It is currently Tue Jan 23, 2018 7:01 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
Given a choice between the two which would you prefer?
Poll ended at Mon Feb 14, 2011 2:38 pm
Sweet Wings 67%  67%  [ 4 ]
Coda Magic 33%  33%  [ 2 ]
Total votes: 6
PostPosted: Sun Feb 13, 2011 2:38 pm
I'm curious what you guys think of these cranksets.
PostPosted: Sun Feb 13, 2011 10:12 pm
Hehehehe, This thread is no good without pics! :wink: :lol: That said, I'm glad someone still remembers the days when top end cranks were made out of an isotropic material. :thumbup:
One caveat, it would've been better to put Magic Motorcycle instead of Coda Magic cranks, even if only to give credits to their creator, Alex Pong. Coda's were cheaper Cannondale knockoffs. It's also interesting to keep in mind that the MMC's served as the predecessor for the current SiSL cranks, so imagine how good they really were and how much they were ahead of their time!
Of course, that could even apply to a greater degree about the Sweet Wings, that set new benchmarks for stiffness and weight savings...
My vote goes to the Sweet Wings, because the Coda Magic cranks were just not quite it in comparison to the original.
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
PostPosted: Sun Feb 13, 2011 11:10 pm
I found some negative press about the Sweet Wings... specifically that the splines on the bottom bracket spindle wore out and stripped frequently under load. I haven't found anything particularly negative about the Magic crankset... although some people expressed concerns about the proprietary chainrings required. I love the looks of both... very industrial and sturdy. I thought the Sweet Wings would look really good if I got them powder-coated or plated to match a steel build I have in the works. I considered the Magic as an option to either polish or anodize, but they look awesome raw. But if the rings don't work with a 10-speed chain they might be useless. So I am torn between the two.
PostPosted: Mon Feb 14, 2011 12:33 am
Now? I would never use either. Sweet wings then, because of durability.
PostPosted: Mon Feb 14, 2011 12:51 am
To this day I still want some Sweet Wings. They were such an amazing product back in the day. I remember talking to them on the phone a few times just getting my money ready. For some reason I chose Zipp cranks and broke them in a race climbing an overpass.
I miss the Jerk because your stem is still too short.
Your saddle is probably too high as well.
Oh, and your cleats too far forward.
PostPosted: Mon Feb 14, 2011 5:24 am
Magic motorcycle by a mile. I remember the first time I saw them in a magazine -- back in the day before the internet took off for the masses. Was still in school, so no way I could afford them. Very drool worthy.
If we really want to take a trip down memory lane ---remember the Bullseye cranks? I believe they were the original one piece crank arm + spindle design. And this was back in the early 90s
AX Lightness Vial Evo, Carl Strong Titanium
PostPosted: Tue Feb 15, 2011 3:53 pm
I bought one of each... now to figure out what I'm going to do with them.
PostPosted: Wed Feb 16, 2011 4:17 am
i've owned and used the sweet wings on my mountain bike and my road bike, back in 96-98 or so. I never had problems, except for a slight tolerance issue between the big bearing (LEFT side!) and the spindle. it would have a slight amount of play, as if the bearing was shot, but it was actually a very slight gap in the bb/bearing interface. a little green loctite pretty much fixed it, until the next time. today, i'd probably hit the area with a spring loaded center punch a few times to tighten up the fit.
anyways, that's the main thing i've heard, as well as lack of bearing sealing, some spotting,rusting on the plating, etc.
i really loved the cranks, enough that i bought them again at a swap meet, without a bike to put them on. their quill stem was pretty nice too. always very well thought out. just like in craig's new life, at ee cycles.
i'd attribute the lack of negative feedback from the Magics with the lack of Magic cranks out there!
-greg
PostPosted: Fri Feb 18, 2011 3:35 am
Sweets were nice. Someone should produce them again.
Slight off topic: why could Magic Motorcycle produce their awesome crank for BSA bottom brackets, but no one can make an SISL work? Are they that different? Was the outboard Magic bearing too weak? I don't remember problems back in the day, other than all the shims.
PostPosted: Fri Feb 18, 2011 2:37 pm
The Coda/Magic Crankset is BEAUTIFUL! I especially like the one-piece 53/39 chainring. Phots on the scale to come later but the entire crankset, bottom, bracket, and chainrings is as light as or lighter than most modern carbon cranksets (excluding exotics light AX or THM).
download/file.php?id=41753&mode=view
PostPosted: Fri Feb 18, 2011 2:59 pm
Honestly I just don't see why you would want either of these on your bike now.
PostPosted: Fri Feb 18, 2011 10:36 pm
Because I am planning a retro build...
PostPosted: Mon Feb 21, 2011 6:40 pm
Wow! These cranksets are impressively light considering their construction. Both were clearly ahead of their time. I think the Cannondale/Magic crank is beautiful, especially with the one-piece dual chainring. The Sweet Wings though, really touch the soft spot I have for steel. I think I'll use them for my sonn-to-be custom steel build and maybe put the Coda cranks on a retro Cannondale or even an old Klein.
Coda = 742 grams with bottom bracket and chainring(s).
Sweet = 525 grams with bottom bracket and no rings.
http://www.facebook.com/album.php?aid=2 ... 4d0a91140b
PostPosted: Wed Feb 23, 2011 2:38 am
xnavalav8r wrote:
Nice. BTW, if you dig deep enough, you might uncover the hens teeth-like Sweet Wings made out of titanium.
PostPosted: Wed Feb 23, 2011 3:41 am
I'm sure I couldn't afford them if I found them...
There are no new unread posts for this topic. Attachment(s) Sweet spot Wheel build.....
in Everything wheels
Gutsyfungus
7
542
Mon Jan 22, 2018 9:57 pm
Multebear View the latest post
There are no new unread posts for this topic. Base Training: Traditional, Sweet Spot, or both?
in Training
JBeauBikes2
26
3756
Mon Aug 21, 2017 11:10 pm
bm0p700f View the latest post
There are no new unread posts for this topic. KMC Missing/Quick/Magic Link wearing out before the rest of the chain?
alcatraz
13
2463
Mon Oct 02, 2017 10:12 pm
blueturtle View the latest post
There are no new unread posts for this topic. Attachment(s) Have Colnago done away with the inner metal sleeve in the C60 BB?
[ Go to page: 1 2 3 4 ]
wilwil
53
3649
Tue Oct 03, 2017 9:21 pm
ironman1 View the latest post
There are no new unread posts for this topic. Acros the clamp thin metal washers
Alexandrumarian
Sat Sep 09, 2017 1:29 am
Alexandrumarian View the latest post
Users browsing this forum: BdaGhisallo, dereksmalls and 5 guests
