Post new topic Reply to topic  [ 324 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 22  Next
PostPosted: Tue Mar 13, 2012 4:22 pm
pRoto wrote:
609$ and 664$ hubsmith(ceramic bearing), sapim cx-ray. But im thinking still about 50mm's. 1300g.
So it's more than 700$ includes shipping cost, then i will prefer Body or William or Flo cycling, it's too expensive for these chinese wheels.
PostPosted: Tue Mar 13, 2012 5:18 pm
well, it can be -40$ if bitex hubs and -40$ if steel bearings.
PostPosted: Tue Mar 13, 2012 5:50 pm
absmith wrote:
andyindo wrote:
absmith wrote:
My experience has been so bad about these rims from Farsports, maybe you guys have good experiences now, but then you will find "something interesting" after long ride. The first time i bought and built the superlight rims from Farsports, my target drive side tension was 120 kgf, I follow my standard procedure of stress relieving by squeezing parallel spokes with my hands. That's when I heard the rim creak. Not until the wheel was done did I see a crack at the nipple hole and several other bulging.
Which model rims were these? I was told by farsports that there CP model was discontinued to it not being 'stable'
superlight rims, both tubulars and clinchers. I prefer the stiffer rims, not lighter and weak rims.
Its a CP or CM version of wheels (both are superlight ones). The CP has been discontinued.
PostPosted: Tue Mar 13, 2012 6:30 pm
If so, which kind of clincher rims did they build for 1300g wheels?
Deleted quote. PP
PostPosted: Tue Mar 13, 2012 7:57 pm
Online
They use the FSL50-CM rim in the FSC50-CM wheelset - which is a mid-1300g 50mm clincher.
Deleted quote. PP
PostPosted: Tue Mar 13, 2012 8:36 pm
My FSL50-CMs arrived today. They're 406g and 410g. I hope they are reliable at that weight!
There's no foam inside and the inside looks smooth. They must have gone to a bladder type process.
They did not come with nipple washers. They're drilled for external nipples. Would Sapim PolyAx washers be appropriate? Or none?
PostPosted: Tue Mar 13, 2012 10:47 pm
Cool! Let us know how the build goes.
Deleted quote. PP
PostPosted: Wed Mar 14, 2012 4:59 am
do you have the total cost landed cost for the 50mm rims
how much lighter were the hubsmith hubs
PostPosted: Wed Mar 14, 2012 5:39 am
Do you have any photos of these rims to share with us? I think these are the same rims as my broken rims which weigh 410g and 415g.
PostPosted: Wed Mar 14, 2012 11:26 am
bitex 315g
novatec 325g
chosen 315g
hubsmith 252g
PostPosted: Wed Mar 14, 2012 11:49 am
powerway hubs from focus-carbon, weigh 284g.
PostPosted: Wed Mar 14, 2012 3:16 pm
Online
Absmith, you seem pretty hell-bent on discrediting Farsports in favor of Focus-Carbon. However, I see more positive comments for Farsports on this site than I do for Focus!
bitex 315g
novatec 325g
chosen 315g
hubsmith 252g
Everything I've seen puts Bitex at 211 rear and 76 front.
PostPosted: Wed Mar 14, 2012 3:58 pm
I am not discrediting Farsports, but you know i had bad experience from farsports, and no replacement rims or refund, after-sales service is the same important as products quality i think, what's more, the price is too high when i compare to focus-carbon.
PostPosted: Wed Mar 14, 2012 4:06 pm
bitex 315g
novatec 325g
chosen 315g
hubsmith 252g
It depend on which model of hubs you want..
http://www.bitexhubs.com/htm/products.php
some interesting site I found:
http://vulcancarbon.com/specs/
I think they use the same chinesse rims.. And selling them in 1400$
PostPosted: Wed Mar 14, 2012 4:11 pm
Online
http://www.bitexhubs.com/htm/products.php" onclick="window.open(this.href);return false;
http://vulcancarbon.com/specs/" onclick="window.open(this.href);return false;
Yes, I should have been more specific. I was referring to the A713SB front and RAR12 rear... I remember Bitex having a lower weight listed a week or so ago, however.
Post new topic Reply to topic  [ 324 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 22  Next
Users browsing this forum: Exabot [Bot], Google Adsense [Bot] and 48 guests
There are no new unread posts for this topic. Best option for carbon clinchers >50mm and <$1000
capnc
9
1683
Fri Sep 07, 2012 9:23 pm
eric View the latest post
There are no new unread posts for this topic. New wheels - Using RTS Carbon T1000 50mm rim
elfuinha
Mon Jun 11, 2012 12:08 am
elfuinha View the latest post
There are no new unread posts for this topic. Planet X Pro Carbon 50mm Tubulars
stephenjwhan
Mon Jul 23, 2012 8:07 pm
AttacknowAttackoften View the latest post
There are no new unread posts for this topic. Zipp 404 vs standard 50mm carbon deep-v?
blantonator
7
1121
Tue Jun 05, 2012 6:46 pm
blantonator View the latest post
There are no new unread posts for this topic. What lightweight 38mm or 50mm carbon wheel?
Bianchi10
Tue Nov 20, 2012 5:17 pm
mgrennie View the latest post
It is currently Wed May 22, 2013 12:00 am
