It is currently Fri Jan 19, 2018 9:05 pm
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Mon Jul 18, 2011 6:41 am
I wished bikeradar had more pictures.
Can't hardly wait...
PostPosted: Mon Jul 18, 2011 2:50 pm
I have the carbon rail model sitting in a box in my closet awaiting my frameset to mount it too. It's the 155mm size and weighs 169g. It looks nice and comfy. I ride two Toupes on my road and rain bike. If it's as good as the toupe I'll never complain.
Specialized Allez 06' "Rain Bike" 21.50lbs
Neuvation F100 11' "Road Bike" 16.80lbs
Specialized Tarmac Pro 11' "WW Bike" 14.25lbs
PostPosted: Mon Jul 18, 2011 3:21 pm
Side shot, but from a low angle. Looks like the Evo still has a bit of a kick in the tail and a more curved nose:
2012 Venge Pro by The Fitzroy Revolution, on Flickr
PostPosted: Mon Jul 18, 2011 4:29 pm
Looks a little bit like a SMP. I like the kick in the tail!
Can anyone with a romin evo measure the width of the nose?
PostPosted: Mon Jul 18, 2011 5:03 pm
I've seen the Romin Evo in person and compared one to my regular Romin. I don't think I will like it. The nose isn't much narrower and the edges/padding is different and I don't know how it will make the saddle work better for me. I've long debated heating up and pulling off the front cover and dremelling down the nose a bit and regluing it back in place.
Gramz
Failed Custom Bike
PostPosted: Mon Jul 18, 2011 7:22 pm
Turns out I'm not crazy! I'm considering the same thing.
PostPosted: Wed Jul 20, 2011 6:35 am
Ha! That makes 3 of us!
I need a width around the same as my Arione.
I'm not too handy and was thinking of taking it to an upholstery shop to have the cover removed and reglued.
PostPosted: Wed Jul 20, 2011 6:31 pm
Its not hard to do and I'll probably do it in the next month or so and give it a shot. The glue isn't very thick and a simple heatgun should be able to pry it up.
Gramz
Failed Custom Bike
PostPosted: Thu Jul 21, 2011 6:27 am
Keep me posted. I've got two of the them that I am not using on account of the super wide nose. It chafes my inner thighs, but I brush the seatpost as well, so I'm not sure it is the saddle's fault.
When I took a look at the underside, it looked like you might ruin the integrity of the shell by shaving too much material away from the sides. It is quite wide where the rails attach to the shell.
PostPosted: Thu Nov 03, 2011 8:01 pm
For guys who went from a Toupe to a Romin did you fing your saddle setback decreased even though the two saddles are almost identical in length?
I went from 5.5cm to 4.2cm from nose to BB centre. Sitting on the saddle whilst riding there is definitely more of the saddle nose visible in front of my crotch compared to the Toupe.
Cheers!
PostPosted: Thu Nov 03, 2011 11:17 pm
Online
If I remember correctly, the Romin is about 8 millimeters longer then the Toupe. It sounds like that difference might be in the front.
My Bikes
My Photoblog
PostPosted: Fri Nov 04, 2011 3:07 pm
The Romin is effectively 1 cm longer if you measure from the widest point of both saddles. It doesn't necessarily require any more/less effective setback, but subtract 1 CM from your bb to saddle tip measurement.
Gramz
Failed Custom Bike
PostPosted: Tue Nov 08, 2011 3:28 am
I got to the same approximation of 1cm by lining up the two saddles on top of each other at the shoulders.
The other difference I noticed was that saddle height measured from the pedal axle along the seat tube to the top of the seat is about 4mm lower with the Romin compared to the Toupe. I set my saddles up level from nose to end and put this height difference down to the greater curve front-to-back with the Romin.
PostPosted: Tue Nov 29, 2011 5:00 pm
The Romin also does not sag as much as the Toupe, so you effectively sit higher.
Tried the Evo out on a 4.5 hour ride Saturday- definitely feels different. Slightly less firm (but not soft at all) and the nose feels more comfortable. Giving it a run this week before going back to my Toupe.
I've tried other saddles in the meantime and keep going back to the Toupe even though it gives me slight saddle sores sometimes.
Gramz
Failed Custom Bike
PostPosted: Wed Jan 11, 2012 7:50 am
Sorry to resurrect a old thread.
Did any Romin Evo Expert owner happen to weight their saddle?
My 143mm Evo Expert weights 232G, quite a big difference from the claimed 205G. :x
I bought it online, so I am just wondering if they sent me a fake one....
There are no new unread posts for this topic. Anyone stripped a Romin Evo Pro?
addictR1
Sun Nov 12, 2017 4:25 am
egebhardt View the latest post
There are no new unread posts for this topic. Is 168 romin saddle too wide for me?
zalle
Mon Jan 23, 2017 5:09 am
mpulsiv View the latest post
There are no new unread posts for this topic. Astute Skylite VT regular or Pilagra VS Romin Pro 143
micro553
Wed Feb 01, 2017 1:53 pm
micro553 View the latest post
There are no new unread posts for this topic. FS:Spec Romin Evo 143mm, Zipp SL 27.2 post
SolidSnake03
Sun Nov 12, 2017 10:08 pm
SolidSnake03 View the latest post
There are no new unread posts for this topic. What's a 'quality' ride?
in Training
Shrike
14
1830
Fri May 05, 2017 3:16 am
TwiggyTN View the latest post
Users browsing this forum: IrrelevantD, petelars and 13 guests
