It is currently Mon Jan 22, 2018 11:34 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 28331 posts ]  Go to page Previous 11148 1149 1150 1151 11521889 Next
PostPosted: Tue May 14, 2013 1:58 am
Baby Schleck not even close. He is done.
PostPosted: Tue May 14, 2013 2:11 am
This will be a truly epic stage tomorrow. Perfect profile for making GC differences; huge mountain first, wet descend, and then another huge mountain with elevated finish line. If wiggo is strong, he can make other riders push their limits in the first mountain, and in the second make some time, as he can't keep any advantage on the descent...
http://www.steephill.tv/players/profile ... ile-10.jpg" onclick="window.open(this.href);return false;
Happy Trails !!!
 Post subject: "PRO" Cycling Discussion
PostPosted: Tue May 14, 2013 2:22 am
The fact he held on as long as he did shows a lot for his form coming around. I know he doesn't have many fans around here, but he looks to be progressing. I am never one to cheer for one's failure, so I hope he comes back to show some form of old.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Tue May 14, 2013 2:57 am
wingguy wrote:
Now that's what I call a road surface! None of that billiard table smooth poncy French alpine rubbish :twisted:
Yeah, for the Tour they repave the entire route. Rir the Giro, only the real dodgy parts. ;)
Sent from my Galaxy Nexus using Tapatalk 2
PostPosted: Tue May 14, 2013 3:49 am
I have no clue why and which admin deleted my prior post Re: fellow weight weenie Adam Hansen........anyways, check out this article where it gives Weight Weenies a great plug!! :beerchug:
http://www.cyclingnews.com/news/adam-ha ... -own-hands
Go Adam - Giro stage winner in 2013!! :podium:
PostPosted: Tue May 14, 2013 5:26 am
I have to agree with Merckx. I have never seen a pro freeze up like that before in the middle of the race. Plenty of races when it was raining and they went down and then proceeded to get on it again.
I understand that they would be more tentative but not like that. He froze up badly.
Merckx: Wiggins descends like a novice
Five times winner of the Giro d'Italia, Eddy Merckx, has told Het Nieuwsblad that "It is incomprehensible how Wiggins descends," after the Sky leader suffered a crash on stage 7 and was then dropped on a descent on stage 9 to Florence. Wiggins currently sits 1'16 down on maglia rosa Vincenzo Nibali but has looked increasingly vulnerable on the wet roads.
"I never saw it before and have never experienced that myself. I do not know why he suddenly descends so bad. He's ridden the past few days like a novice on the downhills. I think there is something wrong with his material, he has no confidence."
"He seems okay in terms of his physical condition and it is still too early to draw conclusions. Wiggins is right when he says that there are two more hellish weeks."
http://www.cyclingnews.com/news/giro-di ... oken-bones
PostPosted: Tue May 14, 2013 5:29 am
+1 tompkins
Current:
T2
Retired:
PostPosted: Tue May 14, 2013 5:51 am
+2
PostPosted: Tue May 14, 2013 6:54 am
Funny, I'm reading Friebe's 'Eddy Merckx' and it's quite extensive how, early on, he was a terrible descender.
Maybe he can't quite recall what he was like at one point.
Difference being at that point he was a neo-Pro, not a Tour de France winner.
VeloKicks
The Gram
The Men of Steel
PostPosted: Tue May 14, 2013 7:08 am
http://www.tdwsport.com/en/imagedesk/im ... /id/195720
Mick Rogers with Oakley
(all the team is on RH+)
PostPosted: Tue May 14, 2013 9:00 am
it must be really hot in california right now. look at 3:21 => a quickstep guy collapses
http://www.youtube.com/watch?v=TgUXir0OjIw
PostPosted: Tue May 14, 2013 9:10 am
Yeah, it's been hot for the past few days. It will get cooler later this week.
To put it in (mild) perspective: the stage was in the Palm Springs area. Yesterday's temperature was peaking at 103°F (recorded) - but it felt much hotter than that (it always does). The race pretty much finished at the peak of the day's heat.
Add to that the road up to the Palm Spring Tram, which was at the end of the stage. It isn't easy by any means.
Climbing in severe heat at the end of a stage on a road which reflects the heat, no shade anywhere to be found, and gradients that often make you feel like you will fall backwards? Pretty much everyone collapsed either on the stage or afterwards.
Thankfully it appears the weather will get much cooler (by comparison) for the next few days. By the time the riders are up North they'll be dealing with much more manageable temperatures.
PostPosted: Tue May 14, 2013 9:52 am
tonytourist wrote:
Tramway Road is a pretty nasty climb, especially in the heat. I've done it in similar conditions (110 at the base) and wouldn't want to do it a second time! After 120 miles, forget it :P
hmm true, id didn´t look as such a hard climb in TV probably due to the open surroundings and wide road, but the numbers say it clearly:
Length: 3.8 miles
Elevation Gain: 1910 ft
Average Grade: 9.5%
Last 1.2 miles: 12%
Last 1/2 mile: 14.3%
Shut Up Legs! (Jens Voigt)
PostPosted: Tue May 14, 2013 9:58 am
The numbers actually don't say it clearly enough. The road peaks at over 24% at around less than 200m to the line.
PostPosted: Tue May 14, 2013 4:18 pm
I'd say that now the Giro is over for Wiggins. Evans looking surprisingly strong today. My new picks are Evans or Uran with that uphill TT more suiting Uran.
Gramz
Failed Custom Bike
There are no new unread posts for this topic. Pirelli Pzero Velo (and their varience) tire discussion thread.
in Everything wheels
Hexsense
39
7187
Wed Jan 10, 2018 11:44 pm
stormur View the latest post
There are no new unread posts for this topic. Cycling in belgium
TomColnago
Thu Jul 20, 2017 3:20 pm
Fiery View the latest post
There are no new unread posts for this topic. Cycling Glasses
Dagger9903
27
2637
Mon Aug 14, 2017 3:48 pm
BearCrawl View the latest post
There are no new unread posts for this topic. Cycling in New York
cyclespeed
Thu Feb 23, 2017 6:47 pm
cyclespeed View the latest post
There are no new unread posts for this topic. Rheumatoid Arthritis - Cycling
Colnago71
Fri Dec 29, 2017 4:46 pm
djgarrett21 View the latest post
Users browsing this forum: No registered users and 9 guests
