"PRO" Cycling Discussion
pastronef
by pastronef
California: are UHC and Belkin wearing those different Bell aero helmets, because the ones they wear in Europe are not USA omologated?
milroy
by milroy
A couple of days late but a nasty perspective of the Garmin Sharp TTT crash.
https://www.youtube.com/watch?v=fyvCMG2qzWM
DartanianX
by DartanianX
Lampre Merida not running the rotor power meter any more. Instead opting for a P2M on a rotor chassis.
Sent from my Nexus 4 using Tapatalk
dereksmalls
by dereksmalls
And Cav wins by the narrowest of margins at ToC
Wingnut
by Wingnut
Curious...Adam Hansen still riding 22mm tyres...are the sheep on here going to follow him back from 25mm tyres like they did with narrow handlebars?
"It's not the destination...it's the ride!"
ave
by ave
Kittel was soo much faster than the others... That was amazing!
mentok
by mentok
milroy wrote:A couple of days late but a nasty perspective of the Garmin Sharp TTT crash.
i wouldn't have thought it was shorts weather in belfast, even this time of year, but there you go.
ultyguy
by ultyguy
Re: Hansen on 22s
Don't forget he's also one of the few still on narrow wheels (Boras are 20-21mm wide) and wheel/tire interface means a lot to aero. A wider tire on that rim would just slow it down even more...
MattSoutherden
by MattSoutherden
And since when has Hansen been a sprinter? :/
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
KWalker
by KWalker
Ultyguy is right- the wheel/tire interface is more important than actual tire width. The lightbulb effect is worse than you'd think. I doubt he chooses his tire width anyways.
Also, most riders are only running 25s on the rear where this matters less due to air turbulence. Wider does not mean more aero nor does it necessarily even mean less crr, but its definitely a bit more comfortable.
As for the narrow bar comment don't knock it until you try it. A lot of pros are still on narrow bars and everyone I know that has sized down has loved it. Some cycling myths need to die a fast death and wide bars providing any sort of advantage is one of them. I'm excited to try 38s.
Gramz
Failed Custom Bike
Geoff
by Geoff
That is a 22 on the front, which will be fine. The depth of the Campagnolo rim bed may also allow a 22 on the rear without the risk of pinch-flats. I still think that the 22 handles better up front.
ave
by ave
As for his Hansen's narrow handlebars - it was clear on a hilltop finish in Turkey(?) that his bike was quite nervy compared to the others'.
nathanong87
Resident master of GIF
by nathanong87
ave wrote:As for his Hansen's narrow handlebars - it was clear on a hilltop finish in Turkey(?) that his bike was quite nervy compared to the others'.
i was just about to add this to the thread. He looked huge on that bike climbing out of saddle on hoods. Pros can do whatever Pros want, but that's all im saying. It looked* like he was riding narrow bars lol.
ultyguy
by ultyguy
Sastre used to vary his bar width depending on stage profile.
If you're in the wind most of the time, I can def understand the narrow bars. From a fitting perspective as well, you can get a lower front end with narrower bars as it actually raises your chest a bit. However, I would find it hard to generate much leverage through the bar if it was narrower than my shoulders (still have no ligaments in my right shoulder after seperating it years ago).
