Post new topic Reply to topic  [ 23 posts ]
Go to page Previous  1, 2
 Post subject: Re: Di2 troubleshooting
PostPosted: Thu Mar 08, 2012 9:24 pm
How long will it be before an electronic system can be made to transmit via telemetry what the problem is back to head office a la mclaren f1?
PostPosted: Fri Mar 09, 2012 1:01 am
probably tomorrow or the next day
PostPosted: Thu Nov 22, 2012 4:27 am
Same thing happened to me today. 25 miles out from home and poof, the system stops working (as luck would have it, in my 53x12). Checked all connections and the system is dead. I hooked it up to an old external harness at home and it worked, so the problem has to be either the internal Junction B box or the battery mount/cable.
Really irritates me that I now have to go and shell out $250+ to replace a set of 4 wires and a junction box, particularly on a system that will be out of date in just a few months.
Anyone have a suggestion? (or a used internal Junction B box and battery cradle?)
PostPosted: Wed Nov 28, 2012 10:27 pm
Following up - turns out it was my battery cradle (I tried a brand new Junction B and the system still didn't work). Ended up ordering an internal seatpost battery to replace the OEM external cradle, as I have always wanted to go with the internal battery. Hopefully this will tide me over until the new 9070 Di2 is available.
PostPosted: Fri Feb 08, 2013 12:36 am
Well so much for the prior "fix". I replaced the battery+cradle with an internal seatpost battery (crafted by the dude selling on ebay). It worked for two months, then last week went crazy. On one day, the system stopped working completely after 20 min of riding, I stopped and checked all connections and it still didn't work. Then 40 minutes later it started working again (without me doing anything more). Two rides later, the exact same thing happened -- stopped working about the same place on the same route, and started working again within a mile of where it resumed working earlier in the week.
I am perplexed with the intermittent functioning after having checked all components and replacing the battery and cradle. Really getting frustrated after being an early and devoted Di2 adopter. At this point I'm thinking I may replace the FD (as it has been making a soft clicking noise about 20 seconds after downshifts) to see if that may be the source of the problem.
Any ideas please???
PostPosted: Fri Feb 08, 2013 1:50 am
The Fd issue could be similar to the trouble I had. See my old post about giving it a bit of a lube in the right places.
I wouldnt really trust an ebay seller for hacked Di2 battery, much better to do it youself then you'll know its potential weak points (mainly where water might get to the cells/connections).
Suprised the battery holder gave in though on the stock setup. Mine's had 2 full winters and gets hosed down multiple times a week, never had any trouble with Shimanos bits.
viewtopic.php?f=3&t=107037 & viewtopic.php?f=3&t=106865
Might be of some help.
Di2x2
PostPosted: Fri Feb 08, 2013 8:04 am
i'm familiar with that ebay seller and have had long conversations with him about di2 batteries and custom modifications i have done for di2.
i know he does excellent work.
that said, $hit happens sometimes.
to mordi, my first suspicion is a poor connection -- and given the intermittent nature it suggests to me a poor soldering connection. i would suspect something with the battery and/or it's wiring to the junction, simply because this was not stock.
if it were me, i would sub in a stock battery for testing.
since you're losing all power, it just seems like it cannot be the RD, FD or shifters.
 Post subject: Di2 troubleshooting
PostPosted: Sat Feb 09, 2013 4:42 am
Sounds like an intermittent conductor fault in the wiring loom somewhere...
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Users browsing this forum: Google [Bot], HammerTime2, jdott and 74 guests
It is currently Sun May 19, 2013 4:55 pm
