Post new topic Reply to topic  [ 9 posts ]
 Post subject: Dogma Seatpost slipping
PostPosted: Sun Mar 04, 2012 4:18 pm
First couple of months seatpost never slipped, now every ride is slips. I have tried the carbon paste and electrical tape but still slips. Only thing I can thing of now is to wet sand the clear coat to rough it up a little, any hints would be appreciated.
PostPosted: Sun Mar 04, 2012 5:02 pm
I'll ask the obvious, is it torqued to spec?
PostPosted: Sun Mar 04, 2012 5:55 pm
Yes!
PostPosted: Sun Mar 04, 2012 5:59 pm
Try using some hair spray to fix it.
PostPosted: Sun Mar 04, 2012 6:26 pm
Have you checked for any cracks. There will be a reason why it's started slipping.
PostPosted: Sun Mar 04, 2012 6:44 pm
Assuming everything is fine and no cracks etc......
On a LOOK 585 i had the same issue, tried everything, mine even went back into warranty for a new post, it was fine for a while and then started to slip again!
In the end i got a Miche x seat clamp from PBK, which is designed to accept a higher torque figure.
http://www.probikekit.com/uk/contact-po ... clamp.html" onclick="window.open(this.href);return false;
i found i didnt have to go to 10nm max 8nm was perfect.
PostPosted: Sun Mar 04, 2012 7:59 pm
With hairspray is there any creaking noises?
PostPosted: Sun Mar 04, 2012 10:58 pm
Why would there be any creaking? hairspray would just be an extra degree of sealant.
PostPosted: Mon Mar 05, 2012 12:48 am
because it's like like glue and dries out, it's not a lubricant!
Users browsing this forum: bikewithnoname, Bing [Bot], DamoRider, DMF, Google Adsense [Bot], mnmasotto, Tom-s, Tristan and 75 guests
There are no new unread posts for this topic. Easton EC90 seatpost slipping
HugoDrax
16
507
Tue Mar 12, 2013 5:33 pm
HugoDrax View the latest post
There are no new unread posts for this topic. Considering a Dogma 2 build, had a weight and seatpost Q
Chiho
20
1281
Thu Jul 05, 2012 3:07 pm
sedluk View the latest post
There are no new unread posts for this topic. Romin Pro Slipping - Any suggestions?
Dallez
10
766
Sat Jul 14, 2012 9:52 pm
Dallez View the latest post
There are no new unread posts for this topic. 3t fork alu sleeve slipping
Monkeyboy3333
Tue Aug 07, 2012 10:38 pm
monkeyburger View the latest post
There are no new unread posts for this topic. "Slipping" headset
bontie
Fri Sep 28, 2012 6:44 am
bontie View the latest post
It is currently Thu Jun 20, 2013 1:14 pm
