"PRO" Cycling Discussion
Liggero
by Liggero
I´ve tried laced shoes, and they were far far more comfortable, as they distribute the tension and there are never hot spots, once you get the proper tension. Only problem is that you can not re adjust them while riding, but apart from that I can understang why wiggins is on laces...
Happy Trails !!!
djconnel
by djconnel
Tullio Campagnolo, on the legendary Passo Croce d'Aune stage of the 1930 Giro, was the first rider to use full-Velcro shoes.
stella-azzurra
by stella-azzurra
Liggero wrote:I´ve tried laced shoes, and they were far far more comfortable, as they distribute the tension and there are never hot spots, once you get the proper tension. Only problem is that you can not re adjust them while riding, but apart from that I can understang why wiggins is on laces...
Wiggins wants to be 'different'.
Getting hot spots is a different physical issue. I am sure one gets hot spots with and without laces.
If laces were that good every one in the peleton would wear them.
jooo
by jooo
Have you ever been to a velodrome?
stella-azzurra
by stella-azzurra
Well velonews says that they are lace-up shoes on an FDJ rider.
My apologies they are not Wiggins shoes.
Although Wiggins has used lace up shoes before
http://www.cyclingnews.com/features/pho ... nce/131767
prendrefeu
by prendrefeu
You needed Velonews to tell you what you could have figured out by looking at the logo on the sock?
Or maybe the frame is clearly a Lapierre and there's only one team in the Pro Tour (road) that rides Lapierre?
petepeterson
by petepeterson
He still does. The Bont Zero lace up.
djconnel
by djconnel
More factual than my last post, Luca Paolini now leads Wiggins by 17 seconds. He would lead by at least 22 seconds had he not looked back repeatedly then cruised across the line in a slow salute. What was up with that? Is he simply that stupid or is holding onto the jersey considered undesirable and he was hoping to give up some time?
koebes
by koebes
Tillquist wrote:
racermech wrote:Was wiggo (or any Sky) on the new TT pina??
No
http://www.youtube.com/watch?v=aorAionRUTA
Look at 0:11 and 2:01! He used the new TT Pina for warm up!
djconnel
by djconnel
Maybe they were afraid it was so fast he'd rear-end the rider ahead of him.
Tillquist
by Tillquist
koebes wrote:
No
Yes, when he warm up, but not in the TTT race........
See all my bike h e r e
koebes
by koebes
I didn't want to correct you; I just wanted to add the info 8)
http://www.cyclingnews.com/features/photos/giro-ditalia-tech-gallery-time-trial-gear-from-stage-2/264353
The Pinarello Bolide Team Sky prepared for the race was put to one side as Wiggins opted to ride his backup Graal
Tillquist
by Tillquist
koebes wrote:I didn't want to correct you; I just wanted to add the info 8)
Yes :)
KWalker
by KWalker
djconnel wrote:More factual than my last post, Luca Paolini now leads Wiggins by 17 seconds. He would lead by at least 22 seconds had he not looked back repeatedly then cruised across the line in a slow salute. What was up with that? Is he simply that stupid or is holding onto the jersey considered undesirable and he was hoping to give up some time?
Probably has no interest in keeping the jersey and have his team do multiple days of work to protect it.
Gramz
Failed Custom Bike
handler
by handler
Willier wrote:Any info about these shoes:
Those are Sierra cycling shoes. Made in france. Popular among french riders. Cost around 500 €. What I know, they are only made to order. Interesting though is that, they already use Atop "boa" system. Same as the new Bont Vaypor+ and Zero+ uses.
http://www.sierra-shoes.com/
