Post new topic Reply to topic  [ 19 posts ]
Go to page 1, 2  Next
PostPosted: Sat Jan 29, 2011 9:49 am
Hi there,
I have a Shimano rear hub for my rear Zipp wheel. Yet, due to rear derailleur change (from Dura ace 7900 to Campy 10), I need a Campy-compatable cassette to be installed on the rear wheel. The problem arising thus is I am having a Shimano hub, so is there a way to put a Campy cassette into a Shimano hub?
Advice from you guys are highly appreciated! Thanks!!
PostPosted: Sat Jan 29, 2011 1:18 pm
assume you mean that shifters also campy. you need to swap the freehub. zipp sells campy ones. splining is quite different to shimano.
dangerous curves ahead
PostPosted: Sat Jan 29, 2011 10:32 pm
here's one. it's an easy swap.
http://cgi.ebay.ca/Zipp-182-Freehub-2005-2008-Campagnolo-9-10-Speed-Blue-/220717200518?pt=Cycling_Parts_Accessories&hash=item3363c53486#ht_2598wt_1139
PostPosted: Sat Jan 29, 2011 11:59 pm
You have a couple of options but you should be able to use the shimano 10 speed cassette with the campagnolo rear derailleur and campagnolo ergo 10 levers.
Reference this viewtopic.php?p=372177
PostPosted: Sun Jan 30, 2011 12:30 am
it's not the cheapest option, but http://www.excelsports.com/main.asp?pag ... 1&minor=10 conversion cassettes seem to be what you're looking for.
PostPosted: Sat Apr 16, 2011 10:29 am
Nope. Will not fit. Campy will only fit on campy hubs.
PostPosted: Sat May 14, 2011 2:20 pm
Choices (consolidated): American Classic or Wheels Mfg conversion cassette, Free hub swap, a compromise of shifting on existing Shimano cassette.
PostPosted: Mon Feb 06, 2012 11:01 pm
Shimano 10 speed, sram 10 speed, and Campagnolo 10 speed cassettes, has the same distance between the sprockets...
The difference is that Campy's sprockets are thicker, and therefor also longer lasting. Witch makes it harder to measure :smartass: :smartass: :smartass: :smartass: :smartass: :smartass:
PostPosted: Tue Feb 07, 2012 1:31 am
Quote:
Shimano 10 speed, sram 10 speed, and Campagnolo 10 speed cassettes, has the same distance between the sprockets,
wrong
http://www.sheldonbrown.com/gloss_sp-ss.html#spacingk7
PostPosted: Tue Feb 07, 2012 2:21 am
Or just keep using your Shimano cassettes and use a Shift Mate.
http://jtekengineering.com/shiftmate.htm
PostPosted: Tue Feb 07, 2012 6:11 am
Can you swap the freehub body on all rear zipp wheels without needing to redish the wheel?
PostPosted: Tue Feb 07, 2012 10:49 am
bikerjulio wrote:
wrong
You are right, i got this paper at school Image
and believed it, how stupid of me. Sorry to have spread wrong facts in here :oops:
PostPosted: Tue Feb 07, 2012 1:11 pm
You do not need a Campy cassette. You can run Shimano cassette with campy levers + RD (10sp) without any trouble. My girlfriend has been riding bike like this for a long time without any problem (Campy chain). The Shimano cassette provides smoother shiffting.
PostPosted: Tue Feb 07, 2012 1:23 pm
Yes.
PostPosted: Tue Feb 07, 2012 2:56 pm
Yes. +1
Try this - it works for me both ways round and with minor changes in cable tension both setups index 100% perfectly if the chain and cassette are both roughly equally used. I really don't understand why anyone buys special cassettes and fiddles with cable devices for this. And whether you use chain x, y or z doesn't matter either.
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], brearley, CarlosFerreiro, devinci, MSN [Bot] and 10 guests
There are no new unread posts for this topic. Attachment(s) Campy 10Speed 12/25 all Ti cassette SOLD
CP
Sun Feb 10, 2013 8:24 pm
CP View the latest post
There are no new unread posts for this topic. chian whip for campy 11 sp cassette
mjduct
10
674
Tue Jul 10, 2012 10:14 pm
petal666 View the latest post
There are no new unread posts for this topic. 13 to 28T Cassette (Shimano Pattern)
SergeantRock
9
522
Tue Apr 09, 2013 9:28 am
bm0p700f View the latest post
There are no new unread posts for this topic. Attachment(s) New Campy Scirroco CX with Chorus 11 speed cassette
Thrillho
Tue Apr 30, 2013 9:08 pm
Thrillho View the latest post
There are no new unread posts for this topic. Campagnolo chain with shimano cassette?
Boss93
Fri Mar 22, 2013 12:03 pm
mikipov View the latest post
It is currently Wed May 22, 2013 9:09 pm
