Post new topic Reply to topic  [ 10 posts ]
PostPosted: Sun Feb 20, 2011 4:56 am
Came across a shop carrying limited stock of Conti competition Tubulars in 22mm, imprinted with Pro Limited Edition and LARGE Competition wordings in the side wall. I was told it's lighter and uses a better compound than the Standard Conti Competitions Tubular.
Would Appreciate anyone have ridden or knows the differences? Probably the Pro Team Mechanic will know?
Thk You for Any feedbacks if paying a 30% premium over these pro limited Conti Competition make sense........ :?: :?: :?:
PostPosted: Sun Feb 20, 2011 2:11 pm
From what I remember the pro models get a laytex tube.
PostPosted: Mon Jul 16, 2012 1:27 pm
I came across the "Pro Limited" too, and am wondering what sets them apart. Thanks.
Bikes: Raceur, Beateur
PostPosted: Thu Jul 19, 2012 4:23 am
I believe the Pro(tection) Limited have a reinforced Gatorskin sidewall.
PostPosted: Fri Jul 27, 2012 1:02 pm
"ProTection" and "Pro Limited" seem to be different tyres though, the latter has the normal sidewall.
PostPosted: Fri Jul 27, 2012 7:42 pm
Maybe Geoff (WW member, Conti tubs and pro stuff expert) can answer that one.
Send him a PM.
Louis :)
http://www.ccsalma.com
PostPosted: Sat Jul 28, 2012 6:40 pm
The compound is the same, they have a different casing, and you can get them with either butyl or latex. The base tape used to be different too, but this year were the same as the standard competition. You can order either the AllAround or protection, which is just A gotorskin version. They are basically made to order depending on team requirements/needs. Specifically what that shop is selling I have no idea.
PostPosted: Sat Jul 28, 2012 9:43 pm
So is the Pro Limited AllAround with butyl tube the closest to the standard Conti Competition? If so , what is the difference in the casing , and how does that affect the ride and flat propensity (for example sharp stones scraping the sidewall)? Are the butyl tubes in the butyl tube version of the Pro Limited identical to those in the standard COnti Competition? Is there a difference in difficulty in mounting?
PostPosted: Sun Jul 29, 2012 2:00 am
The Pro Limited is a Conti Comp with a latex tube (at least, it is supposed to be, I have some with butyl). It is supposed to be World Tour-only, but they show-up now and again...
PostPosted: Tue Jul 31, 2012 10:01 am
Not to muck things up too much but anyone else seen the new Force/Attack Competition tubular versions in person?
I've been on the std Comp from time to time but have migrated back to the sprinter Gatorskin which to me somehow feels a touch more comfy, has great grip (esp in wet where I think all of the cotton tubs suffer) and has so far (big fingers crossed) been pretty bulletproof while being a touch cheaper. As with all Contis that I've had they take a few rides to 'break in' and then give excellent road feels when leaned over.
edit- my horrible luck with Vittoria Evo CX tubs continues. I've got a set on my light climbing wheels and I think I have 3 punctures over a total of about 300 kms. I've gotten 3,000 kms out of my Sprinter Gatorskins w/ zero punctures (knock knock on wood). They are squaring a bit at the rear, but to be expected.
Users browsing this forum: Ghost234 and 7 guests
There are no new unread posts for this topic. Conti Attack/Force Comp tub
wassertreter
11
641
Thu May 09, 2013 1:17 pm
mentok View the latest post
There are no new unread posts for this topic. 4 x Continental Competition tubulars
jonjones13
Tue Apr 09, 2013 2:28 pm
jonjones13 View the latest post
There are no new unread posts for this topic. Competition/racing wheelset (tubular)
frederique
13
811
Sun Nov 11, 2012 10:31 am
MajorMantra View the latest post
There are no new unread posts for this topic. Vittoria Corsa Evo CX or Continental Competition Tubulars
stephenjwhan
33
2229
Sat Jul 28, 2012 11:56 pm
ParisCarbon View the latest post
There are no new unread posts for this topic. Attachment(s) Continental Competition Tubular BNIB, 28 x 19mm
mdeth1313
Sat Mar 30, 2013 4:10 pm
mdeth1313 View the latest post
It is currently Wed Jun 19, 2013 1:41 am
