"PRO" Cycling Discussion
jooo
by jooo
luckypuncheur wrote:MSR will be Sagan's first monument win. I simply don't see a tactic that would put someone else in a position to beat him.
Really?
luckypuncheur
by luckypuncheur
I really rate Ciolek as a rider but doubt he'd have won without the race interruption last year.
Get a bicycle. You will certainly not regret it, if you live.
stella-azzurra
by stella-azzurra
The teams at a race put their best man for the job so here are my picks
Edvald Boasson Hagen --> 1st
Peter Sagan --> 2nd
Simon Gerrans --> 3rd
A lot of hark horses from the past;
Pozzato
Pelizzotti
Bennati
Nibali (outside shot)
hna
by hna
Gerrans isn't riding.
MarkGiardini
by MarkGiardini
Vansummeren
Sent from my SGH-M919 using Tapatalk
KWalker wrote:chill out perv dogs, homegirl is still only 17.
stella-azzurra
by stella-azzurra
hna wrote:Gerrans isn't riding.
No problem I'll update my list as cycling news didn't.
Peter Sagan --> 2nd
Pozzato --> 3rd
Luke Durbridge
Pelizzotti
Bennati
lippythelion
by lippythelion
According to cyclingnews Stannard isn't on the MSR start list. I'm at work so I can't check other sites to see if it's a mistake.
Tinea Pedis
by Tinea Pedis
Anyone handy with solidworks (or whatever you would use) and be able to give an approximation of the saddle setback for Hansen's bike?
http://www.cyclingnews.com/features/pho ... -sl/297702
MortenE
by MortenE
According to the article it's 65mm.
Tinea Pedis
by Tinea Pedis
Hence asking if someone could check...
CulBaire
by CulBaire
Nic,
I happen to know the writer of the article! Knowing Romey I can imagine he would have been running a tape measure over the thing while taking pictures. He is (or was back in the day) a bike nerd in the truest sense. I will ask if he can confirm the measurements.
I am positive he was a member on here at one point also.
AH
nathanong87
Resident master of GIF
by nathanong87
Tinea Pedis wrote:Hence asking if someone could check...
i did the calculation based on ridley's geometry chart and the specs in the article, just on a piece of paper.
i did make some assumptions on the saddle. because i was only able to find the length of the saddle. So in knowing that and using an underside image of the saddle and measuring my computer screen with calipers.... i was able to find rail length from the ratio. Also i assumed that the rails were in the center of the saddle with equal material in front and behind the center point of the rails, this was based on measuring the picture as well. I also assumed that the thomson cradle was 27.2 length. Pictures show it to be slightly longer than the diameter of the shaft however. So i then assumed the clamp could be moved to the very edge rearward of the rails. Also assumed that rails were 25.4mm below the plane of the top of the saddle.
needless to say I'm interested to hear what the guy above me finds out, but the number i got was closer to 82mm which would be the tip of san marco saddle behind the vertical line 90deg drawn through the bottom bracket. I certainly could be wrong though through margin of error on assumptions of saddle
the numbers from the surface seem to make 'sense'. The horizontal distance if there was no saddle , from the bb-top through seattube (816mm) is 239mm, to get to directly above bb. Selle lists the san marco total length as 278mm. So if you imagine crudely the rails being in the middle and being clamped in the middle that would leave ~140 behind and in from of the seat post center. and that's 100mm 'setback'. (i am leaving out the horizontal extra distance because in reality the clamp is clamping the rail at a plane 1inch (assumed) lower than the top of the saddle). And despite moving a clamp fore or aft in rail, it's limited by the outer edge of the clamp, meaning the true adjustability of fore/aft is less than the total length of rail.
djconnel
by djconnel
1. View source for cyclingnews page
2. Find the URL for the JPG (there's a lot of JPGs, but it's sort of obvious)
3. Click on that.
4. Copy image
5. Load into GIMP.
6. Find angle between top and bottom of tires. Take average.
7. Rotate layer by the negative of this angle. This should flatten the bike reasonably.
8. Measure lateral dimension of a tire. This should be around 2.11 meters / π. Divide by number of pixels. This is distance per pixel.
9. Measure lateral pixels from tip of saddle to center of bottom bracket.
I did all of this and got 5.3 cm. But perspective distortion is tricky.
The bike is extraordinary. If I saw that parked outside a cafe, or on the train, I'd shake my head sadly, maybe discretely take a photo for the freaks thread. But Adam obviously knows what he's doing.
djconnel
by djconnel
For the record, my prediction was Cavendish.
In head-to-head Cavendish is going to beat Sagan and probably Degenkolb. Greipel is even with Cav, or close, but Cav has a stronger team and is probably stronger tactically. It's going to be a headwind so it's going to be very hard for a break to stay away, and Sagan needs separation. A brutal pace on the Cipressa could pop Cav and Gripel, but that takes a team to sacrifice itself, and that's not likely. On the Poggio, the headwind will make it relatively easy to sit on. Wet roads will be a factor but Cav's good in the rain. Crashes are always an issue and I can't predict those.
Best chance if these two get dropped is Sagan, then Degenkolb. Hard to see Cancellara winning so I'll put him 5th.
It's too bad Phinney and Garrans are missing: they would have added spice to the finish.
martinko
by martinko
Just saw Antonio Parrinello in the breakaway. His surname is not far from the bike brand :)
I hope for Sagan, obviously.
