Post new topic Reply to topic  [ 2 posts ]
PostPosted: Tue Mar 06, 2012 4:43 am
Any suggestions for removing internal cable routing guides on a BMC SLC01?
I want to enlarge the entry holes and run my Di2 wires inside the frame but the internal routing guides for traditional cables prevent me from simply enlarging the holes and inserting the Di2 wires. Do you think if I just both holes on either ends of the guide that I could simply pull it out? Or are they also attached somewhere along the way inside the frame?
The last thing I want is broken guides floating around inside my frame. Anybody ever seen the inside of an SLC01?
PostPosted: Thu Mar 15, 2012 4:05 am
Anybody have any thoughts?
Where would be the best (least stressed) spots on the frame to drill exit holes for the front and rear derailleur Di2 wires?
Users browsing this forum: 54x11, Bing [Bot], thprice, Yahoo [Bot] and 40 guests
There are no new unread posts for this topic. Best way to replace internal cable routing
ninjanoir78
Fri May 24, 2013 1:06 am
boolinwall View the latest post
There are no new unread posts for this topic. Attachment(s) DI2 frame with internal routing can't take the cables intern
WasFab
38
2934
Wed Apr 10, 2013 12:49 am
di2diy View the latest post
There are no new unread posts for this topic. Internal routing outer cable Campagnolo 11s
chickenbourne
7
389
Fri Jan 11, 2013 4:18 pm
bontie View the latest post
There are no new unread posts for this topic. Cannondale SS EVO Rear Brake Routing
KWalker
Mon Mar 11, 2013 5:04 pm
upside View the latest post
There are no new unread posts for this topic. how do you remove a stripped bolt (top cap)
roca rule
21
763
Mon Oct 22, 2012 10:58 pm
roca rule View the latest post
It is currently Sun May 26, 2013 12:39 am
