Post new topic Reply to topic  [ 324 posts ]
Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 22  Next
PostPosted: Wed Apr 04, 2012 5:36 pm
I see you have just enough valve stem sticking out to get air in. Are you using 60mm tubes or an adapter?
Let us know how they ride.
PostPosted: Wed Apr 04, 2012 6:54 pm
60mm michelin tubes.
Laterally stiff and vertically compliant. They added 1 mph average speed on my regular loop.
OK, I'm kidding. But other than being reasonably laterally stiff (which is partly due to hub geometry and front lacing) the ride quality is just like any other wheel. Maybe a little rougher than lower profile rims, but the difference is small if it's there at all. I know some people claim to feel significant differences in ride quality between clincher wheels but if they're fully tensioned they all feel pretty much the same to me.
PostPosted: Mon Apr 16, 2012 3:19 pm
My 50mm clincher rims are in from Light-Bicycle.com. Took a couple of weeks to make and 1 week to ship. I couldn't get a super accurate weight but they look like they are 450-460 each as advertised (They do offer a 410 gram rim for a $15 each upgrade). I will re weigh when I get them delivered to my LBS for the build. They feel ultra stiff when trying to twist them in my hands compared to a normal box type clincher rim. Should build right to 1390 grams if calculations are right. Rim width is 20.83 on both rims, much wider than the American Classic 420's I have been riding. ERD was 546 and the brake track goes out to the edge of the rim.
For the record the Velocity Velo plugs in red fit mega tight, just perfect and I mean perfect they have to be pried out.
PostPosted: Fri Apr 20, 2012 2:18 am
I did a pretty steep descent on my 50mm chinese rims today. Steep and technical, and you have to stop at the bottom and ride back up 'cause its a dead end unless your name is Neil Young. A lot of braking is required on this road.
At the bottom I stopped and felt the front rim temp. It wasn't very warm at the brake track and was cool elsewhere. Braking was the same all the way down and nothing exploded.
This isn't the worst descent I do because it's not that long, but it was a good first test.
PostPosted: Fri Apr 20, 2012 7:02 am
Eric, how long was your first ride test? will appreciate if you have any photos on brake tracks? I had some chinese rims which have pulse & bubbles on brake surface under braking, hope to look at yours.
PostPosted: Tue Apr 24, 2012 9:47 pm
Light-Bicycle.com 50mm rims are built up! These were the heavier version at 455 grams each (as opposed to the 410G). Extremly stiff my LBS tells me and I can confirm that. While mounted in the bike the left to right play is roughly 1/3 of the other wheels I have. Build weight is 1390 grams with the Token TK520 carbon hub, DT Aerolites and Red allow nipples. I will be on my normal twice a week group ride tonight so report later on how they do.
PostPosted: Tue Apr 24, 2012 10:18 pm
Are these the BOYD wheels ...??? if so ... are they good, stiff enough ..?
all coments will be apreciated . Nice bike by the way . :thumbup:
PostPosted: Wed Apr 25, 2012 12:14 am
The ride was about 50 miles. The descent test was maybe 3 or so. I also used them this last weekend at the Sea Otter road race. That has a neutralized descent down Barloy Canyon. Our moto had us going pretty slow and I had to ride the brakes. I didn't get to stop and check the rim temp at the bottom but the braking did not change so they didn't get too hot.
Here's a pic below. They're not perfect. The rear has a bit of pulsing, the front had a little when new but it seems to have gone away. I did measure the front's brake track width and if I recall the variation was on the order of .1mm.
Loco2546- these are not Boyd wheels. They are FarSports, direct from China. See http://forums.roadbikereview.com/wheels ... 41788.html" onclick="window.open(this.href);return false;
http://ericm.lne.com/images/farsports_c ... etrack.JPG" onclick="window.open(this.href);return false;
PostPosted: Wed Apr 25, 2012 3:17 am
The braking surface don't look very reassuring. Is it meant to be like that?
