Post new topic Reply to topic  [ 14 posts ]
Which would you buy? (same price - 140€)
look keo max 2 carbon with yard industries ti spindles - 200 gr 45%  45%  [ 10 ]
xpedo thrust 8 ti -170 gr 55%  55%  [ 12 ]
Total votes : 22
PostPosted: Tue Feb 28, 2012 6:58 pm
Has anyone had experience with these pedals?
http://www.xpedo.com/products/pedals/road/90/thrust-8-ti
They are here with a very attractive price (140€):
http://www.bike-components.de/products/info/p29690_Thrust-XRF-08CT-Titan-Carbon-Klickpedale-.html
What would you prefer? Look keo max 2 carbon with TI spindles, 200gr? (same price with ti spindles from ward industries)
http://www.amazon.de/dp/B0029KD6WI/ref=asc_df_B0029KD6WI6760528?smid=AOC3G2PBG3IY7&tag=geizhals10-21&linkCode=asn&creative=22506&creativeASIN=B0029KD6WI
http://www.ebay.com/itm/Titanium-Spindles-Only-Fit-Look-Keo-Max-Carbon-/220847389021?pt=Cycling_Parts_Accessories&hash=item336b87b95d
Or the xpedo?
Best regards,
Filipe Dias
PostPosted: Tue Feb 28, 2012 7:19 pm
The Thrust pedal is a nice looking pedal, but the Ti version has a 180lbs weight limit.
PostPosted: Wed Feb 29, 2012 2:50 am
I'm curious about folks experience too. I have what most would call boat anchors (Shimano 105 pedals - same weight as Ultegra, just less pretty and not from Japan - at 321g actual), and wouldn't mind dumping 140g.
PostPosted: Wed Feb 29, 2012 3:44 pm
Exactly like me.. I have the ultegra sl which weight the same... too much! I weight 70 kg/154 pounds and I think that TI is fine..
Today another good deal as come out:
Look keo blade crmo 230gr - 107€
http://www.kompressor-bike.com/pedales-look-keo-blade-carbon-cromo-12-p-3547.html
Looking forward for yours opinions,
Filipe Dias
PostPosted: Wed Feb 29, 2012 5:26 pm
I've not used the Xpedo pedal. From what I've read it works great when new, however with only one bearing I question how long that will last. I'm much more comfortable with the three bearing design my Looks incorporate.
PostPosted: Wed Feb 29, 2012 5:56 pm
I think that this model also has 3 bearings. At least in their webpage it seems so.
Filipe Dias
PostPosted: Sun Mar 11, 2012 9:08 pm
So, safe to assume folks haven't used these?
PostPosted: Mon Mar 12, 2012 1:03 am
Formerly known as PezTech
I have em.
And they do have 3 replaceable cart bearings which are arguably better than needle set ups.
The set I've had have worked flawlessly and came in at weight spec. Easy to adjust, float works well.
these guys move more pedals than most probably think.
The Magnesium version are only 109 bucks...
charles@pezcyclingnews.com
PostPosted: Mon Mar 12, 2012 1:29 am
I have the xpedo thrust TI the 195 gram for a pair and I am 74 kg and they are great. I use them for over a year flawless.
PostPosted: Mon Mar 12, 2012 10:14 am
+1 ... 7000 km no issues to date.
PostPosted: Sun Dec 30, 2012 3:53 am
Location: Dullsville Australia /Praha 9 Ceska Republika
So I'm no engineer but what gives with weight limit on pedal axles , so if a 70kg pro pumps out some massive wattage in a Sprint this is better than an 100kg guy just out for a Sunday ride?
PostPosted: Sun Dec 30, 2012 3:17 pm
The xpedo's are probably fine. I've been using exustar 200 ti pedals for a few years now with zero issues and those use a plastic bushing. These are probably better.
Speedplay is the devil.
PostPosted: Sun Dec 30, 2012 3:46 pm
It's not the wattage that's the problem, it's the entire body weight standing on one pedal while the bike goes over a bump.
I like seeing parts with weight limits. A part made to handle a 100kg rider is overkill for a 65kg one.
PostPosted: Sun Dec 30, 2012 4:31 pm
I've been on the Xpedo Thrust "195g", very similar build to the Thrust 8Ti, for 1.5 year. They came with Ti spindles, magnesium bodies (if I'm not wrong) and after changing the spring preload bolts for alu ones, they scale showed 188g.
That was a really bargain, I got them for about £40!
Haven't had any problems with them at all. There is no play on the bearings, which, for instance was developed on my other pedals Look Keo Spring which haven't seen even a half of the Xpedo's mileage. Thrusts also look much better after more than twice longer time of use. I'm 200lb.
Cervelo R5 VWD 5637g/12.43lb
Cannyon Ultimate slx 5592g/12.33lb
Pronghorn XC SW Race 8284g/18.26lb
Users browsing this forum: BeeSeeBee, Google Adsense [Bot], maissi, skinnyrider, vinceflynow and 86 guests
There are no new unread posts for this topic. BTP carbon cage - carbon fiber or plastic ???
maverick_1
16
1350
Thu Feb 21, 2013 8:38 am
mann2 View the latest post
There are no new unread posts for this topic. keo 2 max carbon issue or not.
loco2546
Tue Jul 17, 2012 2:12 pm
loco2546 View the latest post
There are no new unread posts for this topic. Carbon Ti chainrings
konky
Sun Nov 04, 2012 2:36 am
Gold Knight View the latest post
There are no new unread posts for this topic. OBE Carbon rim pads
chazzawoods
Thu Sep 06, 2012 10:51 pm
eric View the latest post
There are no new unread posts for this topic. Firefly Carbon-Ti
phallenthoul
28
2491
Thu Apr 18, 2013 10:31 am
elviento View the latest post
It is currently Thu May 23, 2013 7:46 pm
