Post new topic Reply to topic  [ 13 posts ]
PostPosted: Sat Mar 03, 2012 3:02 am
I'm curious, actually more anxious that is.
I bought the 16Nm Keo blades. Never tried on the road yet.
Even on the trainer, they don't feel like they hold the shoe very tight.
Anyone experienced un-clipping while sprinting, or for intense out-of-the-saddle efforts ?
I was thinking if it was possible to have a higher tension than the 16Nm blade, or I'll have to settle with it...?
Louis :)
http://www.ccsalma.com
PostPosted: Sat Mar 03, 2012 3:20 am
I've my Keo carbons on minimum tension. Never unclipped, and I tried!
Sure enough, I'm not as strong as McEwen. (not Blades) http://www.pezcyclingnews.com/photos/ra ... sprint.jpg" onclick="window.open(this.href);return false;
I'd think LOOK have tested the Blade quite extensively before they brought them onto the market, no?
PostPosted: Sat Mar 03, 2012 3:58 am
I have been using 16Nm blades for almost a year and never had any issues with unclipping, but I had few instances in the past where my Looks (pre Keo) unclipped during sprinting.
My C59 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=80193
PostPosted: Sat Mar 03, 2012 1:21 pm
Are you sure you're not just feeling the float ? New cleats and new pedals can feel pretty smooth and there may just be little friction between the pedal body and the cleat causing you to perceive the float more. Just a hypothesis, but given that the spontanoeus unclipping under power not a problem with these in ProTour racing, I suspect that you'll be fine.
PostPosted: Sat Mar 03, 2012 4:26 pm
Not a problem here... they work.
PostPosted: Sat Mar 03, 2012 5:13 pm
Formerly known as PezTech
4 sets, no unclips. Couple of national ranked sprinters also run em without problem.
your results may vary, but I'm not sure what "feeling" youre getting. maybe the float is just too free for you ?
charles@pezcyclingnews.com
PostPosted: Sat Mar 03, 2012 5:18 pm
Mine work great no issue with the 16nm
PostPosted: Sun Mar 04, 2012 12:54 am
Louis :)
French Co. XX Cycles lists (2) versions for the carbon blade. But it looks like your 16nm is the strongest of the (2). Since the 12nm exists maybe an (18)nm exists.
http://www.xxcycle.com/lame-carbone-pou ... de,,en.php
PostPosted: Sun Mar 04, 2012 2:28 am
I decided to change the old cleats I had on my shoes (thay have about one and a half seasons). I noticed one was cracked at the back almost half an inch. Probably the reason the shoe un-clipped a few times.
The new cleats shure feel more "solid" now. I had the grey cleats on my old Keo carbon, and decide to keep the grey ones on the Blades. The (7 degrees ?) float is fine for me. I don't think my pedal stroke, or my knees would like less float.
Louis :)
PostPosted: Sun Mar 04, 2012 6:30 am
I once installed the BLACK zero float cleats. All was good for about a month and then it all caught up with me. From the knees down I began to get extreme muscle / ligament strain.
PostPosted: Sun Mar 04, 2012 10:13 am
LouisN wrote:
The new cleats shure feel more "solid" now. I had the grey cleats on my old Keo carbon, and decide to keep the grey ones on the Blades. The (7 degrees ?) float is fine for me. I don't think my pedal stroke, or my knees would like less float. Louis :)
Pretty sure the grey cleats have 4.5 degrees of float
PostPosted: Sun Mar 04, 2012 10:45 am
I have the yellow (12kN) blades and have had ZERO unintentional releases. I'm an MTB rider at heart and bunny hop the Cervelo and jump the odd kerb/roundabout etc. I'd go so far to say that the Blades are better than the shimano SPD's I use on the MTB. The Blades are easy to release from when intended or in a panic and very positive when attaching. A lot easier and faster than Shimano SPD SL road peddles thats for sure. Dont worry about accidental releases, especially with the red 16kn version. It just wont happen
Contact is very good, although you will need to find the older teflon cleats or put some lube on the newer cleats or you will get a ton of noise while cycling (Sound like the bearings are on their last legs)
Also found the secret to a very quick clip in is NOT to look at the peddle, but just do it, the peddles hang in the same position each time.
Oh yes the grey cleats are 4.5 deg float, but thats either side of Zero so total float is 9 degrees, thats why you often see two numbers reported
Cervelo S3 2011. Blinged 6.718 Kg
PostPosted: Sun Mar 04, 2012 12:33 pm
My understanding is that it's 4.5 deg inclusive. Best pic I can find.........
Users browsing this forum: CBJ, Exabot [Bot], petal666 and 53 guests
There are no new unread posts for this topic. Keo Blades
jaredfontaine2002
9
882
Tue Jul 31, 2012 11:53 pm
Dcgriz View the latest post
There are no new unread posts for this topic. Mavic CX01 Blades
ttlund
Sat Feb 02, 2013 11:54 am
ttlund View the latest post
There are no new unread posts for this topic. sram red b tension size
styrrell
Wed Oct 17, 2012 12:54 am
styrrell View the latest post
There are no new unread posts for this topic. Curved washers, tension for a carbon rim
crewdoglm
Wed Jan 02, 2013 3:33 pm
eric View the latest post
There are no new unread posts for this topic. replace spoke - tension by sound?
ricorob
7
547
Sun Sep 16, 2012 3:53 am
stella-azzurra View the latest post
It is currently Sun May 19, 2013 12:43 pm
LOOK KéO Blade
