Post new topic Reply to topic  [ 3 posts ]
PostPosted: Thu Mar 01, 2012 7:58 pm
Is there any real world difference between the two? why do they offer different size face plates, does the non-44 version cause bars to slip or is it not stiff enough?
150lb rider here.
PostPosted: Thu Mar 01, 2012 8:41 pm
It would be great to know is there is any noticable stiffness between the two from someone who has used both. 2 off standard version has no slippage issues for me.
PostPosted: Thu Mar 01, 2012 9:40 pm
I posted your query in the Ritchey sub forum over at RBR. Ritchey Dave is sure to provide a good answer for you.
http://forums.roadbikereview.com/ritche ... ost3804130" onclick="window.open(this.href);return false;
And here's the answer:
"Good question. The 4-Axis 44 differs from our standard 4-Axis stem in stiffness and weight. It has a larger, more squared, body to increase the stiffness. This stiffness is at the expense of about 10 grams compared to the standard 4-Axis, but sprinters, track racers, and larger riders have found it worth it. Climbers and "weight weenies", however, have preferred the 4-Axis for the more obvious emphasis on weight. The 44s larger faceplate is a result of the larger body, rather than to combat bar slipping, however it does add to a larger contact patch for the handlebars, which does reduce the possibility of slipping. For a maximum stiffness to weight ratio our new C260 stem has surpassed both our 4-Axis and 4-Axis 44 in all departments. Hope this answers your question.
__________________
Dave Law
Ritchey Design Representative "
Users browsing this forum: Bing [Bot], Exabot [Bot], Google [Bot], kaaos and 40 guests
There are no new unread posts for this topic. Question about off-axis drag numbers in aero wheel tests
Boomer
10
619
Fri Nov 16, 2012 2:43 am
tommasini View the latest post
There are no new unread posts for this topic. ritchey super logic stem
michel2
22
1464
Tue Nov 27, 2012 1:03 pm
elfuinha View the latest post
There are no new unread posts for this topic. Anyone try the Ritchey sl carbon c260 stem
NWSAlpine
Wed Dec 05, 2012 5:33 pm
NWSAlpine View the latest post
There are no new unread posts for this topic. ritchey c260 wet black stem
gg333
Tue Jun 12, 2012 9:35 pm
Zigmeister View the latest post
There are no new unread posts for this topic. new Ritchey Stem, supposed to be light?
bolizous
12
1129
Thu May 24, 2012 12:05 pm
CBRE View the latest post
It is currently Sun May 19, 2013 8:00 am
Ritchey WCS C260 stem
