Post new topic Reply to topic  [ 3 posts ]
 Post subject: TRP 950SL compatibility
PostPosted: Mon Mar 05, 2012 3:37 pm
Hi guys,
Can anyone tell me if TRP 950SL brakes are compatible with DA7900 levers? I've tried emailing TRP directly but didn't get a response. I read somewhere about 7900 levers having different pull ratios.........??
Thanks.
PostPosted: Mon Mar 05, 2012 6:20 pm
Hi Feex, I believe that the TRP950SL is 1:3 actuation whereas the DA7900 is expecting 1:4. This is saying that using a 7900 lever will require more lever movement when combined with the TRP950SL. Those who have done this with DA7900 to DA7800 caliper have said that it does not feel right (a spongy or delayed feeling) and apparently the reverse gives an even stranger feeling. Either way the braking is not optimum.
They should still work but Shimano would not call them compatible.
PostPosted: Wed Mar 07, 2012 2:19 am
Thanks KLabs. I was under that impression as the brakes didn't feel quite as strong as they should having gone from original fit OEM units.
I'm assuming that TRP make some 7900 compatible brakes.........? More spending.........
Users browsing this forum: ave, Bing [Bot], eric, Google Adsense [Bot] and 38 guests
There are no new unread posts for this topic. Specialized Srm - BB compatibility
micky
Sat Apr 20, 2013 10:35 pm
Machinenoise View the latest post
There are no new unread posts for this topic. Campagnolo BB compatibility.
Lewis
22
901
Fri Jan 25, 2013 8:44 am
paddyrider View the latest post
There are no new unread posts for this topic. BB compatibility Scott Foil
merlin6014
Sun Feb 10, 2013 10:30 am
merlin6014 View the latest post
There are no new unread posts for this topic. Dura Ace 9000 FD compatibility
TimmS
33
4331
Mon Mar 04, 2013 8:16 pm
Berg View the latest post
There are no new unread posts for this topic. Q-Ring / Campag 11-sp Compatibility?
JimmyRingo
Thu Aug 09, 2012 9:18 pm
JimmyRingo View the latest post
It is currently Fri May 24, 2013 11:51 pm
