Post new topic Reply to topic  [ 7 posts ]
PostPosted: Mon Feb 27, 2012 7:16 am
Well here goes...
Im 17 from new zealand, still at school. I race alot, ride alot and generally like to go fast. Thanks to my science teacher at school and now my coach im a weight weenie (most of you will know him as 'theremery' on here). I had this SRAM Red front derailleur clogging my man cave bench and decided to attack it with the drill, mini files and a weenies best friend a dremell.
About 10/11 hours later this is my nearly finished product. The derailleur started at 86grams, and now is at 65grams (waiting for nylon and alloy bolts). i also have to rebuild the little plastic bit that holds the two ends of the cage together as i thought the cage went through it but it didnt. but ill reconstruct it out of carbon and only add about 1 or 2 grams to it. Target is <70grams. if with the bolts im waiting for and the new carbon tip its more than 70 ill remove the spring and replace it with a much lighter titanium spoke twisted around the body. which should take off about another 2 or 3grams depending on the weight of the current spring.
It hasnt been tested yet as my current bike is braze on and the SRAM red lever with super record front derailleur is a match made in heaven! (best frontal shifting EVER!!) However i will report back when i have a bike avaiable to test on.
For a project that will end up costing me about $5.00NZD im pretty happy with it. If anyone see's room for improvement comment below and ill see what i can do. So what do you think?[url][/url]
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=100739
PostPosted: Mon Feb 27, 2012 7:17 am
whoops no photos, follow the link... sorry they are to big apprently to attach
http://s1264.photobucket.com/albums/jj481/taylerreed/
PostPosted: Mon Feb 27, 2012 10:47 am
Administrator
:thumbup: Wow, that is some great work! Do you have more projects up your sleeve?
Follow me on twitter. I try to be interesting ;)
On Facebook!
PostPosted: Tue Feb 28, 2012 12:24 am
Let it shine....polish!
PostPosted: Tue Feb 28, 2012 5:08 am
yes rear derailleur is next. will be more expensive, but 'theremery' and i have plans after a 96gm Sram red rear derailleur had a small faliure. tething problems though.
and yes... polishing to come
PostPosted: Fri Mar 02, 2012 9:54 am
Here is a new photo, the unit = 64.89 grams without the new alloys and nylon bolts, i have also just moulded a bit or carbon to replace the plastic part that connected the inner and outer cages, but this should only add about a gram or two. then if i can be bothered (you would assume after about 12 hours of dremelling i will be) ill tune the spring using an old titanium spoke replacing the original spring as i think i can get away with less coils and then less weight/mass which is the idea. does anyone have any recommendations on how i can drop a little more off. I thought i could drill out the alloy bolts but realistically thats only a gram or half. So what do you think????
http://i1264.photobucket.com/albums/jj4 ... to0020.jpg
Users browsing this forum: bigkraig, G6612 and 64 guests
There are no new unread posts for this topic. Front derailleur clamp/adapter and chaincatcher
fifarafa
18
438
Thu May 02, 2013 2:17 pm
rowdysluggins View the latest post
There are no new unread posts for this topic. Ultegra di2 front derailleur clamp compatibility?
theStig
Sat May 18, 2013 7:35 pm
Dammit View the latest post
There are no new unread posts for this topic. Attachment(s) Need advice: Sram Red front derailleur
poppiholla
31
2072
Sun Jul 22, 2012 11:36 pm
CharlesM View the latest post
There are no new unread posts for this topic. SRAM chainring and front derailleur problems
bluhorizan
Fri Aug 17, 2012 7:57 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Sram Red front derailleur(non yaw) with Chorus 10 speed shif
digiadaamore
Wed May 15, 2013 10:19 pm
dereksmalls View the latest post
It is currently Fri May 24, 2013 4:12 pm
