Post new topic Reply to topic  [ 17509 posts ]
Go to page Previous  1 ... 975, 976, 977, 978, 979, 980, 981 ... 1168  Next
PostPosted: Thu Jan 24, 2013 9:18 pm
Location: At the bottom of the barrel & starting to dig
It's funny how when you rock up with a frame fit pump everyone takes the piss. Then when they puncture they all want to borrow it
PostPosted: Thu Jan 24, 2013 9:56 pm
HUMP DIESEL wrote:
It also says that Goss' setback is 4.5? Is that not breaking the rules?
I like the set up though, slick looking bike.
HUMP
most likely mismeasured or the ground isn't level. That'd be extremely hard to get on a frame that size with that much setback.
PostPosted: Thu Jan 24, 2013 9:58 pm
i think in other articles goss's bike seems to have a 0-5mm offset post , which might explain the lack of 'lots of setback'.
PostPosted: Thu Jan 24, 2013 10:21 pm
Are Astana's Corimas legal? I thought wheels had to have a minimum of 16 spokes for mass start races?
PostPosted: Thu Jan 24, 2013 10:31 pm
according to gazzetta dello sport, Vini Fantini (former farnese) signed danilo di luca
PostPosted: Thu Jan 24, 2013 10:39 pm
Yes, they are legal. They fall under the "Non Standard" category which means that they have to be tested and approved by the UCI using their protocol(whatever that may be :noidea: ).
PostPosted: Thu Jan 24, 2013 10:45 pm
Ah, of course. The fox is guarding the chicken coop.
Maybe if I pay the local commissaire I can be declared non-standard and have my saddle less than 6cm behind the bottom bracket of my TT bike.
PostPosted: Thu Jan 24, 2013 10:59 pm
What are you talking about Privateer? :noidea:
The Corima wheels are non-standard because, well, look at them! They're non-standard wheels. They also have official UCI approval... as in they are registered, on the UCI's list of approved wheels, have the badge, and so on. They underwent UCI's testing protocols, passed the tests, and work. Is this the first time you are seeing them? The wheels are a bit old - at least one or two years on the market now, and have been on plenty of podiums since their introduction.
In your metaphor analysis, you are assuming that some kind of chicanery is being pulled, which it isn't.
In your example, the local commissaire will still declare your set up not legal. It does not pass the UCI's tests nor rules.
Exp001
PostPosted: Thu Jan 24, 2013 11:05 pm
Privateer, 5 cm is the limit. If you want to run less you need to get a morphological exemption like has been mentioned above. You can also run an ISM saddle which will put you really far forward and still conform to the rules.
PostPosted: Fri Jan 25, 2013 12:22 am
Stage 3 Tour Down Under power analysis
http://www.ridemedia.com.au/?p=8462
have a rough estimation of FTP. Hopefully can build the picture as the Tour goes on.
PostPosted: Fri Jan 25, 2013 12:35 am
Loving the SRM data, hopefully the UCI don't stop you publishing it like they disallowed them last year - don't want no pesky signs of doping rearing their heads now for all to see
PostPosted: Fri Jan 25, 2013 1:26 am
http://www.ridemedia.com.au/?p=8462" onclick="window.open(this.href);return false;
Cheers! enjoying the insight :thumbup:
PostPosted: Fri Jan 25, 2013 2:06 am
Thanks for linking these, however I would take any 38 degree day FTP estimations with a large grain of salt.
PostPosted: Fri Jan 25, 2013 2:34 am
None of those calculations used data from yesterday.
It's also, as mentioned, a "rough estimate". Need a few more rides to fill in some blanks. But I don't think it's too far off.
PostPosted: Fri Jan 25, 2013 5:02 am
Just curious -- is UCI actually testing the products these days? Like impact, fatigues, etc.?
I had quite a bit of correspondence with the UCI 7-8 months ago and the frame sticker (costs thousands of euros BTW) were basically about geometry and shapes. A measuring tape could do the job in 3 mins. This is one of the reasons I thought UCI is a bunch of a-holes.
prendrefeu wrote:
...They underwent UCI's testing protocols, passed the tests, and work.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
twitter: Falco_bike
Facebook: falco.bike
Post new topic Reply to topic  [ 17509 posts ]  Go to page Previous  1 ... 975, 976, 977, 978, 979, 980, 981 ... 1168  Next
Users browsing this forum: ayrej2, Google Adsense [Bot], twigstim, Willier and 20 guests
There are no new unread posts for this topic. Pedal discussion, again.
asdf123
23
1720
Thu Mar 28, 2013 9:31 pm
claus View the latest post
There are no new unread posts for this topic. Light touring bag recomendations/discussion
in Cyclocross / Touring
dvincere
10
288
Tue May 21, 2013 11:39 pm
jordo99 View the latest post
There are no new unread posts for this topic. Non-cycling friends: 'pro soccer is harder than pro cycling'
[ Go to page: 1, 2, 3, 4, 5 ]
Maximilian
61
1875
Fri Mar 22, 2013 8:50 am
mattr View the latest post
It is currently Thu May 23, 2013 4:25 pm
