It is currently Fri Jun 23, 2017 9:44 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 28331 posts ]  Go to page Previous 11436 1437 1438 1439 14401889 Next
PostPosted: Sat Nov 30, 2013 11:56 pm
Didn't see it, my bad.
Gramz
Failed Custom Bike
PostPosted: Sun Dec 01, 2013 9:46 am
Fiery wrote:
I find it ignorant and disrespectful to automatically dismiss something just because one doesn't understand or personally like it.
This isn't about disrespect or dislike. I'm not even criticizing. I simply find it amazing that a guy the exact same size as me, professionally fitted to ride a 56cm frame with a 120mm stem, would "choose" to ride a 50 or 51 necessitating a 130mm (or longer) stem. To each their own.
PostPosted: Sun Dec 01, 2013 3:46 pm
It goes both ways, I guess. I can't believe that someone that size can ride a bike with a 160mm headtube, but there are lots of guys that do...
PostPosted: Sun Dec 01, 2013 9:28 pm
Shop Wrench
A low position being 'poor-fitting' or uncomfortable is a myth.
Negative side effects of a too upright position quoted from http://www.bikepro.com.au/bike-fit-myth-debunking
Really, If you have some spare time read this article. It's a very refreshing take on bike fitting and has helped me a lot with fitting clients.
Quote:
1. It transfers most of your upper body weight from your load bearing arms, to your pelvis-spine complex, which induces lumber spine injuries and saddle soreness.
2. Some weight shifts to your feet, as your pelvis-spine complex seeks extra support. Your feet then applies downforce onto the pedals during the upstroke, an undesirable after effect.
3. Your upper body and arms need to work much harder to counter the extra pedaling up thrust when in high loads.
4. With spinal flexion, the geometry of the psoas causes the front rib cage to compress, as there are vital internal organs, the restriction of the abdomen against the thighs limits the movement of the diaphragm, leaving the persons breathing restricted.
5. The lower back extensor muscles (psoas antogonist) strains to counter the spinal flexion, which eventually induces back pain and injuries.
6. This causes your body to be supported by 1 static point (saddle) and 2 dynamic points (feet) instead of 3 static points. (saddle and two hands). As the points are not static, this causes the upper body to need to make constant adjustments to keep balanced, wasting energy.
7. Without both hands to support the upper body, the spine deals with bending moment, shear stress and torsional stress simultaneously
8. The position which allows your body to remove weight from the handlebars, is the setback position, this creates another 20 unintentional consequences.
PostPosted: Sun Dec 01, 2013 11:22 pm
BMC has some really weird geo's. :wink:
PostPosted: Sun Dec 01, 2013 11:37 pm
Yep, that 50cm frame that most of their riders use has a 535mm top tube.
PostPosted: Mon Dec 02, 2013 2:03 am
And you're not the age, fitness level, or flexibility level of a pro either.
Gramz
Failed Custom Bike
 Post subject: Re:
PostPosted: Mon Dec 02, 2013 8:36 am
Wingnut wrote:
Tapeworm wrote:
And as mentioned above, probably not wise to publicly eschew a power meter when your sponsor is marketing their new...wait for it... power meter. Not very professional.
I think you read more into this than what was really in the article...
Martin didn't trash his sponsor or the product so not so big an issue, he just stated he doesn't have the power of fellow racers so has to use his brain & instincts to be efficient, I'm sure he uses his sponsors products at times...it's refreshing to see an opinion that differs from many in the peloton these days, maybe that's why Thomas Voeckler is popular? So you question his intelligence because he can read a race, train well and win without devices?
I'll just wait for the third sigh shall I...
I know precisely how my team management would react if I made comments like Martin's and in the context of my major sponsor just releasing a product that I've gone on to say I have no use for.
Even if he's not a user of it, he could have worded it a lot better. But then the media training these guys have is pretty minimal, so...
http://www.nicksquillari.com.au
The Gram
The Men of Steel
PostPosted: Mon Dec 02, 2013 2:59 pm
The smart way to say it: "I don't use a power meter...... but I have one on my bike because its useful for the team doctors and coaches and the new Vector pedals barely weigh anything so I don't even notice its there."
Gramz
Failed Custom Bike
PostPosted: Mon Dec 02, 2013 3:57 pm
Live press conference can be streamed live here:
https://www.youtube.com/watch?v=63HAhYAUptA
What's in the boxxx??
PostPosted: Mon Dec 02, 2013 4:17 pm
Tinkoff-Saxo - "long-term stability"... lol
PostPosted: Mon Dec 02, 2013 4:33 pm
Oleg looks like he could use a drink or two..
PostPosted: Mon Dec 02, 2013 5:58 pm
PostPosted: Mon Dec 02, 2013 6:38 pm
:shock: How often do you replace that? Got a build thread?
Edit: D'oh. Just realised what thread I'm in and the fact it's got a NFTO topcap.
PostPosted: Mon Dec 02, 2013 6:42 pm
Resident master of GIF
duel weilding garmin mounts. Stem so long. wyked
Nate ★ Life , my tumblr joint
Instagramz
My Podcasts
There are no new unread posts for this topic. Attachment(s) 2017 'PRO' cycling discussion.
[ Go to page: 1229 230 231 232 233 ]
294072
Fri Jun 23, 2017 9:30 pm
CrankAddictsRich View the latest post
There are no new unread posts for this topic. Garmin Edge 820 Discussion Thread
[ Go to page: 13 4 5 6 7 ]
EvilEuro
96
12850
Sat May 27, 2017 2:38 am
zev View the latest post
There are no new unread posts for this topic. Interval Discussion and Resource Thread
in Training
RyanH
11
2070
Sun Sep 18, 2016 8:19 pm
RyanH View the latest post
There are no new unread posts for this topic. Total Cycling
Bridgeman
Tue Feb 07, 2017 3:36 am
Bridgeman View the latest post
Users browsing this forum: prebsy and 10 guests
