It is currently Mon Feb 20, 2017 9:43 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Tue Mar 19, 2013 11:44 am
Shop Owner / Manufacturer
A Shimano cassette with Campagnolo der and shifter will not work. I hear people say it does all the time as I ride behind them listening to their noisy, clattering drivetrain.
It is sub-par at best.
Swap the freehub bodies and be done with it.
BDop Cycling Co., Ltd.
www.bdopcycling.com
PostPosted: Tue Mar 19, 2013 9:45 pm
So what you can do is the following:
1. fine tune shifting to the 5th or 6th sprocket.
2. set your der. range well, it will not over- or undershift. So you got the 5th, the 10th and the 1st (smallest) cog working perfectly.
The difference between 'perfect' and 'sub-par' will now be:
1st: perfect.
2nd: 0.6mm off
3rd: 0.4mm off
4th: 0.2mm off
5th: perfect
6th: 0.2mm off
7th: 0.4mm off
8th: 0.6mm off
9th: 0.8mm off
10th: perfect.
In other words, your center-to-center spacing is 3.95mm, and you will be off 20% at max on 2nd and 9th, 15% on 3rd and 8th, and 10% or less on the middle and outer cogs. Just try and see...
Bianchi EV3, Master Olympic, Pinarello Asolo
PostPosted: Tue Mar 19, 2013 9:57 pm
1st: perfect.
2nd: 0.6mm off
3rd: 0.4mm off
4th: 0.2mm off
5th: perfect
6th: 0.2mm off
7th: 0.4mm off
8th: 0.6mm off
9th: 0.8mm off
10th: perfect.
I'd agree that it's a matter of how well the missmatch works rather than if it works. Going with a 0.2mm error per shift, I'm curious as to why you think it becomes perfect at the 1st and 10th sprockets, when I'm thinking it's between 1.0 and 0.8mm away from perfect.
There's sometimes a buggy.
One.
PostPosted: Tue Mar 19, 2013 10:50 pm
1st sprocket: der. cannot go further than just 'perfect', even if it would like to relax with no cable tension until 0.8mm off.
Same for 10th. If you set the der. range right, you just go from the not-so-perfect 9th to the 10th, and while your cable pull would like your der. to go further than just 'perfect', your der. setting is keeping it where it should.
PostPosted: Fri Aug 16, 2013 11:30 pm
I just posted this in another thread but... bicimod.com has a spacer kit solution for that.
PostPosted: Fri Sep 06, 2013 9:46 am
If we agree it's an error of 0.2mm per shift, the fact is that this margin is well within the "error" of the mechanical system and manufacturing and assembly tolerances of the system, so it works fine. Just like any other RD, if you set it up properly there is no noise.
But if you feel mixing sushi and pasta on your bike gives you stomach ache then go for a consultation with your friendly LBS who will resolve your distress for a small fee.
There are no new unread posts for this topic. Campy 11-29 cassette not compatible with EPS
audiophilitis
16
1342
Fri May 13, 2016 6:17 pm
audiojan View the latest post
There are no new unread posts for this topic. Campy cassette on Di2 9070
coppercook62
11
1019
Thu Jun 02, 2016 1:00 pm
micro553 View the latest post
There are no new unread posts for this topic. Shimano CS-9000 cassette vs. CS-9100?
eaglejackson
44
3918
Thu Nov 17, 2016 9:38 pm
vanmatthew View the latest post
There are no new unread posts for this topic. Zipp hub 177 and Shimano cassette issues
dorin
Wed Jan 25, 2017 3:48 pm
joejack951 View the latest post
There are no new unread posts for this topic. 11spd Shimano Cassette w/ Campagnolo groupset? (temporary fix)
Devon
11
655
Sun Jun 26, 2016 12:39 pm
reippuert View the latest post
Users browsing this forum: glam2deaf, wingguy and 7 guests