PostPosted: Wed Apr 25, 2012 4:11 am
cep111 wrote:
Light-Bicycle.com 50mm rims are built up! These were the heavier version at 455 grams each (as opposed to the 410G). Extremly stiff my LBS tells me and I can confirm that. While mounted in the bike the left to right play is roughly 1/3 of the other wheels I have. Build weight is 1390 grams with the Token TK520 carbon hub, DT Aerolites and Red allow nibbles. I will be on my normal twice a week group ride tonight so report later on how they do.
Sounds good. Looking forward to see some pics of the wheels. upclose shots if you can to see how the rims look.
thanks :beerchug:
Salice sunglasses for sale PM me for info
PostPosted: Wed Apr 25, 2012 4:23 am
I did 32 miles tonight with my usual group using the new wheels. They braked fantastic!! I installed new Swiss Stop Yellow pads. No issues at all and no loss noticed in braking power with the Dura Ace brake calipers.
They felt faster, or at least easier to accelerate and hold speed. Average was better too but that is subjective with so many variables of group riding. Here is what I know for sure.....on 2 longer down hills I was out coasting my usual buds going down. That is something new as I usually don't out roll anyone. I have 3 differences from my normal wheels, Deeper rim, 3mm wider rim and ceramic bearings
Biggest thing I can comment on is how strong and stiff they are. I think they would work well for a much larger rider, no issues.
PostPosted: Wed Apr 25, 2012 4:59 am
I got two clincher rims and two tubular wheels from FarSports. That's probably the worst looking section. The tubulars don't have any pits at all. The braking doesn't seem to be affected, and the pits are in the presumeably non structural basalt brake track.
They're not perfect, but they're about 1/4 the price of Enve rims, and lighter too.
Cep111, try the blue pads that came with the rims (or Reynolds blue pads if yours did not come with pads- I think they are the same thing). I've found that they stop better than SwissStops.
PostPosted: Wed Apr 25, 2012 6:28 am
Image,
PostPosted: Wed Apr 25, 2012 8:13 am
As my past experience with chinese rims, "the wheels were built up well and looked well" can not prove anything, will appreciate any reports after 120 miles.
PostPosted: Wed Apr 25, 2012 4:21 pm
So far on my Farsport 50mm clinchers I've got in a couple circuit races and a couple brief rides (30 miler and a 10 just to feel the wheels). I honestly can't say much about their performance thus far, this is my first experience with carbon wheels or wheels with any sort of depth. The final build weight was 1414 with tape, I can't say I've really noticed the 106 grams I lost from the ROL D'Huez. I can't say that I've noticed easier spin up or that they maintain speed faster... but I expect to be able to comment more on the latter after some longer training rides.
I was a little nervous about having my sprint on the wheels be in a race... but after 2 races this week they've given me no reason to be wary.
I'll post another update when I log more road miles.
Post new topic Reply to topic  [ 324 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 22  Next
Users browsing this forum: aaric, Exabot [Bot], Google Adsense [Bot], Majestic-12 [Bot], ninjanoir78, timeforheroes and 47 guests
There are no new unread posts for this topic. Best option for carbon clinchers >50mm and <$1000
capnc
9
1683
Fri Sep 07, 2012 9:23 pm
eric View the latest post
There are no new unread posts for this topic. New wheels - Using RTS Carbon T1000 50mm rim
elfuinha
Mon Jun 11, 2012 12:08 am
elfuinha View the latest post
There are no new unread posts for this topic. Planet X Pro Carbon 50mm Tubulars
stephenjwhan
Mon Jul 23, 2012 8:07 pm
AttacknowAttackoften View the latest post
There are no new unread posts for this topic. Zipp 404 vs standard 50mm carbon deep-v?
blantonator
7
1121
Tue Jun 05, 2012 6:46 pm
blantonator View the latest post
There are no new unread posts for this topic. What lightweight 38mm or 50mm carbon wheel?
Bianchi10
Tue Nov 20, 2012 5:17 pm
mgrennie View the latest post
It is currently Wed May 22, 2013 12:27 am
