Lightweight Meilenstein
WeightySteve
by WeightySteve
Andreas, so what age do 'current' Standard C's stretch to?
Like if you bought them from LBS January 2012 you would have wheels made in 2011 for sure, but if you bought them March, maybe you got wheels that were stored in the shop or your production store for 2 months and so they are from 2011. Or maybe they were made to order and indeed 'current'?
I realise gradual improvements took original Standard C's to where they are now, but how do we identify one Standard C from another? Chip Number ranges perhaps?
CarbonSportsGmbH
by CarbonSportsGmbH
As we always produce "on order", it only depends on shipping and dealers stock how old or new the wheels are that you can see in a shop.
To have a detailed differentiation we have to look in our database, where we can see all specific details on a wheel. This only works via the chipnumber (which is not consecutive!).
For a global differentiation between "old" Standard C" (produced up to ~Dec. 2011) and current Standard C / Meilenstein C please have a look on the pictures...
"old" Standard C
Andreas Schiwy, CarbonSports GmbH
http://www.lightweight.info
support[at]lightweight.info
WeightySteve
by WeightySteve
Thank You Andreas for all your posts in this thread. It has been very reassuring having such a responsive (& suprisingly public) contact throughout my queries both pre, mid and post sales.
trisilver57, hope you get sorted out soon, seems the US to Europe link is the problem here because as you can see CS themselves are very supportive. During the timeline of this thread, I have also returned and had re-posted back one of the wheels for inspection (there was nothing wrong with it, I just wanted to be sure about a query). This process took about a week, from original collection (which CS arranged) back to delivery to my door.
Ulle
by Ulle
@ Carbonsports GmbH
Can you post a picture of Mailenstein's big logo on the new wheels? I would like to see the new graphic closer because I can't decide between the new graphic stile and the old one.
Thank You :beerchug:
J-Nice
by J-Nice
Is there a price listed posted anywhere for the new Carbonsports wheel models?
Also, are there any plans in the works to make the rim width any wider than 19.5mm, as it seems to be the new thing to do nowadays?
Check out the latest controversies in sport-
http://berzin.blogspot.com/
Ulle
by Ulle
New Meilenstein Tubular:
20mm rim width
47,5mm rim depth
100kg weight limit
"Old" Standard III
19,5mm rim width
53mm rim depth
120kg weight limit
Is that correct?
Why the decreasing weight limit?
Thanks :beerchug:
CarbonSportsGmbH
by CarbonSportsGmbH
Ulle wrote:New Meilenstein Tubular:
20mm rim width
47,5mm rim depth
100kg weight limit
"Old" Standard III
19,5mm rim width
53mm rim depth
120kg weight limit
Is that correct?
Thanks :beerchug:
Semi-correct... :wink:
You forgot to compare the matching spokes counts and/or mixed up the types tubular and clincher:
Tubular:
Standard III 16/20: 100kg <=> Meilenstein 16/20: 100kg
Standard III 20/20: 120kg <=> Meilenstein 20/20: 120kg
Rim: 53mm <=> 53mm
Clincher:
Standard III C 16/20: 120kg <=> Meilenstein C 16/20: 120kg
Standard III C 20/20: 120kg <=> Meilenstein C 20/20: 120kg
Rim: 47,5mm <=> 47,5mm
=> no decreasing weight limit! (Which would be nonsense...the wheels are technically identical! Only the clincher models got a technical update, starting with production end of November 2011. Shape was not modified!)
Ulle
by Ulle
CarbonSportsGmbH wrote:Semi-correct... :wink:
Tubular:
Rim: 53mm <=> 53mm
Clincher:
I found this at lighweight.info :noidea:
Berk
Carbon Cowboy
by Berk
Updated Meilenstein Tubulars - with 47.5mm?
http://www.bikerumor.com/2012/08/18/lig ... -tubulars/" onclick="window.open(this.href);return false;
They also lowered the overall rim height top 47.5mm (down from 53mm).
:noidea:
Tubular:
Rim: 53mm <=> 53mm
Clincher:
Berk PROTO-TYPE Composites - Handmade In Slovenia
Berk Composites
http://www.berk-composites.com/
info(a)berk-composites.com
CarbonSportsGmbH
by CarbonSportsGmbH
Tubular:
Rim: 53mm <=> 53mm
Ahh..now I see the problem. I did not recognize you refer to the news that was posted e.g. at bikerumor.com... sorry for that!
So I have to correct myself:
Tubular:
Standard III 16/20: 100kg <=> Meilenstein III 16/20: 100kg <=> Meilenstein (MY2013) 16/20: 100kg
Standard III 20/20: 120kg <=> Meilenstein III 20/20: 120kg <=> Meilenstein (MY2013) 20/20: 120kg
Rim: 53mm <=> 53mm <=> 47,5
But: still no decreased weight limit! :wink:
reggiebaseball
by reggiebaseball
So when are the MY2013 wheels available? Or are they already shipping now?
What should we specify with our dealer when ordering if we want to ensure we get the MY2013?
thanks!
CarbonSportsGmbH
by CarbonSportsGmbH
Production will start shortly after Eurobike 2012. When ordering, just be sure to order "Gen. IV" or MY2013...
HammerTime2
by HammerTime2
Is there going to be a Gen. IV GIPFELSTURM? If so, what will be the differences from the Gen. III GIPFELSTURM?
WeightySteve
by WeightySteve
Is there a MY2013 Meilenstein (C) on the way too, or is the current Meilenstein (C) ( which is <=> December 2011 onwards Standard III C's ) the latest gen clincher for the forseeable future?
I ask because Bikerumor says MY2013's will support 11s, but no news (that I have seen) about current wheels supporting (or accepting new freehub bodies to accept) CS 9000 cassettes.
Ulle
by Ulle
"The Meilenstein gets an upgraded brake track using similar tech that the clincher received earlier this year. The carbon layup and resin mix was changed to improved heat tolerance." from the Bike Rumor article....
Can You confirm that?
Will be used the same brake track available as optional/upgrade this year or another technical solution?
Thanks :beerchug:
