical dropouts with a White ENO hub to make a single speed, but I think it would be better to go with Harrys's comment of a 1x something. Depending on direction the wind is blowing you could need a couple of teeth up or down. I would go with an aluminum 10 speed cassette and a downtube shifter. The Bullhorn bar setup sounds good as well. I did some quick math and came up with about 3630 grams / 8.00 lbs as a realistic target. This sounds like a fun project!
PostPosted: Tue Mar 13, 2012 1:42 am
Well for sh1ts and giggles I thought I would put together my Giant TCR Zero aluminum frame with Easton EC90SL forks on a hill climbing diet since it is in pieces already and built it up with Syntace basebar and stem, FSA carbon crank with 32t Spiderless chainring, EDGE 45 clinchers, Thomson Masterpiece, Fizik Arione Carbon, Sram TT500 rear shifter, KCNC 11/23 rear cassette and KMC X10sl chain with stock X2's and it came in at 11 lbs.
I think it would climb amazingly well and I like the hand position which reminds me of climbing on my MTB with the bar ends.
The frame is 1080g and the forks are about 324g, wheels are 1282g, tires are 164g each, tubes are latex, cassette is 110g, Sram Force RD tuned with carbon cages and pulleys, skewers were Omni racer as well as seat clamp. Masterpiece 31.6 post with carbon cradle, Fizik Arione carbon. Syntace stem is about 94g and the basebar has upturn cut so about 224g. Chain was full length for my standard set up so I could remove some links for sure.
This is going to be my trainer bike for now but with different wheels and I will add a front brake for those times I need to ride a 12.5lbs bike to the store. The lock will weigh more.
BIG DADDY B FLOW
PostPosted: Tue Mar 13, 2012 11:24 pm
styrrell wrote:
Not sure if this is Kosher, but i have an old set of sub 1200 gm wheels (actaul weight, no tires cassette, qr, just under 1200 gms by a few gm, tubular /shimano compatible) that I will let go cheap.
smtyrrell99 at yahoo.com
5 dollars, that's my final offer. If I'm not mistaking, a year or two ago, the Mt Washington hill climb was won by a weightweenie with a R3SL
PostPosted: Tue Mar 13, 2012 11:30 pm
Word:
(image is link to VeloNews article)
Exp001
PostPosted: Tue Mar 13, 2012 11:32 pm
Yes, indeedy. viewtopic.php?f=3&t=76357#p673292
PostPosted: Mon Apr 16, 2012 3:10 am
Sounds like a fun build! I'd like to do something similar but not quite as extreme (would keep brakes for descending). I think 10-speed spaced rear cassete using every other gear (something like 11,13,15,19,25,28) with a single front ring would be pretty versatile. So what's a good cheap crankset that would be light and easy to convert to 1x?
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Mon Apr 16, 2012 2:05 pm
Have you considered using flat bars w/ bar ends? Very easy to get a ~100g flat bar, but if you're running brakeless, the position would work better. You wouldn't need to put dummy hoods on it.
PostPosted: Mon Apr 16, 2012 3:02 pm
If you are creative there are lots of light weight options. Like mentioned you could use a flat bar sub 100g, barends 50g, grip shift for the rear, tuned RD and if you do want to use a brake just use something like a cross lever for the front brake.
BIG DADDY B FLOW
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
Users browsing this forum: 6mt, Google Adsense [Bot], robertg, shimmeD and 58 guests
There are no new unread posts for this topic. Lets create something
compositesss
31
1892
Tue Mar 19, 2013 11:49 am
BobDopolina View the latest post
There are no new unread posts for this topic. Anyone create their own Di2 connectors?
bartturner
Fri Apr 26, 2013 11:58 pm
goodboyr View the latest post
There are no new unread posts for this topic. Attachment(s) Exustar Pro carbon Ti pedal (with picts)-SUPER light!
Bianchi10
19
2626
Fri Oct 26, 2012 9:11 am
Kasparz View the latest post
There are no new unread posts for this topic. FSA K Force Light Wilier BB386Evo vs Campy Super Record Crnk
Berlingtonberty
Fri Nov 30, 2012 5:50 pm
Briscoelab View the latest post
There are no new unread posts for this topic. Zipp 303 for climbing?
project3
31
3415
Thu Sep 27, 2012 6:29 am
notsoswift View the latest post
It is currently Tue May 21, 2013 3:23 am
